ELV Max! Heating control system
l0gic
Domoticz version: Latest
Re: ELV Max! Heating control system
Post by l0gic »
Hi BD65,
this is my second heating season with the system.
So far, so good.
It works fine stand alone, but MaxBuddy adds the integration into Domoticz.
It's a shame that MaxBuddy has been abandoned but it does do a reasonable job.
For the price it fits the bill.
ATB
Kevin
Non credus crepitus
roman1528
Domoticz version: lat.beta
Post by roman1528 »
Hi there.
Since maxbuddy website is down i can't set it up on my raspberrypi. can anyone upload his running package with all files needed so i just have to create the autorun and maybe the chmods ??
would be very nice... thanks a lot
Raspberry Pi 2 Model B,
RFLink Gateway,
'OBI' RF Outlets,
some DS18B20 1-wire Temp.Sensors,
TSL2561 I2C Luminosity Sensor (not working at all)
joostvanderlinde
Domoticz version: 2023.2
Post by joostvanderlinde »
Domoticz on BPI-M2-Pro (compiled on Ubuntu 22.04) and RPI (binary on Raspian 10)
RFXCom, Sonoff Zigbee stick, eBusd Adapter 5, P1, S0, Husdata H60 integration
Zigbee2MQTT AD, MQTT local, AirconWithMe, Ebusd, VolvoRecharge, PSA Car Controller
roman1528
Post by roman1528 »
got it working^^
thanks
RFLink Gateway,
'OBI' RF Outlets,
Skippiemanz
Domoticz version: 4.10233
Post by Skippiemanz »
Kevin,
Are you making some progress? Iám trying to run the maxbuddy on my synology but unfortumed not very lucky untill now..
Hope to get it sorted out.
roman1528
Post by roman1528 »
Once back to the Domoticz.js script for Max!Buddy software ...
i'm running all the things on my raspberry pi 2 and i got it working perfectly two days ago...
whatever happended i had to do a clean install with new sd-card image... set up domoticz, set up maxbuddy ... both working fine ...
but the Domoticz.js in maxbuddy doesn't anymore... it just print the following in maxbuddy log file:
[2015-10-16 12:39:11,364] [DEBUG]: executeScript(Domoticz.js)
[2015-10-16 12:39:11,633] [DEBUG]: Script debug (Domoticz.js): Start run()
[2015-10-16 12:39:11,773] [DEBUG]: Script debug (Domoticz.js): Room  = Wohnzimmer
[2015-10-16 12:39:11,785] [DEBUG]: Script debug (Domoticz.js): Mode  = MANUAL
[2015-10-16 12:39:11,879] [DEBUG]: Script debug (Domoticz.js):    Device = Fensterkontakt rechts
[2015-10-16 12:39:11,884] [DEBUG]: Script debug (Domoticz.js):    SerialNumber = LEQ1073084
[2015-10-16 12:39:11,886] [DEBUG]: Script debug (Domoticz.js):
[2015-10-16 12:39:11,916] [DEBUG]: Script debug (Domoticz.js):    Device = Wandthermostat
[2015-10-16 12:39:11,918] [DEBUG]: Script debug (Domoticz.js):    SerialNumber = LEQ1152239
[2015-10-16 12:39:11,919] [DEBUG]: Script debug (Domoticz.js):
[2015-10-16 12:39:11,922] [DEBUG]: Script debug (Domoticz.js):    Device = Thermostat
[2015-10-16 12:39:11,930] [DEBUG]: Script debug (Domoticz.js):    SerialNumber = KEQ0991634
[2015-10-16 12:39:11,932] [DEBUG]: Script debug (Domoticz.js):
[2015-10-16 12:39:11,940] [DEBUG]: Script debug (Domoticz.js): Room  = Schlafzimmer
[2015-10-16 12:39:11,943] [DEBUG]: Script debug (Domoticz.js): Mode  = AUTO
[2015-10-16 12:39:11,946] [DEBUG]: Script debug (Domoticz.js):    Device = Thermostat
[2015-10-16 12:39:11,947] [DEBUG]: Script debug (Domoticz.js):    SerialNumber = KEQ0344922
[2015-10-16 12:39:11,948] [DEBUG]: Script debug (Domoticz.js):
[2015-10-16 12:39:11,950] [DEBUG]: Script debug (Domoticz.js):    Device = Fensterkontakt rechts
[2015-10-16 12:39:11,951] [DEBUG]: Script debug (Domoticz.js):    SerialNumber = JEQ0608068
[2015-10-16 12:39:11,953] [DEBUG]: Script debug (Domoticz.js):
[2015-10-16 12:39:11,955] [DEBUG]: Script debug (Domoticz.js):    Device = Wandthermostat
[2015-10-16 12:39:11,956] [DEBUG]: Script debug (Domoticz.js):    SerialNumber = LKF0026366
[2015-10-16 12:39:11,957] [DEBUG]: Script debug (Domoticz.js):
[2015-10-16 12:39:11,965] [DEBUG]: Script debug (Domoticz.js): Room  = Bad
[2015-10-16 12:39:11,967] [DEBUG]: Script debug (Domoticz.js): Mode  = AUTO
[2015-10-16 12:39:11,969] [DEBUG]: Script debug (Domoticz.js):    Device = Thermostat
[2015-10-16 12:39:11,972] [DEBUG]: Script debug (Domoticz.js):    SerialNumber = KEQ0992947
[2015-10-16 12:39:11,973] [DEBUG]: Script debug (Domoticz.js):
[2015-10-16 12:39:11,977] [DEBUG]: Script debug (Domoticz.js):    Device = Fensterkontakt rechts
[2015-10-16 12:39:11,983] [DEBUG]: Script debug (Domoticz.js):    SerialNumber = LEQ1157609
[2015-10-16 12:39:11,989] [DEBUG]: Script debug (Domoticz.js):
[2015-10-16 12:39:11,991] [DEBUG]: Script debug (Domoticz.js):    Device = Wandthermostat
[2015-10-16 12:39:11,992] [DEBUG]: Script debug (Domoticz.js):    SerialNumber = LKF0026190
[2015-10-16 12:39:11,993] [DEBUG]: Script debug (Domoticz.js):
[2015-10-16 12:39:11,998] [DEBUG]: Script debug (Domoticz.js): Room  = Küche
[2015-10-16 12:39:11,999] [DEBUG]: Script debug (Domoticz.js): Mode  = AUTO
[2015-10-16 12:39:12,001] [DEBUG]: Script debug (Domoticz.js):    Device = Thermostat
[2015-10-16 12:39:12,002] [DEBUG]: Script debug (Domoticz.js):    SerialNumber = JEQ0618718
[2015-10-16 12:39:12,003] [DEBUG]: Script debug (Domoticz.js):
[2015-10-16 12:39:12,005] [DEBUG]: Script debug (Domoticz.js):    Device = Fensterkontakt rechts
[2015-10-16 12:39:12,008] [DEBUG]: Script debug (Domoticz.js):    SerialNumber = LEQ1156849
[2015-10-16 12:39:12,010] [DEBUG]: Script debug (Domoticz.js):
[2015-10-16 12:39:12,015] [DEBUG]: Script debug (Domoticz.js):    Device = Wandthermostat
[2015-10-16 12:39:12,017] [DEBUG]: Script debug (Domoticz.js):    SerialNumber = LEQ1152452
[2015-10-16 12:39:12,019] [DEBUG]: Script debug (Domoticz.js):
[2015-10-16 12:39:12,025] [DEBUG]: Script debug (Domoticz.js): Room  = Büro
[2015-10-16 12:39:12,026] [DEBUG]: Script debug (Domoticz.js): Mode  = AUTO
[2015-10-16 12:39:12,028] [DEBUG]: Script debug (Domoticz.js):    Device = Thermostat
[2015-10-16 12:39:12,029] [DEBUG]: Script debug (Domoticz.js):    SerialNumber = KEQ0993833
[2015-10-16 12:39:12,030] [DEBUG]: Script debug (Domoticz.js):
[2015-10-16 12:39:12,032] [DEBUG]: Script debug (Domoticz.js):    Device = Fensterkontakt rechts
[2015-10-16 12:39:12,033] [DEBUG]: Script debug (Domoticz.js):    SerialNumber = LEQ1156889
[2015-10-16 12:39:12,034] [DEBUG]: Script debug (Domoticz.js):
[2015-10-16 12:39:12,036] [DEBUG]: Script debug (Domoticz.js):    Device = Wandthermostat
[2015-10-16 12:39:12,037] [DEBUG]: Script debug (Domoticz.js):    SerialNumber = LKF0026362
[2015-10-16 12:39:12,039] [DEBUG]: Script debug (Domoticz.js):
[2015-10-16 12:39:12,042] [DEBUG]: Script debug (Domoticz.js): Room  = Wärmeunterbett
[2015-10-16 12:39:12,043] [DEBUG]: Script debug (Domoticz.js): Mode  = AUTO
[2015-10-16 12:39:12,045] [DEBUG]: Script debug (Domoticz.js):    Device = Zwischenstecker 1
[2015-10-16 12:39:12,046] [DEBUG]: Script debug (Domoticz.js):    SerialNumber = KEQ9016681
[2015-10-16 12:39:12,047] [DEBUG]: Script debug (Domoticz.js):
two day ago it printed links with the code for domoticz... now there is nothing and no new devices in domoticz.
Yes the script is activated in maxbuddy... Yes the HID, IP and PORT in Domoticz.js are set correctly... and yes in domoticz new devices are accepted... domoticz is latest beta (with latest stable it does not start on port 80) and maxbuddy is 9.16.2 with 1.4.1 libraries...
can anyone help me with that issue?
RFLink Gateway,
'OBI' RF Outlets,
blackdog65
Post by blackdog65 »
Well... my Max! equipment arrived 30 mins ago :D looks like a fun weekend ahead :lol:
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
l0gic
Post by l0gic »
Skippiemanz wrote:Kevin,
Hi Skippiemanz,
yeah mine is running fine.
I have the core domoticz script to populate the domoticz items.
I also have a battery monitor that I run a couple of times a day to email me if an EQ-3 item has a failing battery.
Plus I also run a monitor to keep an eye on a dummy Domoticz switch for when my log burner is on. If it is I force all radiators to ON irrespective of the standard heating requirements.
All mine are running on Windows rather than a Pi.
All the best
Kevin
Non credus crepitus
blackdog65
Hi guys,
I got my new equipment running. It appears that the manufacturers software will run either local or online... but not both. Is that correct or have I fluffed it at the 1st hurdle :oops: :lol:
I in the process of installing maxbuddy which has been a pain as I'm on a cubietruck so slightly different. I have apache 2.4 so different again :evil: but getting there slowly.
I'm at the point of running maxbuddy headless but it doesn't create the hidden file .maxbuddy :cry:
so I'm stuck and don't know how to proceed from there
any ideas?
Sean
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
l0gic
Post by l0gic »
Hi Sean,
not sure what you mean with local/online?
Are you talking about the Max! software?
This runs on a PC and throws up a web page to set up the cube. I guess there are other flavours too.
You should be able to set up an on line account and configure the cube locally.
Once you have set up the user/password on line and the cube has "rung home" you will be able to set the cube up either way.
On line changes take some time to propagate back to the cube I've noticed.
Once you have Max!Buddy installed you will need to shut down the Max! software (or vice versa) as only one connection is allowed to the cube at a time.
You're getting there :)
Kevin
Non credus crepitus
blackdog65
Hi Kevin,
Yes I was referring to the Max! software, It seams that If I log into the web page on localhost I have issues with https://max.eq-3.de and vice versa... but
makes perfect sense :roll: should have seen it :lol:
Soooo... all instances of Max! software closed but the problem remains. If I run headless.sh no .maxbuddy is created. I'm rebooting my cubietruck and trying a few other options but no luck yet :(
Sean
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
blackdog65
AHHHHH! :o found it!
.maxbuddy has been created in the "root" folder. This must be because I'm using a cubietrck and not a Pi.
So my options/questions are
a) Edit ext-libs where it is (as Root) and all will be well
b) Move .maxbuddy (and change ownership etc) to user home
c) Start again as root
D) Other ;)
As you can see, I'm getting out of my depth rapidly now :oops:
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
blackdog65
Hmmmm... previous post somewhat moot as the ext-libs folder in root is empty.
Now I'm stuck :cry:
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
l0gic
Post by l0gic »
Hi Sean,
Have you followed the instructions that come with the code?
It's a bit of a pain but it was I had to do to get it working.
If you don't have them I can post it up here.
Kevin
Non credus crepitus
blackdog65
No mate,
I've been following Skippiemanz instructions in this thread.
I'd much appreciate it if you could post them.
Another thought is that I could go through the process on a spare raspi and have it as a slave to the cubietruck. Not the most elegant solution, but a solution... maybe :D
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
Skippiemanz
Going through the same struggle as you when trying to set it up on my synology nas. Unfortunately not an Linux expert
l0gic
Post by l0gic »
Sean,
just checked, my instructions are for Windows only.
I'll post them up as it may give you a lead.
MAX! Buddy running with the new libraries yet, but the links have to download the latest libraries from the manufacturer eQ-3 and vonELV removed so that MAX! Buddy the required libraries currently can not download directly. Therefore, the error message
Errors on Startup: Failed to download required libraries.
However, it is possible to get MAX Buddy R9.16.2 and R9.17-beta2 to run:
1. Download the following files:
MaxEssentialsBackend-1.4.1.jar
MaxLocalBackend-1.4.1.jar
digest.txt
2. This must for Windows XP users to folder
C: \ Documents and Settings \ <username> \ Application Data \ MAXBuddy \ ext-libs \ u \ 57840205 \ Libs1-4-1 \
be copied.
For Windows 7 users please to folder:
C: \ Users \ <username> \ AppData \ Roaming \ MAXBuddy \ ext-libs \ u \ 57840205 \ Libs1-4-1 \
copy.
WIndows 8 users copy the files into the directory:
3. The modified file left-916.xml
need for Windows XP users to folder
and for Windows 7 users to folder
All use the Windows 8, please to folder:
copy.
Then, very important to enable the write protection on the file, otherwise the file will be overwritten.
4. MAX! Start Buddy R9.16.2 as usual.
5. Do you use MAX! Buddy R9.17 beta2 need your modified file left-914.xml use. The 1st to 4th steps remain the same.
All MAX! Buddy versions you can find here and here .
Should you have problems just report briefly here in the forum.
Greeting
Matze
Hope that helps
Kevin
Non credus crepitus
roman1528
Post by roman1528 »
l0gic wrote: yeah mine is running fine.
0.0 yay? :-D
nice to hear^^
have testet two other home automations on my pi supportin MAX by default. But both are very hard to configure... AND they don't know what the RFLink Gateway is :-D Mine is arrived few days ago.
in both (openhab and fhem) the MaxCube and other Max Devices are accessed directly (over Cube). Have here the scripts and programs for that... see attachement. maybe there is anyone out who understand whats in the files... I only see ???????
i hope there will be an update soon with controlling MAX...
good evening
fhem_MAX_MAXLAN__openhab_maxcube_jar.zip
openhab jar maxcube binding
(77.57 KiB) Downloaded 198 times
roman1528
Post by roman1528 »
roman1528 wrote:Once back to the Domoticz.js script for Max!Buddy software ...
hey guys... any ideas? maybe a library for json or java is missing on pi?? if yes... wich library? pls help.
RFLink Gateway,
'OBI' RF Outlets,
roman1528
Post by roman1528 »
anyone? no? nice community... really...
why the script not working anymore? it seems the script can't get the DeviceType... but why?
this thread is dead allready... nobody want to get working his max system in domoticz?
RFLink Gateway,
'OBI' RF Outlets,
