[MyDomoAtHome] Support thread
- epierre
Re: [MyDomoAtHome] Support thread
please update to the latest version, the unknown devices are now hidden
ImperiHome & MyDomoAtHome on top of:
868.42Mhz - Vera Lite - Fibaro SS-101, S-211, K-101, FWP - Fortress SSA2
433Mhz - Cubie Domoticz + RFXtrx + Oregon || Foscam 9821W
2,4Ghz - Cubie MySensors Gateway + COV + TempHumidity + Pressure + WaterMeter
- Domoticz version: 2020.x
Wow your are quick, thanks
I just did the update:
- Spoiler: show
- epierre
try a new updateBikey wrote:Wow your are quick, thanks![]()
And at first there where no unknown devices, but after switching a couple of times, they are back again! And increasing...
Wow, you are really fast, this time it works! Thanks, no more repeating devices!
Only issues I still have are:
- Most important: the push-on and pus-off buttons work the wrong way around. Like explained earlier: a "push-on" button should be "Off" in the interface. If you push it, it should send an "On" signal and show an "On" state in the interface temporarily and then turn back to the "Off" state in the interface. Currently it is just the other way around: it is "On" in the interface and send an "Off" command if you push it.
- My PIR-sensors are presented just like smoke detectors with the status "OK", "Alert!". They have a button wich suggests that they can be "Armed" and "Disarmed" but that is not possible with my motion detectors.
- I have 2 empty tab pages in the App: "Utility" and "Volume" (?). Probably not something you can do anything about?
- In the App (top right) you can select "show hidden devices". That does not do anything, I was expecting that it would show the devices that are hidden in Domoticz by using a name that starts with "$"
- epierre
this is not what I have seen yesterday for I tested in both interface and this was ok for push on and push off buttons. In domoticz the push on is always on, there is no off anywhere. In imperihome, since they doon't have the push button it is a switch, so if you push the on button, it goes off in imperihome but sends an on to domoticz. Then imperihome refreshes and see it is On in domoticz so goes back to On.Bikey wrote: [*]Most important: the push-on and pus-off buttons work the wrong way around. Like explained earlier: a "push-on" button should be "Off" in the interface. If you push it, it should send an "On" signal and show an "On" state in the interface temporarily and then turn back to the "Off" state in the interface. Currently it is just the other way around: it is "On" in the interface and send an "Off" command if you push it.
I have the same, it is not a button but a status you cannot change.Bikey wrote: [*]My PIR-sensors are presented just like smoke detectors with the status "OK", "Alert!". They have a button wich suggests that they can be "Armed" and "Disarmed" but that is not possible with my motion detectors.
I could, but I would need a tracker for this. This means I need to parse the devices before giving the rooms, this can be done as an enhancementBikey wrote: [*]I have 2 empty tab pages in the App: "Utility" and "Volume" (?). Probably not something you can do anything about?.
this is imperihome specific, you can hide devices in imperihome going in their configuratonBikey wrote: [*]In the App (top right) you can select "show hidden devices". That does not do anything, I was expecting that it would show the devices that are hidden in Domoticz by using a name that starts with "$" [/list].
I just tested it: you are wright, in Domoticz the push on is always on. If you push it, Domoticz sends an "On" command (that's why it is called a push-ON button I guess...).epierre wrote: this is not what I have seen yesterday for I tested in both interface and this was ok for push on and push off buttons. In domoticz the push on is always on, there is no off anywhere. In imperihome, since they doon't have the push button it is a switch, so if you push the on button, it goes off in imperihome but sends an on to domoticz. Then imperihome refreshes and see it is On in domoticz so goes back to On.
However, if I push it in Imperihome it sends an "Off" command, which causes it to go Off in Domoticz interface as well.
Also in Imperihome the buttons returns to "On", while in Domoticz it is still "Off" (both in the interface and looking at a the last state in the log). So the gateway does not actually seem to look at the status of Domoticz (or the API gives a wrong state)?
What do you mean by "tracker". Is that something I can do, I don't have a Github account.I have 2 empty tab pages in the App: "Utility" and "Volume" (?). Probably not something you can do anything about?.I could, but I would need a tracker for this. This means I need to parse the devices before giving the rooms, this can be done as an enhancement
this is imperihome specific, you can hide devices in imperihome going in their configuraton[/quote]Bikey wrote: In the App (top right) you can select "show hidden devices". That does not do anything, I was expecting that it would show the devices that are hidden in Domoticz by using a name that starts with "$" [/list].
Ok, so you mean that the Imerihome API does not support hidden devices? I don't see any options in the settings for the Imperihome App to hide devices.
- epierre
I did look in the domoticz logs, it does not send an off. Yes the api sends always an on for a push on button whatever the status.Bikey wrote:I just tested it: you are wright, in Domoticz the push on is always on. If you push it, Domoticz sends an "On" command (that's why it is called a push-ON button I guess...).epierre wrote: this is not what I have seen yesterday for I tested in both interface and this was ok for push on and push off buttons. In domoticz the push on is always on, there is no off anywhere. In imperihome, since they doon't have the push button it is a switch, so if you push the on button, it goes off in imperihome but sends an on to domoticz. Then imperihome refreshes and see it is On in domoticz so goes back to On.
However, if I push it in Imperihome it sends an "Off" command, which causes it to go Off in Domoticz interface as well. Also in Imperihome the buttons returns to "On", while in Domoticz it is still "Off" (both in the interface as if I look at a the last state in the log). So the gateway does not actually seem to look at the status of Domoticz (or the API gives a wrong state)?
What do you mean by "tracker". Is that something I can do, I don't have a Github account.[/quote]Bikey wrote: I have 2 empty tab pages in the App: "Utility" and "Volume" (?). Probably not something you can do anything about?.I could, but I would need a tracker for this. This means I need to parse the devices before giving the rooms, this can be done as an enhancement
ok I'll do it
Ok, so you mean that the Imerihome API does not support hidden devices? I don't see any options in the settings for the Imperihome App to hide devices.[/quote]
yes and no.... I take all devices whenever they are hidden or not in domoticz, but I cannon set a hidden flag in the API
to change this in the ui, press long on the device name, then check "hide this device"
No, it's a regular On/Off switch. I tried changing to another type and changing it back but that didn't help. When changed to a push-on I see indeed the same behaviour except when it's an On/Off switch it shows this behaviour only when On. Other switches behave normal, so I've only one weird switch.epierre wrote:
is that a push-on or push-off button in domoticz ? then this is normal, I restested this yesterday
Mark: Domoticz Beta on Raspberry Pi 4 running Debian Bookworm - Z-Stick 7 - RFXCom - P1 - MySensors - SolarEdge - Dahua - Philips Hue - Docker - Zigbee2mqtt (plugin) - Zwave-js-ui - dzVents - Nodered
- epierre
ok so it is something different, if I have your database, what is the device in question so I can have a look ?Doler wrote:No, it's a regular On/Off switch. I tried changing to another type and changing it back but that didn't help. When changed to a push-on I see indeed the same behaviour except when it's an On/Off switch it shows this behaviour only when On. Other switches behave normal, so I've only one weird switch.epierre wrote:
thanks,
I have to disagree. I have created a dummy "push-on" switch in Domoticz. If I push it in ImperiHome the status gets "Off". The API also shows that the status is "Off". Look:epierre wrote: I did look in the domoticz logs, it does not send an off. Yes the api sends always an on for a push on button whatever the status.
- Spoiler: show
Thanks!ok I'll do it
Oh, didn't know that, that's what I needed, thanks for the tip!to change this in the ui, press long on the device name, then check "hide this device"
Nope: all devices with a "$" in the name do not appear in Imperihome. They are also not available in http://gatewayIP:port/devicesI take all devices whenever they are hidden or not in domoticz
Did sent it a couple of minutes ago.epierre wrote: ok so it is something different, if I have your database, what is the device in question so I can have a look ?
thanks,
- epierre
this indicates something internal, we only use the Status which is empty here for it is always On. I guess this is something alwas answered but not used, I'm not sure the value changes one day... it has also dimmer function but is not dimmable, too much useless informationBikey wrote:I have to disagree. I have created a dummy "push-on" switch in Domoticz. If I push it in ImperiHome the status gets "Off". The API also shows that the status is "Off". Look:epierre wrote: I did look in the domoticz logs, it does not send an off. Yes the api sends always an on for a push on button whatever the status.
- Spoiler: show
this has to be investigated, I see no reasonBikey wrote:Nope: all devices with a "$" in the name do not appear in Imperihome. They are also not available in http://gatewayIP:port/devices
Well I see "Data" : "On" or changing to "Off" and "Internal State" (which is probably the presentation) also changing from "On" to "Off".epierre wrote: this indicates something internal, we only use the Status which is empty here for it is always On. I guess this is something alwas answered but not used, I'm not sure the value changes one day... it has also dimmer function but is not dimmable, too much useless information
Perhaps you can use those states?
See below for the "On" condition of the push-on button (previous post was the "Off" state):
- Spoiler: show
Another request/question: I have a door contact (type "contact" in Domoticz) wich can be "Open" or "Closed".
In Imperihome however this contact is presented as a switch, suggesting that you can activate it. Can you change this to a "DevDoor" (not Armable)?
I see in the ImperiHome API-documentation that a smoke detector = DevSmoke and that it has a param key "Armable" as well. If you set this at "0", perhaps this is also removed in the App interface? That would be nice!
- epierre
Well I'm a bit puzzled because:Bikey wrote:Well I see "Data" : "On" or changing to "Off" and "Internal State" (which is probably the presentation) also changing from "On" to "Off".epierre wrote: this indicates something internal, we only use the Status which is empty here for it is always On. I guess this is something alwas answered but not used, I'm not sure the value changes one day... it has also dimmer function but is not dimmable, too much useless information
1- I don't think domoticz would handle any off value on such buttons (push on button)
2- many people already use it this way without reporting an issue.
if this is a push on button, why would you have an off command which is sent ? I don't understand the behavior...
From Domoticz it is not possible to send an "Off" command. So the only way for me now to get it to change to "Off" is by using the ImperiHome App. If i push it in the App, it changes to "Off" in Domoticz, but changes to "On" again in Imperihome! So to me, this proves that Imperihome is sending an "off" message if you press a "Push-on" button....
- epierre
if there is a parameter presented by domoticz I can show that difference, what is your device so I can see ?Bikey wrote:Another request/question: I have a door contact (type "contact" in Domoticz) wich can be "Open" or "Closed".
I already send a DevDoor for a DooLock device in DZ.
Same here, I already send a DevSmoke for a Smoke Detector device in DZ.Bikey wrote:I see in the ImperiHome API-documentation that a smoke detector = DevSmoke and that it has a param key "Armable" as well. If you set this at "0", perhaps this is also removed in the App interface? That would be nice!
have you some device that are not mapped these way ? if so, please tell me your names on your DZ,
- epierre
I don't know if this is the same issue as Doler, but a push on is always on in domoticz. If it is not, then this is not a push-on button.Bikey wrote:From Domoticz it is not possible to send an "Off" command. So the only way for me now to get it to change to "Off" is by using the ImperiHome App. If i push it in the App, it changes to "Off" in Domoticz, but changes to "On" again in Imperihome! So to me, this proves that Imperihome is sending an "off" message if you press a "Push-on" button....
what is the device in your database so I can have a look ?
In Domoticz API it is shown as: "SwitchType" : "Push On Button", see below:epierre wrote:I don't know if this is the same issue as Doler, but a push on is always on in domoticz. If it is not, then this is not a push-on button.Bikey wrote:From Domoticz it is not possible to send an "Off" command. So the only way for me now to get it to change to "Off" is by using the ImperiHome App. If i push it in the App, it changes to "Off" in Domoticz, but changes to "On" again in Imperihome! So to me, this proves that Imperihome is sending an "off" message if you press a "Push-on" button....
- Spoiler: show
"name":"TestButton","type":"DevSwitch","id":"166","room":"Switches"},{"params":[{"unit":"","value":"unk","graphable":"false","key":"Value"}]
- epierre
ok the unk value is not normal, I'll see why it is here.Bikey wrote: And this is what the Gateway shows:
