Logitech Media Server
pvm
Domoticz version: 4.10538
Re: Logitech Media Server
Post by pvm »
Updated, working fine with these improvements, though I still have the issue with the left and right buttons (often) not working. Is there anything I can do to help? I'm running this on a spare/test PI, have some possibilities to perform tests.
Eduard
Post by Eduard »
pvm wrote:Updated, working fine with these improvements, though I still have the issue with the left and right buttons (often) not working. Is there anything I can do to help? I'm running this on a spare/test PI, have some possibilities to perform tests.
It just sends the remote commands directly, it works ok with my sb3. If it does not work from Domoticz, does it work ok from your sb-remote? Can you tell me in which menu it does not work?
pvm
Post by pvm »
I've seen it in multiple menus, infrared remote worked fine. One example press browse music button, left and right do not work, when pressing right on my remote it shows the first artist. At that time pressing left or right in Domoticz do not work, the remote does work however.
Eduard
Post by Eduard »
New version available.
Fixed know issue:
* Artists starting with a number (10CC etc.) will display an extra text 'Level xx%' after the titles
Eduard
Post by Eduard »
pvm wrote:I've seen it in multiple menus, infrared remote worked fine. One example press browse music button, left and right do not work, when pressing right on my remote it shows the first artist. At that time pressing left or right in Domoticz do not work, the remote does work however.
Found the issue; will be fixed in new version. I have to split play/pause also to use 'play' as select; Does not work now, because it's using 'pause' now...
Eduard
Post by Eduard »
New version available:
* Fixed issue with left/right buttons.
* Had to split play/pause to use 'play' as select.
Don't forget to flush browse-cache.
Have fun!
pvm
Post by pvm »
just updated and rebuild
2 layout / design things:
in IE 11 the design is not so nice as in Chrome (dark colors, scrollbars)
IE11
IE11
in Chrome upon opening the popup with controls there's a strange default selection at the right top
Chrome
Chrome
cyberclwn
Domoticz version: 2024.4
Post by cyberclwn »
pvm wrote: 2 layout / design things:
Hey,
I don't think that's an issue with this plug and for Eduard, because the remote on the KODI-mediaplayer has the same issues.
So guess it is for the designer/developer of the remotecontrol-bit.
(I just checked it with IE11, because i don't normally use it)
3xPi 2B (Domoticz "live", Domoticz "sandbox", PhotoFrame)
RFXCom433(E), KaKu, Oregon Scientific, Keyes 2-relay, Logitech Media Server, MiLight, Smartwares heating controller(2x), IR Send/Receive, Keyes PIR, XH-M131 DuskSensor, DHT22/11
pvm
Post by pvm »
Ah, ok, clear a more generic issue.
Eduard
Post by Eduard »
Firefox just works :P
PS.: If no issues found in this version, i will make a pull-request to add it to the next Domoticz-beta tomorrow ;)
Eduard
Post by Eduard »
cyberclwn wrote:I have a .zip with the user icon's, or how it is called in english ("Aangepaste pictogrammen", in dutch :) ) if you want those.
Can you please provide me your icons? I will try to replace the media-icon with a better one.
Thnx
cyberclwn
Post by cyberclwn »
Thnx
Here you go :)
squeeze.zip
(8.9 KiB) Downloaded 150 times
pvm
Post by pvm »
I tried changing the default icons based on this branch yesterday :geek: ... however I did not manage :oops:
I'll check your commit when ready, wonder what I was missing...
Would be nice to have this icon set as default for LMS
cyberclwn
Post by cyberclwn »
pvm wrote:I tried changing the default icons based on this branch yesterday :geek: ... however I did not manage :oops:
What went wrong then ?
You can change them easily:
Go to setup (Instellingen) / More Options (Meer Opties) / Custom icons (aangepast pictogrammen)
Click on "Choose File", and browse to where you put the squeeze.zip and select it. Then click on "Add" (Toevoegen) and wait for the icon to show up in the big white space above.
Next go to switches (schakelaars) and select modify (aanpassen). Click the pulldown-button next to switch icon (Schakelaar icoon) and look for the Squeezebox-logo. Click it and then click save (opslaan)
That should do the trick.
But i think it should be included, yes. :)
Eduard
Post by Eduard »
You can change them now, or wait for the next beta; i will include them indeed ;)
cyberclwn
Post by cyberclwn »
Eduard wrote:i will include them indeed ;)
You're the best :)
Eduard
Post by Eduard »
New version available!
New:
* Includes icons now (thnx cyberclwn!)
Also up-to-date with Domoticz-beta-branch
I will add a pull-request today to add it to the Domoticz-master-branch...
Thanx for your suggestions & tests (so far)
[EDIT] Pull request just merged; will be available in next Domoticz beta :D
rron
Post by rron »
Hello Eduard,
Thx, it's working perfect! :D
pvm
Post by pvm »
The icon just finishes it, top, thnx!
(checked your implementation, I was thinking about adding a new type instead of re-using the mediaplayer. Yours is a lot simpeler, should have thought of this...)
Skippiemanz
Domoticz version: 4.10233
Post by Skippiemanz »
Can't wait till this beta comes to the synology version. Good job.
