joshimosh wrote:@epierre:
Thank you very much for the fix !
I have adjusted the access rigth for logs and logs/* as described above. To check if everything is ok, I have entered ./start2.sh. Result looked fine. Calling http://<my_ip>:3001/devices resulted in a lengthy list (xml ?) with my sensors - looked fine.
Then I did a reboot for a clean start, but starman then was not running. What did I wrong ?
You nothing, but someone else reported this issue so everything is not fixed...
can you do a :
sudo sh -x /etc/init.d/MyDomoAtHome.sh start
and give me the output ?
I'm busy tonight I won't have time to check this back home...
thanks !
joshimosh wrote:May I throw in a suggestion here ? I have Domoticz and MDAH installed on a Raspi Pi 2. I write all logs to a /var/log which resides on a ramdisk to avoid wear of the SD-card. In Domoticz, the location of the log can be defined by the user. May I suggest that you add a similar feature to MDAH ?
Sure, I'll have to fix problems one at the time
I have sent you a pm with the output.
Thank you
Josh
Hello!
I've a problem whit my Synology DS213J.
I'm trying to install MyDomoAtHome, but some commands are not recognized by the SO .
When launching ./run-once.sh I get the following error :
sudo not found
apt-get not found.
And the program is stopped.
Flyer wrote:Hello!
sudo not found
apt-get not found.
Synology is not yet supported, I bought one to test but it appears this is not so easy... it will surely come out as a spk package, but I have some challenges to solve before for the perl version that can be installed is "bare" and many modules are needed, some of them are not pure perl, so it would mean compilation and based on the many processors this company had for 10 years this is not so easy.
If I can find someone with experience on running perl on synology or from a given directory that would help me speed out things for Synology.
Seems to work now! super!
some temperature sensors (the raspberry mainboard for example) don't have a temperature graph available.
"no data for specified timeframe" but other sensors seems to have no issues ..
is this something locally in my phone or do you have any idea?
DRuw wrote:Seems to work now! super!
well this is to be investigated, the domoticz device mapping can be tricky !
That simple huh
Tried it... didn't work
Graphs work for my temp/hum sensors but the motherboard temp sensor, loose temperature (no humidity) or on/off switches don't.
Temps show "no data available" and switches simply don't respond to a press on the icon.
I havent made any changes to the directory except the updates you indicated.
DRuw wrote:That simple huh
last corrections were for the automatic startup/shutdown, nothing has evolved for a bit because of this critical issue.
DRuw wrote:Graphs work for my temp/hum sensors but the motherboard temp sensor, loose temperature (no humidity) or on/off switches don't.
ps: this is the same as before the git pul btw
well that is not normal, if you reboot your system do you have the same issue ?
Also are you using the dev version of domoticz or the stable one ? and if the dev which one ?
Nope, after reboot same issue.
running 2.3295 and just updated to 2.3353 (issue remains)
Beta verstion.
Graphs available on the web interface btw so it is logging...
DRuw wrote:Nope, after reboot same issue.
Beta verstion.
Hello Pierre,
I'm using the ImperiHome Pro version on my Android phone and its working fine, but now I'm trying to get 2 different raspberry's with domoticz on it to install into the same ImperiHome Pro version.
One system is in Holland and the other is in Spain. Of course they both have an different network range.
When I do the install there is no warning or error in it, but when I trying to setup the ImperiHome it's telling me that the system is already there.(MyDomoAtHome)
I renamed the first install in 'domo240' and try to install the second one.
At that moment the system is telling me that the systeem name MyDomoAtHome is already there.
What I'm doing wrong ?
I also tried with other names or path but it is still coming with the same answer.
Can you help me out?
V3.9460(beta)
2 x RPI (remote) B 2.0 512MB
2 x RPI (remote) B+ 512MB
2 x RPI (remote) 2B 1024MB
2 x PiFace 2 - 1 x RFXtrx433E Firmware 1024 - 4 x RFLink_r48 - 3 x RFLink_r48 - RFLink Gateway
3 x Action (Impuls) - 2 x AMST606 - 9 x MySensors
kabouter wrote:Hello Pierre,
If i remember correct; edit 'MyDomoAtHome.sh' and change -NAME="MyDomoAtHome" at line 17 before you run 'run-once.sh'
ESXi/Ubuntu - Z-wave.me USB Stick - Domoticz Beta - EvoHome - Nest Protect - Logitech Media Server - Netatmo Weather Station - Everspring - Aeonlabs
That's what I already did, but that did not help.
I did already changed that in domo240 and he's still coming with MyDomoAtHome already exist ... very strange
V3.9460(beta)
Did you tried to change the name in the config.yml -> appname: "MyDomoAtHome"
Beta verstion.
