domoticz in synology as package! Available now.
cbe78
Post by cbe78 »
Work perfectly on my DS213J (first try --> OK)
Many thanks for the work
mvveelen
Post by mvveelen »
V2.3256 is doing great on my DS414 (armadaxp). Updated this morning and no crashes or errors. Thanks for the package, Jumbotroll !
RPi3b+/RFXCOM rfxtrx433E/Shelly/Xiaomi Gateway/Philips HUE Lights/Atag Zone One/2 SunnyBoy inverters/AirconWithMe/P1 smartmeter/Domoticz latest Beta
Flyer
Post by Flyer »
Hello!
I would like update domoticz from manual install packages. It's possible? Befor update I must to be uninstall the ols version?
tks in advances
Flyer
mvveelen
Post by mvveelen »
Why wouldn't you just update using the Package Center?
If there is some reason why you don't want to use the PC, download the package from Jadahl's server (http://jadahl.dscloud.me/sspks/index.php?fulllist=true) and install it. And yes, you can use it to upgrade the current version. And no, don't uninstall the current version. You could make a backup of the DB before updating, just to be sure.
Flyer
Post by Flyer »
Tks you for your fast reply!
I've install from packages center all OK!
bye
Flyer
pipitch
Post by pipitch »
I have some X10 switches and I dont know how to install mochad inside the synology.
Anyone have a solution ?
mvveelen
Post by mvveelen »
pipitch wrote:Hello,
You might want to open an new topic for this question.....
Moppersmurf
Domoticz version: Lat.Beta
Post by Moppersmurf »
Jumbotroll, just a word of thanks for the updates
wboerhoop
Post by wboerhoop »
Hello Jumbotroll, i'm glad with the new versions you compile for the synolgy,but i have a small problem automatic updates through packet centre.
Every update i the directory "/var/packages/domoticz/target/www/images/floorplans" is empty again. i'm using floorplans, so everytime i have to copy them manualy from a copy.
Can you change that.
Thanks.
RFXcom-433E last FW
Aeon Z-stick Gen5
Zigbee
Synology and Raspberry Pi4 last Beta
jumbotroll
Post by jumbotroll »
wboerhoop wrote:Hello Jumbotroll, i'm glad with the new versions you compile for the synolgy,but i have a small problem automatic updates through packet centre.
Thanks.
EDIT:
/floorplans folder are now backed up and restored in my latest (v2.3299) Synology builds when updating :)
Jumbotroll
https://paypal.me/Jumbotroll
Jumbotroll
http://www.jadahl.com
wboerhoop
Post by wboerhoop »
Jumbotroll
Installed the latest version V2.3299 and worked as expected.
Thanks for the quick response.
Willem
RFXcom-433E last FW
Aeon Z-stick Gen5
Zigbee
jumbotroll
Update!
Domoticz V2.3338.
New:
OpenZWave 1.3.500 (tested and found ok)
/floorplans folder are now backed up and restored when updating. (tested and found ok)
Jumbotroll
Jumbotroll
datzmazzie
Domoticz version: 2.3430
Post by datzmazzie »
Thnx. Updated and still working.
Raspberry Pi 3B, Arduino Mega, RFLink
My Blog
postman976
Post by postman976 »
I have a question regarding adding hardware.
I want to control my X10 interface device (CM15pro bridge) over USB. For now only the LAN interface version is present.
Can someone add this device feature?
Best regards,
Albert
gizmocuz
Post by gizmocuz »
maybe.... you could install 'ser2net' and bridge a tcp port to usb ?
(Dont know if this is possible on the synology, and if the commands are the same for usb)
mvveelen
Post by mvveelen »
Hi Jumbotroll, I guess you now have Z-Wave hardware so you can test before releasing the packages? The last few updates work flawlessly. Thanks for the regular updates :) !
jumbotroll
mvveelen wrote:Hi Jumbotroll, I guess you now have Z-Wave hardware so you can test before releasing the packages? The last few updates work flawlessly. Thanks for the regular updates :) !
I have borrowed some fibaro units and a z -stick from a friend , I test OpenZWave before I upload new versions of domoticz :-)
Jumbotroll
Jumbotroll
jumbotroll
Update
Domoticz V.2.3397
https://github.com/domoticz/domoticz/commits/master
New
OpenZWave Version: 1.3.513.
Jumbotroll
Jumbotroll
Eternity
Post by Eternity »
ISSUE SOLVED!
It was a router setting that was blocking Domoticz to connect to external souces. I found out after seeing that email notifications were also not getting thru. ALtering the block in my router solved the problems.
I am running v2.3350 on my DS214plus Synology NAS.
I don't think I changed anything, but all of a sudden I have issues connecting from within Domoticz to external sources:
- ThermoSmart
- Harmony Hub
- Winddelen
And see the following errors (page after page):
2015-10-20 14:49:09.779 Error: Winddelen: Error connecting to: http://backend.windcentrale.nl/windcent ... ie_121.txt
2015-10-20 14:49:10.558 Error: Thermosmart: Error login!
2015-10-20 14:49:20.858 Error: Harmony Hub: Logitech web service login failed.
If i use a browser to login to Logitech, Winddelen or Thermosmart the credentials I use are accepted.
What can I do to solve this?
Last edited by Eternity on Thursday 22 October 2015 11:38, edited 1 time in total.
Synology DS218+
Homey controller
Z-Wave stuff (Fibaro / Aeotec / NEO Coolcam)
Zigbee stuff (Aqara)
HUE lights
Logitech Harmony Ultimate + Hub
IP camera's
amz4u2nv
Post by amz4u2nv »
I've upgraded to the latest version and can see domoticz running on the nas drive.
But when I try to login via the interface it says domoticz is offline.
Any ideas how I can solve this issue.
