Blockly examples
cattoo
Domoticz version: 2.3072
Re: Blockly examples
Post by cattoo »
I want my LUX sensor activate my lights between 15:00 and 22:30 when it goes below 60 Lux, and that part is working (ill think)
But when the time is between 06:00 and 09:00 ill want the motion sensor to handle the lights, but it does not work. What have i done wrong?
StanHD
Post by StanHD »
Not sure but try "And" in place of "Or" for your time periods.
Python:- Broadlink RM2, Sonos
mrf68
Post by mrf68 »
Let's assume it is 12:00 hours and LUX < 60. Then read line 1:
If LUX < 60
that is true, so we continu reading the condition, and because of the OR statement that follows one of the conditions need to be true:
TIME >=15:00
that is not true, but because of the OR we need to check the second condition:
TIME <=22:30
that is true, so it will activate the lights.
Try time = 17:00 hours, then both time conditions are true.
Try time = 23:19 hours, then the first condition (TIME >=15:00) is true.
In my opinion this part will always be true. Same goes for the second part of the script with the Motion sensor.
I must say I make this mistake myself every now and then. And maybe my interpretation at this moment is not correct, please feel free to correct me. :mrgreen:
thecosmicgate
Domoticz version: newest
Post by thecosmicgate »
Running this somebody home blokckly:
But the problem is that the virtual switch flips every second on and off .
As the ping script i'am running chopperRob's script.
As geofence tool we run the android domofence app.
Somebody who can tell me , why the somebody home switch is flipping ?
It's nice to be important, but it's more important to be nice
Scooter ;)
thecosmicgate
thecosmicgate wrote:Running this somebody home blokckly:
Changed it:
but the somebody home switch keeps flipping on / off every second :(
Scooter ;)
Skippiemanz
Domoticz version: 4.10233
Post by Skippiemanz »
I think if you change the 2nd or in else if to and it will work. Because all the devices have to be off for the system to turn iemand thuis off
thecosmicgate
Skippiemanz wrote:I think if you change the 2nd or in else if to and it will work. Because all the devices have to be off for the system to turn iemand thuis off
Problem solved ...next ;-)
Sent from my MotoG3 using Tapatalk
Scooter ;)
Richardsnel
Post by Richardsnel »
I created a Blockly script but how can i run it?
thecosmicgate
Richardsnel wrote:I created a Blockly script but how can i run it?
Domoticz does this for you ;-)
Scooter ;)
Skippiemanz
If you marked the blockly as active
Richardsnel
I marked it as active but wil it run every our?
djoeney
Post by djoeney »
FYI
Automate turning off AV devices in combination with Logitech Harmony HUB and z-wave power switch (could also be a KAKU device or whatever power switch you use).
The logic is when you turn off activity's with your remote control the poweroff switch is turned ON. When this happens you have 5 minutes after that the power switch is turned off. If you put the power switch back on you have 5 minutes to turn on an activity on the remote otherwise the switch is turned off again.
switch off activity.PNG (10.07 KiB) Viewed 6065 times
Compute RPi 2 : Domoticz latest beta, Synology : Domoticz tested beta on failover system.
Peripherals RFXCOM - RFXtrx433, Z-Wave.Me ZME_UZB1 USB Stick,P1 cable on smartmeter, Logitech Harmony Hub, 3 IP camera's
doxikus
Post by doxikus »
Hi to all,
I try to create simple rule to send notification with blocky, I hope that someone can help me to pint right direction.
Rule will be something like this, if temperature is larger than some value send notification each 5 minutes. I use dummmy/virtual sensor so notification don't work on sensor notification settings. Right now I have this rule but it will send mail each minute. Domoticz is installed on synology.
Evelen
Domoticz version: 2.4538
Post by Evelen »
Sending E-Mail when smokedetector is detecting smoke:
EDIT: And turing on lamp:
also video:
https://sendvid.com/tqnqdxcc
MarcelMAH
Domoticz version: v3.8025
Post by MarcelMAH »
I'm trying to create a Blocky to toggle the dummy switch 'Someone home'.
If one of the 4 switches (2x Geo 2x ping) is on then 'Someone home' must me set on.
If none of the 4 switches is on then 'Someone home' must be set to off.
It's not working :(
Running Domoticz on Ubuntu 16.04 on VMware with RFXCOM - RFXtrx433 and Aeotec Z-Stick Gen5
alfred_j_kwak
Domoticz version: 2.3530
Post by alfred_j_kwak »
If none of the switches are one then your AND part is ON not OFF.
MarcelMAH
Post by MarcelMAH »
alfred_j_kwak wrote:If none of the switches are one then your AND part is ON not OFF.
You mean this one?
Changed it, still no go... it won't turn it on even when everything else is on.
StanHD
Post by StanHD »
This one works for sure:-
Westcott
Post by Westcott »
Hi StanHD,
How do you do your Galaxy Geofence?
DomoFence?
StanHD
Post by StanHD »
Yes, Domo fence.
