epierre wrote:DRuw wrote:Hi all,
I have some issues with getting my domoticz correctly in Imperihome..
for some reason, all items go to a folter called weather, also switches etc.
Any Idea how to fix this?
can you explain a little bit more your issue ? there is a mapping from Domoticz so that items go to the same forlder as domoticz.
Yeah and that looks like the thing thats not working.
In Domoticz, switches are at switches etc. but in Imperihome, all items from domoticz go to a single tab called weather...
my ip/port/devices output is this:
{"devices":[{"params":[{"unit":"","value":"0.12","graphable":"false","key":"Value"}],"name":"MyDomoAtHome","type":"DevGenericSensor","id":"S0"},{"params":[{"unit":"°C","value":"37.9","graphable":"true","key":"Value"}],"name":"Temp MasterPi","id":"4","type":"DevTemperature","room":"Temp"},{"params":[{"unit":"°C","value":"13.2","graphable":"true","key":"temp"},{"unit":"%","value":"95","graphable":"true","key":"hygro"}],"name":"Voorspelling","id":"12","type":"DevTempHygro","room":"Temp"},{"params":[{"unit":"mbar","value":"1015","key":"Value"}],"name":"Voorspelling","type":"DevPressure","id":"12_1","room":"Temp"},{"params":[{"unit":"km/h","value":"2","graphable":"true","key":"Speed"},{"unit":"°","value":"208","key":"Direction"}],"name":"Huidig weer","type":"DevWind","id":"13","room":"Temp"},{"params":[{"value":"0.0","graphable":"true","key":"Value"}],"name":"UV","type":"DevUV","id":"14","room":"Temp"},{"params":[{"unit":"mm","value":"2.0","graphable":"true","key":"Accumulation"},{"unit":"mm/h","value":"0.0","key":"Value"}],"name":"Regen","type":"DevRain","id":"15","room":"Temp"},{"params":[{"unit":"km","value":"10.0","key":"Value"}],"name":"Zicht","type":"DevGenericSensor","id":"16","room":"Temp"},{"params":[{"unit":"°C","value":"42.2","graphable":"true","key":"Value"}],"name":"SlavePi Temp","id":"26","type":"DevTemperature","room":"Temp"}]}
any idea?
ps: I also don't get the first item with the value 0.12? don't have anything with that value
pps: that 0.12 thing goes to a "no room" group and the rest goes to weather
