Logitech Media Server
pvm
- Domoticz version: 4.10538
Re: Logitech Media Server
Updated, working fine with these improvements, though I still have the issue with the left and right buttons (often) not working. Is there anything I can do to help? I'm running this on a spare/test PI, have some possibilities to perform tests.
It just sends the remote commands directly, it works ok with my sb3. If it does not work from Domoticz, does it work ok from your sb-remote? Can you tell me in which menu it does not work?pvm wrote:Updated, working fine with these improvements, though I still have the issue with the left and right buttons (often) not working. Is there anything I can do to help? I'm running this on a spare/test PI, have some possibilities to perform tests.
pvm
I've seen it in multiple menus, infrared remote worked fine. One example press browse music button, left and right do not work, when pressing right on my remote it shows the first artist. At that time pressing left or right in Domoticz do not work, the remote does work however.
New version available.
Fixed know issue:
* Artists starting with a number (10CC etc.) will display an extra text 'Level xx%' after the titles
Fixed know issue:
Found the issue; will be fixed in new version. I have to split play/pause also to use 'play' as select; Does not work now, because it's using 'pause' now...pvm wrote:I've seen it in multiple menus, infrared remote worked fine. One example press browse music button, left and right do not work, when pressing right on my remote it shows the first artist. At that time pressing left or right in Domoticz do not work, the remote does work however.
New version available:
* Fixed issue with left/right buttons.
* Had to split play/pause to use 'play' as select.
Don't forget to flush browse-cache.
Have fun!
Have fun!
pvm
just updated and rebuild
2 layout / design things:
in IE 11 the design is not so nice as in Chrome (dark colors, scrollbars) in Chrome upon opening the popup with controls there's a strange default selection at the right top
- cyberclwn
- Domoticz version: 2024.4
Hey,pvm wrote: 2 layout / design things:
I don't think that's an issue with this plug and for Eduard, because the remote on the KODI-mediaplayer has the same issues.
So guess it is for the designer/developer of the remotecontrol-bit.
(I just checked it with IE11, because i don't normally use it)
3xPi 2B (Domoticz "live", Domoticz "sandbox", PhotoFrame)
RFXCom433(E), KaKu, Oregon Scientific, Keyes 2-relay, Logitech Media Server, MiLight, Smartwares heating controller(2x), IR Send/Receive, Keyes PIR, XH-M131 DuskSensor, DHT22/11
pvm
Ah, ok, clear a more generic issue.
Firefox just works
PS.: If no issues found in this version, i will make a pull-request to add it to the next Domoticz-beta tomorrow
Can you please provide me your icons? I will try to replace the media-icon with a better one.cyberclwn wrote:I have a .zip with the user icon's, or how it is called in english ("Aangepaste pictogrammen", in dutch) if you want those.
Thnx
- cyberclwn
Here you goEduard wrote:Can you please provide me your icons? I will try to replace the media-icon with a better one.cyberclwn wrote:I have a .zip with the user icon's, or how it is called in english ("Aangepaste pictogrammen", in dutch) if you want those.
Thnx
- squeeze.zip
- (8.9 KiB) Downloaded 150 times
pvm
I tried changing the default icons based on this branch yesterday
... however I did not manage
I'll check your commit when ready, wonder what I was missing...
Would be nice to have this icon set as default for LMS
- cyberclwn
What went wrong then ?pvm wrote:I tried changing the default icons based on this branch yesterday... however I did not manage
You can change them easily:
Go to setup (Instellingen) / More Options (Meer Opties) / Custom icons (aangepast pictogrammen)
Click on "Choose File", and browse to where you put the squeeze.zip and select it. Then click on "Add" (Toevoegen) and wait for the icon to show up in the big white space above.
Next go to switches (schakelaars) and select modify (aanpassen). Click the pulldown-button next to switch icon (Schakelaar icoon) and look for the Squeezebox-logo. Click it and then click save (opslaan)
That should do the trick.
But i think it should be included, yes.
You can change them now, or wait for the next beta; i will include them indeedcyberclwn wrote:What went wrong then ?pvm wrote:I tried changing the default icons based on this branch yesterday... however I did not manage
- cyberclwn
You're the bestEduard wrote:i will include them indeed
New version available!
New:
* Includes icons now (thnx cyberclwn!)
Also up-to-date with Domoticz-beta-branch
I will add a pull-request today to add it to the Domoticz-master-branch...
Thanx for your suggestions & tests (so far)
[EDIT] Pull request just merged; will be available in next Domoticz beta
New:
rron
Hello Eduard,
Thx, it's working perfect!
pvm
The icon just finishes it, top, thnx!
(checked your implementation, I was thinking about adding a new type instead of re-using the mediaplayer. Yours is a lot simpeler, should have thought of this...)
Skippiemanz
- Domoticz version: 4.10233
Can't wait till this beta comes to the synology version. Good job.
Users browsing this forum: palnic and 1 guest
