Blockly temperature comparison not working?
edge
Post by edge »
I have one virtual sensor for the temperature (via WUnderground - link). The sensor is giving as output "14.9" only.
Just created an event for testing purposes, but (shame!) such an basic event isn't working... What am I doing wrong?:
Last edited by ThinkPad on Wednesday 02 September 2015 14:25, edited 1 time in total.
Reason: Changed title to make more clear what topic is about ;)
ThinkPad
Re: [Newb] Notification on temperature
Post by ThinkPad »
Blockly seems to be correct, i have seen this earlier but nobody seems to have an answer about this...
I know user 'Domosapiens' is using these kind of comparisons and has it working, but as far as i know, your Blockly should just work...
Domosapiens
Domoticz version: V3.5981
Re: Blockly temperature comparison not working?
Post by Domosapiens »
.... these type of remarks:
in your 1st post! ....
You can say sorry, by using the Donate button here: https://domoticz.com/
Did some test:
Temp_Ouside is a scraped value from WUnderground
Seems not to work, it does not fire the Blockly, even when temperature is changed.
This one works, the trigger comes from the switch D_Check_Event_Syst that fires the Blockly
My ZWave DS18B20 temp sensors connected via FGBS001 do generate a trigger every time they report and as such fire the Blockly where they are used.
Don't know how to get a trigger after you scraped the temp part of WUnderground.
Hope someone else can help with that.
Domosapiens
edge
Post by edge »
Domosapiens wrote:.... these type of remarks:
Well, the 'shame' reflects on myself, not Domoticz.
Thanks for testing Domosapiens..
scatman
Domoticz version: 2.2563
Post by scatman »
Hellow
i have the sameproblem.
This is my simply event:
and this is log for event:
2015-09-03 22:41:47.387 Error: EventSystem: Lua script error (Blockly), Name: Test_3_1 => [string "result = 0; weekday = os.date('*t')['wday']; ..."]:1: attempt to index global 'temperaturedevice' (a nil value)
What is wrong?
I've RFXcom on RPI2 and sensor temp is Oregno (THC238/268, THN132, THWR288, THRN122, THN122, AW129/131)!
scatman
Post by scatman »
scatman wrote:Hellow
What is wrong?
I found the solution for this problem ...
You have to updateing your LUA ...
sudo apt-get install lua5.2
bizziebis
Domoticz version: 3.8805
Post by bizziebis »
That would be odd. An external dependency causing Domoticz base system to malfunction.. I thought LUA was compiled from source with Domoticz? If that's not the case maybe we should include it to avoid these kind of strange problems.
scatman
Post by scatman »
bizziebis wrote:That would be odd. An external dependency causing Domoticz base system to malfunction.. I thought LUA was compiled from source with Domoticz? If that's not the case maybe we should include it to avoid these kind of strange problems.
maybe, but I didn't change nothing in my event
I only update LUA and I've restarted my event and it was correct.
In the evening I've watched and moved my sensor temp but it's all.
edge
Post by edge »
Hmm interesting.. Going to try that asap.
MEk72
Post by MEk72 »
Any success in this?
I tried updating but without any success.
//Mattias
Minglarn
Domoticz version: v3.8153
Post by Minglarn »
Anyone tried to the update for LUA? and did the temperature comparison work after the update?
talfr
Post by talfr »
I have same error with some events blocky for many months.
I update lua script package, all errors disappear.
thank a lot.
Mooseknuckle
Post by Mooseknuckle »
It works without updating Lua. I didn't use the scraped temp only sensor but the standard (temp+hum+baro)sensor which is created when you add Wunderground as hardware. Notifications based on temp values work for me when I use that sensor.
Greetings.
RPI 3, Philips Hue,Toon Thermostat, Harmony Smart Control, Yeelights
Mysensors wifi gateway + sensors, RFXtrx433E, Kaku stuff, Xiaomi gateway + sensors
Domoticz controlled DIY ambilight, Selectplus chime, Mi-light led controller
