domoticz in synology as package! Available now.
Ady92100
Domoticz version: >V3.6796
Post by Ady92100 »
@JumboTroll
It works great :P
Do you have an idea for my bash issue poqted on Wed Nov 04, 2015 9:46 pm) ?
Thanks a lot
Synology DS212 + RFXTrx433 + AEon Stick S2
Oregon - Thgr122Nx / Chacon - module 1000w - détecteur de fumée 34131 / OWL -CM180 / Greenwave Multiprise
jumbotroll
Post by jumbotroll »
Ady92100 wrote:@JumboTroll
It works great :P
Thanks a lot
Sorry, but I don't know why only you have this problem.
No another users have reported this issue before.
Jumbotroll
https://paypal.me/Jumbotroll
Jumbotroll
http://www.jadahl.com
mvveelen
Post by mvveelen »
All updates so far are running smoothly on my DS414, thanks for the updates.
Just a reminder to you all: maybe a (small) donation for Jumbotroll would be great. If you appreciate.....donate !
Click on the globe beneath Jumbotroll's picture (is that a selfie, Jumbotroll :D :D ?), and click on the donate button.
Flyer
Post by Flyer »
I added a username and pwd to enter ( web site protection) . now I can not log in anymore and domoticz is " off line".
Could you help me?
Tks
Flyer
Isane
Domoticz version: Stable
Post by Isane »
Flyer wrote:Hello,
Could you help me?
Tks
Flyer
I have the same problem. I tried it with google chrome and it works
yugoos
Domoticz version: 2.3072
Post by yugoos »
jumbotroll wrote:@yugoos
The log does not tell me what the problem is.
Did you uninstall the old domoticz or did you update?
I think you should uninstall the old.
I'm not familiar with ser2net, do you need some special drivers for this device?
Jumbotroll
Hi Jumbotroll,
I managed to install the package using your repository instead of uploading a manual install what i was doing all the time.
working like a charm and now finaly able to use the latest domoticz code ;)
many many thanx,
Yuri
raymond
Domoticz version: V4.10232
Post by raymond »
Latest update V2.3601 gives me a strange error. This Blokcy script used to work flawless, now it pops up as an error in the log.
2015-11-18 08:20:02.073 Error: EventSystem: Lua script error (Blockly), Name: HD Temps_1 => [string "result = 0; weekday = os.date('*t')['wday']; ..."]:1: attempt to compare number with nil
The Blocky script checks if my HD Temp value is > 55 and if it does just send a notification.
Did something change here? It seems like I'm comparing sensor value with a wrong type of string value?
Cheers,
Ray
amz4u2nv
Post by amz4u2nv »
Does anyone know if I can use rfxtrx433 and zwave usb stick together with synology domoticz package?
ThinkPad
Post by ThinkPad »
amz4u2nv wrote:Hi,
Yes.
amz4u2nv
Post by amz4u2nv »
Thanks for the quick reply.
Flyer
Post by Flyer »
screen shot
screen shot
I have problems with the count of the current used ( kWh Meter ), counter/usage detected an anomalous data ( only one day ) , as shown in the image .
Could you tell why ? It's possible correct the data manually ?
My device is:
Aeotec Home Energy Meter G2
tks in advances,
Flyer
tbryel
Post by tbryel »
Has anyone succeeded in downgrading their domoticz installation from the default delivered v2.3607 beta version in to stable version v2.3530.
We've the option to "upgrade" to latest stable version directly in the domoticz localhost:8080 environment. But although it seems to execute and work fine the version didn't change, it remained v2.3607.
I'm trying to align my synology with my raspberry pi domoticz version. And upgrading my raspberry pi to beta version v2.3607 seems quite hard to do as it's not the latest beta (v2.3608).
Synology version: DS213j.
Thanks for any responses and really appreciate your efforts Jumbotroll.
Kind regards,
Tim
lienrag35
Post by lienrag35 »
HI,
Unfortunately, this setup failed on my NAS included USB driver :( .My Nas is DS213+. Does someone else have the same issue ? and know how to solve it ?
thank you for your help.
Limboconnect
Post by Limboconnect »
Dear jumbotroll,
Can you possibly help me for the latest version of domoticz for DSM 1.5 ( bromolow )
On http://jadahl.dscloud.me/sspks/ are versions for DSM 5.2 and higher.
Thanx
jumbotroll
Limboconnect wrote:Dear jumbotroll,
Thanx
Have you tested to install the 5.2 package on 5.1?
I think 5.2 is backward compatible.
Jumbotroll
Jumbotroll
Limboconnect
Thanx
Jumbotroll
Yes but the installer stopt and does not continue.
I get a popup that I must install at least 5.2
jumbotroll
I get a popup that I must install at least 5.2[/quote]
Ok.
I downloaded toolchain for Bromolow DSM 5.1 an compiled a test for you.
domoticz_bromolow-5.1_2.0.3679-7.spk
http://jadahl.dscloud.me/sspks/index.php?fulllist=true
Jumbotroll
Jumbotroll
Limboconnect
Ok.
Jumbotroll[/quote]
Thanx is working...
The problem wat i see now is that my LUA script doesn't work correct.
Error: EventSystem: Warning!, lua script /usr/local/domoticz/var/scripts/lua/script_device_deurbel.lua has been running for more than 10 seconds
--2015-11-24 10:29:54-- http://192.168.1.100:8084/camsnapshot.jpg?idx=3
Connecting to 192.168.1.100:8084... connected.
HTTP request sent, awaiting response... 2015-11-24 10:30:04.001 Error: EventSystem: Warning!, lua script /usr/local/domoticz/var/scripts/lua/script_device_deurbel.lua has been running for more than 10 seconds
2015-11-24 10:29:53.999 (RFXcom 433,92MHz) Lighting 2 (Deurbel)
200 OK
Length: 268633 (262K) [image/jpeg]
Saving to: '/volume1/homes/ilemmens/Deurbel_Snapshots/deurbel-24-11-2015__10-29-54.jpeg'
0K .......... .......... .......... .......... .......... 19% 145M 0s
50K .......... .......... .......... .......... .......... 38% 179M 0s
100K .......... .......... .......... .......... .......... 57% 44.6M 0s
150K .......... .......... .......... .......... .......... 76% 157M 0s
200K .......... .......... .......... .......... .......... 95% 211M 0s
250K .......... .. 100% 240M=0.002s
2015-11-24 10:30:04 (111 MB/s) - '/volume1/homes/ilemmens/Deurbel_Snapshots/deurbel-24-11-2015__10-29-54.jpeg' saved [268633/268633]
{"ok":true,"result":{"message_id":270,"from":{"id":133920744,"first_name":"Deurbel","username"
When i use it from CLI it works oke.
sh /volume1/@appstore/domoticz/var/scripts/bash/SentSnapshot.sh
Gaat alles perfect.
/volume1/@appstore/domoticz/var$ sh /volume1/@appstore/domoticz/var/scripts/bash/SentSnapshot.sh
--2015-11-24 10:32:51-- http://192.168.1.100:8084/camsnapshot.jpg?idx=3
HTTP request sent, awaiting response... 200 OK
Length: 268739 (262K) [image/jpeg]
Saving to: '/volume1/homes/ilemmens/Deurbel_Snapshots/deurbel-24-11-2015__10-32-51.jpeg'
0K .......... .......... .......... .......... .......... 19% 199M 0s
50K .......... .......... .......... .......... .......... 38% 324M 0s
100K .......... .......... .......... .......... .......... 57% 325M 0s
150K .......... .......... .......... .......... .......... 76% 334M 0s
200K .......... .......... .......... .......... .......... 95% 307M 0s
250K .......... .. 100% 342M=0.001s
2015-11-24 10:32:51 (289 MB/s) - '/volume1/homes/ilemmens/Deurbel_Snapshots/deurbel-24-11-2015__10-32-51.jpeg' saved [268739/268739]
Lua:
  if (devicechanged['Deurbel']=='Group On') then
    os.execute('/volume1/@appstore/domoticz/var/scripts/bash/SentSnapshot.sh')
    print('Deurbel is ingedrukt')
Bash:
#!/bin/sh
today=`/bin/date '+%d-%m-%Y__%H-%M-%S'`;    #Used to generate filename
IP="192.168.1.18"                       # IP address Camera
#Ping IP-address of camera to see if it's online, otherwise we don't have to grab a snapshot
if ping -c 1 $IP > /dev/null ; then  #Grab snapshot
#Get Snapshot from camera
wget "http://192.168.1.100:8084/camsnapshot.jpg?idx=3" -O /volume1/homes/ilemmens/Deurbel_Snapshots/deurbel-$today.jpeg
#Send pushnotification with snapshot
/usr/bin/curl -s -X POST "https://api.telegram.org/bot................../sendPhoto" -F chat_id=........ -F photo="@/volume1/homes/ilemmens/Deurbel_Snapshots/deurbel-$today.jpeg"
#Delete previous taken snapshots older than 7 days
find /volume1/homes/ilemmens/Deurbel_Snapshots/ -name '*.jpeg' -mtime +7 -delete
else /usr/bin/curl --data chat_id=........... --data-urlencode "text=Camera is offline, so no image can be sent"  "https://api.telegram.org/bot..................../sendMessage"
fi
Perhaps you can help me.
Flyer
Post by Flyer »
I tried to install on raspebrrypi my configuration located on Synology nas ds213J by backup and restore.
I use Aeotec Z-Stick Gen5 and RFXCOM.
I noticed the following differences :
device Aeotec Home Energy Meter G2 no longer detects the current and voltage , and the total KWh values ​​of the strange and abnormal peaks .
Moved everything back on Nas all okay.
can help me?
By Flyer
Phifort
Post by Phifort »
Since recent DomoticZ update (Version: 2.3702) I cannot access anymore (Edit) "Thermostat" value of the "Zwave IR extender ZXT-120": it is asked me a password which has not been defined anywhere (in DomoticZ or in device configuration.)
It was boring updating temperature values after each DomoticZ update, it is now impossible to set back the temperature target (default value is 0°, a bit low for house in winter! :-))
If someone knows which "default password" has been set, I am very interested in! ;-)
