OpenZwave now updated to 1.3.482 with some bugfixes.
I can't be sure if this version work, because I am not able to test with Zwave stick.
This time you can roll back to prev version from my server if it's not working
Jumbotroll
Good to hear, then OpenZWave team have fixed the problemmvveelen wrote:Boom !
V2.3042 with OpenZWave 1.3.482 up and running on my DS414 (armadaxp)No crashes this time so far
/usr/bin/curl -s http://127.0.0.1:8084/backupdatabase.php > /volume1/Data/Domoticz_backup/database/domoticz.dbThanks ThinkPadThinkPad wrote:jumbotroll, maybe a nice suggestion for your packages:
Would it be possible to create a backup of the domoticz.db when a upgrade would be initiated?
I already have a script running to make backups every night, but if i would need to do a rollback (removing package, installing again) and didn't make a backup before doing, i would have lost a few hours of logging (energy for example).
Making a backup of the database is very easy actually:Maybe it can be stored in a folder inside the 'domoticz' folder (as the location used in the above code is only valid in my situation).Code: Select all
It is not very necessary (i think everyone should take his own responsibility for taking backups), but maybe it is a small effort for you to implement this. Would be a handy rescue for some people that forget backupping in the heat of the moment.
Just dropping the idea, don't feel obliged by it... would be a nice small addition, but if it is too much work/too difficult: just leave it
And about Z-Wave: you save me (and a lot of others) a lot of work by compiling these packages for us (multiple times a week!!).
I wouldn't mind giving you a small donation for that.... (did i already say i really like your effort? )
Gives you some budget to buy Z-Wave gadgets....
Domoticz version 2.3050 with OpenZWave 1.3.482 is succesfully installed here. Thanks again!jumbotroll wrote:I updated from OpenZWave 1.3.478 to 1.3.481 and 1.3.481 failed.
This time you can roll back to prev version from my server if it's not working![]()
Jumbotroll
I als have problems with the Zwave door sensors (not detecting open/close), but already for some weeks so seams to be caused by another reason. Also other ZWave nodes are working fine.mvveelen wrote:Me too, make a donation button !
Running v2.3050 here too
Edit: one thing though....since updating I haven't had any log entries when I open one of the doors with a ZWave sensor. The mesh network seems OK, I receive data from other nodes (energy, switches), but no data from the wireless door sensors.
Wow, you are fast updating, I had to delete v2.3055 because of bug in domoticz source.mvveelen wrote:The newest (v2.3055) crashes again (armadaxp). Hope you can fix this?
Is this the sensor you have problem with?mvveelen wrote:Me too, make a donation button !
Great News!mvveelen wrote:No, I have the Fibaro FGK-101 door sensors. They worked (very) well since I've got them up and running with Domoticz, but since the latest ZWave update I'm not having on/off entries in the log anymore. Don't know if this has anything to do with the latest ZWave version, but it's really annoying.
Edit: feeling stupid......
I had an RFXCOM switch that suddenly didn't work anymore and had to reboot the Synology to try and fix that. And what do you know.....it's working again AND also the doorsensors are working again. The trick was......rebooting the Synology
You have to choose another serial port (Setup - Hardware - Select the Zwave controller and then below you can change the serial port).timovd wrote: Is the stick connected well to the Synology? And am I doing the right procedure to add the dimmer?
Thanks for your help! I cannot select a serial port; the drop-down is empty.G3rard wrote:You have to choose another serial port (Setup - Hardware - Select the Zwave controller and then below you can change the serial port).timovd wrote: Is the stick connected well to the Synology? And am I doing the right procedure to add the dimmer?
The Setup button is blue when the right serial port is choosen. Your's is red now.
