FlatZ Frontpage
galadril
Domoticz version: latest
FlatZ Frontpage
Post by galadril »
:roll: Version 0.2
Please let me know if you like it and what should be added/changed??
- Upload all files to the www directory
- Adjust user settings in settings/settings.js: the URL of your domoticz, the idx and names of your switches and devices
- Open in browser [your Domoticz IP:port]/frontpage.html
Credits to Hansbit, I've used his frontpage to rework for my own!
Download:
https://github.com/galadril/FlatZ-Frontpage
Screenshots:
Settings.js
I'll try to explain more how to use the settings..
If you go to:
http://ip:port/json.htm?type=devices&jsoncallback=?
You see all devices of Domoticz in a json list.
Here you get get the idx, and value you like to show from your device and put it in the settings.js:
for example:
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "BatteryLevel" : 255,
         "CustomImage" : 0,
         "Data" : "28.65%",
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 1,
         "HardwareName" : "Motherboard",
         "HardwareType" : "Motherboard sensors",
         "HardwareTypeVal" : 23,
         "HaveTimeout" : false,
         "ID" : "0000044C",
         "Image" : "Computer",
         "LastUpdate" : "2015-09-28 08:42:53",
         "Name" : "Memory Usage",
         "Notifications" : "true",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Protected" : false,
         "ShowNotifications" : true,
         "SignalLevel" : 12,
         "SubType" : "Percentage",
         "Timers" : "false",
         "Type" : "General",
         "TypeImg" : "hardware",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "1"
Here i want to show the "Data" value onscreen:
$.PageDashboardArray = [['idx', 'from the json', 'cell7', 'description'],
becomes
$.PageDashboardArray = [['1', 'Data', 'cell7', 'Computer Memory Usage'],
The Data value then gets put in the HTML in the field with id 'cell7', and the description in desc_cel7
<div class="col-sm-3 col-lg-3">
   <div class="dash-unit">
               <dtitle id="desc_cell7" ></dtitle>
               <hr>
               <div id="woonkamer" style="height: 11.313em;width: 11.313em;margin: auto;"></div>
               <h2 id="cell7"></h2>
               <span class="text" id="cell70" style="float:right;padding-right:10px;font-size: 10px;color: #9E9E9E;"/>
    </div>
 </div>
If you want to add the lastupdatedate, then add this line to the $.PageDashboardArray:
[['1', 'LastUpdate', 'cell70', 'Computer Memory Usage'],
So the LastUpdate value from the JSON gets placed in cell70. we don't have a desc_cell70, so the description is not used.
Last edited by galadril on Monday 28 September 2015 9:12, edited 8 times in total.
jjnj
Re: FlatZ Frontpage
Post by jjnj »
Wow looks great!!!
pvm
Domoticz version: 4.10538
Re: FlatZ Frontpage
Post by pvm »
Nice, is it somehow possible to extend this into THE default and configurable ( maybe easily customizable/extendable) Domoticz interface?
Does this cover all possible devices?
galadril
Re: FlatZ Frontpage
Post by galadril »
jjnj wrote:Wow looks great!!!
Justintime
Re: FlatZ Frontpage
Post by Justintime »
What?!? Looks Awesome.
Heisenberg
Re: FlatZ Frontpage
Post by Heisenberg »
pvm wrote:Nice, is it somehow possible to extend this into THE default and configurable ( maybe easily customizable/extendable) Domoticz interface?
I couldn't agree more :)
But I do have some questions:
- The buttons are not changing status when i click on it.
- After configuring and uploading the files to folder www I go to the frontpage.html in the browser but it says 'Domoticz Offline'. When open locally it works.
Checked in Firefox and Chrome.
Raspberry Pi Type B
Raspberry Pi Type B2
RFXCOMtrx433e
galadril
Re: FlatZ Frontpage
Post by galadril »
Heisenberg wrote: - The buttons are not changing status when i click on it.
You are in the same network (not remote)?
Heisenberg wrote:- After configuring and uploading the files to folder www I go to the frontpage.html in the browser but it says 'Domoticz Offline'. When open locally it works.
Does the frontpage.html say 'Domoticz Offline'? I think that's not even in the html ....
Or do you just don't see any values?
Heisenberg
Re: FlatZ Frontpage
Yes, I'm in the same local network.
When I open the frontpage.html locally then it shows the values. But I cannot switch on/off the with the buttons
No, It looks like the frontpage.html in the www folder cannot be opened in browser
EDIT: frontpage.html works. All files should be uploaded to folder /home/pi/domoticz/www
Last edited by Heisenberg on Wednesday 30 September 2015 12:07, edited 3 times in total.
Raspberry Pi Type B
RFXCOMtrx433e
galadril
Re: FlatZ Frontpage
Post by galadril »
To bad the Domoticz JSON API doesn't include a get method for historical data of devices, but I'm looking into making a graph page for the frontpage >>
Or does anyone else know the urls for getting device history?
galadril
Re: FlatZ Frontpage
Post by galadril »
Heisenberg wrote:When I open the frontpage.html locally then it shows the values. But I cannot switch on/off the with the buttons
Maybe an authorisation issue, I'll do some tests tonight..
pj-r
Domoticz version: V3.8650
Re: FlatZ Frontpage
Post by pj-r »
galadril wrote:To bad the Domoticz JSON API doesn't include a get method for historical data of devices
What you mean by historical data? I think you can get exact the same data out from backend as the default UI since its using json for everything.
LXC(x64 Ubuntu Xenial), RFXtrx433E, MySensors
galadril
Re: FlatZ Frontpage
Post by galadril »
pj-r wrote:What you mean by historical data? I think you can get exact the same data out from backend as the default UI since its using json for everything.
Thanks for the tip. :)
I found the json calls and now also have graphs in the dashboard..
galadril
Re: FlatZ Frontpage
Post by galadril »
Also making the settings in one settings.js file.. to make our lives easy :)
Last edited by galadril on Thursday 17 September 2015 10:28, edited 1 time in total.
galadril
Re: FlatZ Frontpage
Post by galadril »
Progress update:
- Graph screen
- Logs screen (+filter input)
see screenshots, hope you like it..
jjnj
Re: FlatZ Frontpage
Post by jjnj »
Looks great! What about security? Does the Domoticz login also function for this?
galadril
Re: FlatZ Frontpage
Post by galadril »
jjnj wrote:Looks great! What about security? Does the Domoticz login also function for this?
At this moment, you have to login on the standard Domoticz dashboard before this frontpage works..
galadril
Re: FlatZ Frontpage
Post by galadril »
vil1driver wrote:$.domoticzurl = "http://<user>:<pass>@<ip>:<port>";
Thanks, i'll do!
bizziebis
Domoticz version: 3.8805
Re: FlatZ Frontpage
Post by bizziebis »
Looking forward to your new version. Looks promissing :)
galadril
Re: FlatZ Frontpage
Post by galadril »
bizziebis wrote:Looking forward to your new version. Looks promissing :)
I'll upload a new version soon.
mvveelen
Re: FlatZ Frontpage
Post by mvveelen »
Nice frontpage. I'm going to follow this topic to see what else will be implemented. Adding historical data is a big plus imho. Keep up the good work !
