Move from RPI B+ to RPI2
tcviper
Post by tcviper »
Hello all,
Has anyone tried moving an existing working SD Card install of domoticz (latest beta build) from RPI B+ model to the new RPI2?
Does anyone know what the steps would be to make it work again or it it will just work as is?
Thx.
antwan
Domoticz version: Latest
Re: Move from RPI B+ to RPI2
Post by antwan »
Use search on this forum.
Rasp Pi 2B: 3x DS18S20 (1-wire), BME280 (i2c)
Cubietruck 1: Aeotec Z-Wave+, RFXtrx433XL+P1, RFXtrx868, TE923 display, SolarEdge API
Cubietruck 2: Aeotec Z-Wave, Voltcraft CO-20
tcviper
Post by tcviper »
I did and i find 100's of threads but nothing specific on if i can just put the current SD card and copy that to a Micro SD and put that in my new RPI2 (coming from RPI).
roblom
Post by roblom »
Try making a backup of the database on the RPi B+(under settings "Restore/Backup" tab). Then install a fresh installation (see WIKI) and then import the backed up databases from the RPi B+.
dijkdj
Post by dijkdj »
Did you succeed? I'm thinking about doiing the same
oliviers
Domoticz version: Stable
Post by oliviers »
I moved from a Raspberry Pi B (512MB) to a Raspberry PI 2B (1MB) simply by moving the microsd card (which, on the R pi B, was in an SD adapter).
It worked instantaneously, but much faster
Oliviers
Paris area
Raspberry Pi 4 - RFXComm 433 - IrTrans - Zwave
oliviers
Post by oliviers »
If you need to copy the SD card to a microsd, this can be done with Win32Diskimager. First "read" the SD card to do a backup, then restore it on a microsd of the same (or higher) capacity.
Olivier
Paris area
stuiow
Domoticz version: 3.6857
Post by stuiow »
oliviers wrote:If you need to copy the SD card to a microsd, this can be done with Win32Diskimager. First "read" the SD card to do a backup, then restore it on a microsd of the same (or higher) capacity.
Olivier
Does this work without any other step's needed? - Like formatting the new microsd card first/installing raspberian first on new card?!
I'm about to do this in the next few days.
Now setup on a RPI3.
Also using Evohome HGI80, RFXTRX433E and a Aeotec Gen5 stick. Mainly a Gen5 Z-Wave system.
My weather (Davis vantage Pro2) data is obtained by weatherunderground
Now collecting rtl_433 data from Apollo Ultrasonic meter
Justino
Domoticz version: 4.10548
Post by Justino »
Olivier
Wind32diskimager will format the sdcard as needed.
So no extra steps needed :D
paulD
Post by paulD »
good to know. thanks,
Users browsing this forum: Google [Bot], jvdz and 1 guest
