domoticz in synology as package! Available now.
- jumbotroll
Domoticz Updated to v2.0.2903.
Domoticz-5.2_2.0.2903-7 All-arch with USB drivers and OpenZWave 1.3.444.
Full list here: http://jadahl.dscloud.me/sspks/index.php?fulllist=true
Jumbotroll
Jumbotroll
https://paypal.me/Jumbotroll
Jumbotroll
http://www.jadahl.com
Jumbotroll
- mvveelen
Wow, Jumbotroll, when you are on a roll, you are on a roll !!
I love the work you're doing for the Synology community / Domoticz users. Thank you very much.
A big hand for Jumbotroll
RPi3b+/RFXCOM rfxtrx433E/Shelly/Xiaomi Gateway/Philips HUE Lights/Atag Zone One/2 SunnyBoy inverters/AirconWithMe/P1 smartmeter/Domoticz latest Beta
- G3rard
- Target OS: -
- Domoticz version: No
I second that! Indeed great work Jumbotroll!!!
Not using Domoticz anymore
- jumbotroll
@mvveelen
@G3rard
Thanks for the feedback guys!
Have spent alot of my free time on this project. And I do not even use OpenZwave
Jumbotroll
@G3rard
Jumbotroll
Jumbotroll
Jumbotroll
The updates are rolling again and they are working great, no issues at all!!
Great job guys
BTW, I have found a way to have the built-in SSL to work but with the update the configuration is being lost, ¿is there any way to keep that changes or have a flag or smthing?
I manually modify the start-stop-status file by adding 2 more variables: -sslwww ${RSSLPORT} -sslcert ${RSSLCERT}
Great job guys
Synology NAS 415+ | Raspberry + Aeon Z-Stick Gen5
- jumbotroll
I have build a test version for you with these line included in start-stop-status.dpons039 wrote:The updates are rolling again and they are working great, no issues at all!!
Great job guys
This is the also domoticz_avoton-5.2_2.0.2903-7.spk, take backup of db and uninstall prev version and reinstall this:
Download here: http://jadahl.com/domoticz_avoton-5.2_2.0.2903-7.spk (with -sslwww ${RSSLPORT} -sslcert ${RSSLCERT})
Jumbotroll
Jumbotroll
Jumbotroll
Wow, great work Jumbotroll!
Yesterday i installed the spk on my synology 213 and everything is working fine! Im trying to connect the RFLink Gateway to my Synology NAS. I see in the log of Domoticz the initializing of the RFlink, after that i receive a few devices like my weather station. Then i got a now log entry with a new initializing.
Is the RFlink supported in this situation? And where can i find detailed logging which i can provide to the RFLink Gateway team?
Thank in advance and keep up the good work!
Hey there,jumbotroll wrote:I have build a test version for you with these line included in start-stop-status.dpons039 wrote:The updates are rolling again and they are working great, no issues at all!!
Great job guys
Jumbotroll
Just installed but it's lacking the 2 settings on the upper side:
WWWROOT="${INSTALL_DIR}/www/"
PID_FILE="${INSTALL_DIR}/var/domoticz.pid"
LOGFILE="${INSTALL_DIR}/var/domoticz.log"
DB_FILE="${INSTALL_DIR}/var/domoticz.db"
PORT="8084"
# SSL PORT - should be different than above
RSSLPORT=""
# SSL pem file route, should include decrypted private key and certificate
RSSLCERT=""
After that, we should have a condition. In case those 2 values are filled the run script should be:
su - ${USER} -c "${DOMOTICZ} -www ${PORT} -wwwroot ${WWWROOT} -sslwww ${RSSLPORT} -sslcert ${RSSLCERT} -approot ${INSTALL_DIR}/ -userdata ${INSTALL_DIR}/var/ -dbase ${DB_FILE} &> $LOGFILE & echo \$! > ${PID_FILE}"
Otherwise it should be:
su - ${USER} -c "${DOMOTICZ} -www ${PORT} -wwwroot ${WWWROOT} -approot ${INSTALL_DIR}/ -userdata ${INSTALL_DIR}/var/ -dbase ${DB_FILE} &> $LOGFILE & echo \$! > ${PID_FILE}"
This will allow any1 to use the SSL if needed, I guess the settings RSSLPORT and RSSLCERT can be preserve in case of an update.
- jumbotroll
I don't use RFlink, so I can't test this.drenergy wrote:Wow, great work Jumbotroll!
Ask the guys in Bugs/problem section on this forum.
Jumbotroll
Jumbotroll
Jumbotroll
- jumbotroll
@dpons039
New Test for you
domoticz_avoton-5.2_2.0.2907-7.spk
http://jadahl.dscloud.me/sspks/packages ... 2907-7.spk
Jumbotroll
New Test for you
Jumbotroll
Jumbotroll
Jumbotroll
Thank you very much! Working perfectjumbotroll wrote:@dpons039
New Test for you![]()
Jumbotroll
- jumbotroll
Good, then I add this in the next updates.dpons039 wrote:Thank you very much! Working perfectjumbotroll wrote:@dpons039
Jumbotroll
Jumbotroll
Jumbotroll
Jumbotroll
Good morning,
I have installed the update 2927-7 and I have notice that the Update did remove the information I have for the SSL connection, is there any way to keep that information?
Thank you for your hard work
- jumbotroll
RSSLPORT= and RSSLCERT= Settings is overwritten, if not the information is compiled in the start script, so the answer is No ATM.dpons039 wrote:Good morning,
Jumbotroll
Last edited by jumbotroll on Thursday 03 September 2015 11:06, edited 2 times in total.
Jumbotroll
Jumbotroll
- mvveelen
Hi Jumbotroll, how much (extra) work is it to leave the styles folder "as it is" while updating? Just like it is with the scripts folder.
I'm using a slightly different theme that I've uploaded to the styles folder, but it's gone after every update. It isn't that much work to upload that folder after an update, but maybe this folder could be moved while upgrading and moved back after upgrading using the same method as the scripts folder.
No big deal though !
And thank you again for all the updates !
- jumbotroll
Can you test this?mvveelen wrote:Hi Jumbotroll, how much (extra) work is it to leave the styles folder "as it is" while updating? Just like it is with the scripts folder.
domoticz_armadaxp-5.2_2.0.2931-7.spk (keep www/styles folder after update)
I don't Know if this is a good solution, but this is a fast quick fix?
http://jadahl.dscloud.me/sspks/packages ... 2931-7.spk
Jumbotroll
Jumbotroll
Jumbotroll
- mvveelen
Whaaaaa.....so fast ?!?!
Yes, I just updated the package and the styles folder still contains the theme I'm using. This is great, thank you !!
- jumbotroll
Nicemvveelen wrote:Whaaaaa.....so fast ?!?!
This quick fix keep the all /www folder. Going to do some testing later, to only keep the www/styles folder.
Jumbotroll
Jumbotroll
Jumbotroll
- mvveelen
That would be the best solution imho because you never know what changes will be added in the rest of the www folder. Thank you for doing this, and if you want me to test: let me know
- jumbotroll
Maybe it is a bad idea to keep the old /styles folder in case of updates.mvveelen wrote:That would be the best solution imho because you never know what changes will be added in the rest of the www folder. Thank you for doing this, and if you want me to test: let me know
I think maybe I will work on a another solution..
If there is a "custom-temp" folder in the styles folder we can keep that but update as usual?
This way
www/styles/custom-temp
What do you think about that?
Jumbotroll
Jumbotroll
Jumbotroll
