domoticz in synology as package! Available now.
- jumbotroll
There is some changes in source "Kodi backend moved to asynchronous"
https://github.com/domoticz/domoticz/co ... 686228a87e
Jumbotroll
Jumbotroll
https://paypal.me/Jumbotroll
Jumbotroll
http://www.jadahl.com
Jumbotroll
- Target OS: -
The package works great on my DS412+. Only thing is that it stops regularly. I made a task in the scheduler that the package starts every hour. That works for now. More ppl with this issue?
DS412+ Aeotec Z-Stick Gen5
- mvveelen
I'm using the test versiin for the armadaxp, with the previous OpenZWave and that version hasn't crashed so far.
RPi3b+/RFXCOM rfxtrx433E/Shelly/Xiaomi Gateway/Philips HUE Lights/Atag Zone One/2 SunnyBoy inverters/AirconWithMe/P1 smartmeter/Domoticz latest Beta
- jumbotroll
@mvveelenmvveelen wrote:I'm using the test versiin for the armadaxp, with the previous OpenZWave and that version hasn't crashed so far.
In that test version I did roll back OpenZWave to V. 1.3.482.
Seems that V 1.3.482. is more stable, so in next domoticz update for synology I will use that version of OpenZWave.
@timovd
I'm using domoticz on DS712+ and never had any problem, but I don't use OpenZWave.
Do you also use OpenZWave?
Jumbotroll
Jumbotroll
Jumbotroll
- mvveelen
If you put up the donation link.....you could eventually buy some ZWave hardware and test it yourself
And then you can upgrade the OpenZWave too if all tests are OK
- jumbotroll
He he. The donation link has been there for some time! http://www.jadahl.com.mvveelen wrote:If you put up the donation link.....you could eventually buy some ZWave hardware and test it yourself![]()
Jumbotroll
Jumbotroll
Jumbotroll
- mvveelen
Doh !
Well, at least now all others that are viewing this thread know about the donation button, so guys : Donate and help Jumbotroll get some ZWave hardware so he can test the OpenZWave himself before updating the packages. And also....for the effort, a donation would be very nice.
10 euro's from me coming your way in a few minutes !
- mvveelen
Is someone else having the same issues with the lua scripts : I'm not seeing any lua script triggered anymore in the logfile. Normally I see entries every minute (at least), but not anymore.
Edit:
Seems to work after uninstalling and installing the whole Domoticz package.
Edit:
Hi Jumbotroll,
Thanks for the package! Really awesome
. Currently I am experiencing this problem: http://www.domoticz.com/forum/viewtopic.php?f=6&t=8191. Apparently a new version with a fix is available. If you could maybe find the time to update the package with this fix, I would really appreciate it!
Kind regards!
Kind regards!
- jumbotroll
Update is on the wayspes9 wrote:Hi Jumbotroll,
Thanks for the package! Really awesome. Currently I am experiencing this problem: http://www.domoticz.com/forum/viewtopic.php?f=6&t=8191. Apparently a new version with a fix is available. If you could maybe find the time to update the package with this fix, I would really appreciate it!
Kind regards!
Fixed PhilipsHue (when using new firmware) Domoticz v2.3191
What synology do you have?
Jumbotroll
Jumbotroll
Jumbotroll
- Domoticz version: 4.10233
Donation on its way, can't wait to test your new beta with the Logitech media server included.
Great, thank you!! I have a DS212j.jumbotroll wrote:Update is on the wayspes9 wrote:Hi Jumbotroll,
Kind regards!![]()
Jumbotroll
- jumbotroll
UPDATE
Domoticz V2.3202
This version is updated with OpenZWave 1.3.488
https://github.com/OpenZWave/open-zwave/commits/master
http://jadahl.dscloud.me/sspks/index.php?fulllist=true
Jumbotroll
Domoticz V2.3202
Jumbotroll
Jumbotroll
Jumbotroll
- mvveelen
If anyone is using this version with OpenZWave and finds it not crashing: please share your findings
I'll wait for a little while this time.
- jumbotroll
I think your prev crash was due Kodi crash in V2.3187.mvveelen wrote:If anyone is using this version with OpenZWave and finds it not crashing: please share your findingsI'll wait for a little while this time.
There were no others reported problems with OpenZWave 1.3.487 .
http://www.domoticz.com/forum/viewtopic.php?f=6&t=8214
OpenZWave 1.3.488 running stable on another platforms as far as I know.
But if there is much work to roll back to the previous version , then maybe let someone else test first
Jumbotroll
Jumbotroll
Jumbotroll
wrong place
- mvveelen
@Sandman79: could you start a new topic with your question(s) ? This is kinda offtopic in this topic.
I hope this question is placed a bit better here:
I was trying to add a virtual weather device following this wikipage: http://www.domoticz.com/wiki/Virtual_weather_devices
However the page points to a location on a raspberry pi (i suppose) which doesn't exist on a synology:
Go to /home/pi/domoticz/scripts/lua/ and create a new file, named 'script_device_sensorWU.lua'.
Am I Correct that on the synology it would be this location: /volume1/@appstore/domoticz/scripts/lua ?
The directories scripts/lua do not yet exist on my synology, that's why i am asking,? Just create them?
- G3rard
- Target OS: -
- Domoticz version: No
The directory for lua scripts is domoticz/var/scripts/lua.
Not using Domoticz anymore
