No worries mate, as I mentioned before, it's my fault not yours. As for the RPI, there are good deals on Aliexpress right nowjumbotroll wrote:Sorry for your problemLouiS22 wrote:Yup, during the update of the package it went to a loop or something. It recovered from them but the result was the wipe of the domoticz folder and the subsequent files. Doublechecked everything, there's no domoticz.db Well, I can only blame myself not to make a backup beforegizmocuz wrote:Whaa... your whole synology crashed ?Price of using betas I guess, and one more reason to switch to an RPI. I'm tired of Synology's way of handling 3rd party spk-s and fiddling with the cross compiler and lack of proper OZW support. Otherwise, synology is a great platform
The arch-x86 running nice on my DS-712+
I have deleted the test files from my server.
Still have problem patching OpenZwave and moore, but I don't have time or skills to fix this.
Maybe it's time to buy a RPI![]()
Time will show if someone have the time to fix a working spksrc?
I think I leave the spksrc updating to the experts.
Jumbotroll
domoticz in synology as package! Available now.
- LouiS22
- G3rard
- Target OS: -
- Domoticz version: No
That would be a pityjumbotroll wrote: Sorry for your problem![]()
Jumbotroll
Is there anyway we can help? I really love Domoticz with OpenZWave on my Synology.
Not using Domoticz anymore
- jumbotroll
@G3rard What type NAS are you running arch?
I am testing openzwave first with arch-x86 if that work I will try to compile for another arch.
I do not have much time to work with this, so be patiently
Jumbotroll
Jumbotroll
https://paypal.me/Jumbotroll
Jumbotroll
http://www.jadahl.com
Jumbotroll
- G3rard
- Target OS: -
I have a x86 as well (DS1010+).
All your effort is very much appreciated
- jumbotroll
Ok..Here you go:domoticz_x86-5.2_2.0.2826-7.spk with OpenZwave 1.3.444 and USB driver support for x86G3rard wrote:I have a x86 as well (DS1010+).
http://jadahl.dscloud.me/sspks/packages ... 2826-7.spk
I have tested on my DS712+ with RFXCOM, but not with OpenZwave, I don't use OpenZwave.
Can you test it?
I have compiled Native openzwave and patched it into domotiz.
Sorry but I still have problem cross compile OpenZwave for another arch.
Jumbotroll
Jumbotroll
Jumbotroll
- G3rard
- Target OS: -
Just installed it and it works, also the ZWave stuff
- jumbotroll
GreatG3rard wrote:Just installed it and it works, also the ZWave stuff![]()
Thanks![]()
Jumbotroll
Jumbotroll
Jumbotroll
ThinkPad
How difficult would armada370 (DS114) without openzwave be? Still sitting on 2619, which means i lag ~200 commits behind
- jumbotroll
Here you go @ThinkPadThinkPad wrote:How difficult would armada370 (DS114) without openzwave be? Still sitting on 2619, which means i lag ~200 commits behind![]()
domoticz_armada370-5.2_2.0.2826-7.spk No OpenZwave in this version.
http://jadahl.com/armada370/domoticz_ar ... 2826-7.spk
Jumbotroll
Jumbotroll
Jumbotroll
ThinkPad
Really great, will try it directly when i'm at home!jumbotroll wrote:Here you go @ThinkPadThinkPad wrote:How difficult would armada370 (DS114) without openzwave be? Still sitting on 2619, which means i lag ~200 commits behind![]()
Jumbotroll
How come that you could compile it so quickly? Or is the difficult part to include Z-Wave support in the package?
- jumbotroll
I have made a environment for building spk on a Linux Mint machine.ThinkPad wrote: How come that you could compile it so quickly? Or is the difficult part to include Z-Wave support in the package?
Only have to download the right toolchain for armada370 and edit some files, the building takes about 10 min if I have the right toolchains installed.
The OpenZwave part, is no problem to incklude, but newer versions of OpenZwave fails big time when I cross compile.
Jumbotroll
Jumbotroll
Jumbotroll
ThinkPad
Installed it this afternoon, everything seems to work fine. Thank you for your help, like always. Greatly appreciated!
- jumbotroll
@mvveelen
Do you want to test this with OpenZWave support?
I have made some tweaks and want to know if Zwave working ok
domoticz_armadaxp-5.2_2.0.2832-7.spk with OpenZWave:
http://jadahl.dscloud.me/sspks/packages ... 2832-7.spk
Jumbotroll
Jumbotroll
Jumbotroll
Jumbotroll
- jumbotroll
Here are some more test files with OpenZWave
http://jadahl.dscloud.me/sspks/index.php?fulllist=true
Jumbotroll
Jumbotroll
Last edited by jumbotroll on Saturday 05 September 2015 21:08, edited 3 times in total.
Jumbotroll
Jumbotroll
- mvveelen
Just made some time for this. The package for the armadaxp seems to work fine with ZWave ! Wow
I'm checking some other things of course, but this seems to be fine.
One error when I started Domoticz though:
What about this error, gizmocuz ?
Edit: after a reboot of the Synology this error didn't show up again. So it could be something to do with the update. But: how do I know if the db is OK ? Everything seems to run fine.
2015-08-27 19:44:54.274 Error: SQL Query("ALTER TABLE MySensorsChilds ADD COLUMN [Name] VARCHAR(100) DEFAULT ''") : duplicate column name: Name
2015-08-27 19:44:54.274 Error: SQL Query("ALTER TABLE MySensorsChilds ADD COLUMN [UseAck] INTEGER DEFAULT 0") : duplicate column name: UseAck
ThinkPad
Seems to work fine on DS114, no errors.jumbotroll wrote:Here are some more test files with OpenZWave
domoticz_armada370-5.2_2.0.2841-7.spk
http://jadahl.dscloud.me/sspks/packages ... 2841-7.spk
Jumbotroll
Didn't try Z-Wave.
Thanks again jumbotroll!
apepannetje
domoticz_avoton-5.2_2.0.2841-7.spk
domoticz_alpine-5.2_2.0.2841-7.spk
domoticz_88f6281-5.2_2.0.2841-7.spk
domoticz_armadaxp-5.2_2.0.2841-7.spk
domoticz_bromolow-5.2_2.0.2841-7.spk
domoticz_cedarview-5.2_2.0.2841-7.spk
domoticz_ppc853x-5.2_2.0.2841-7.spk
domoticz_qoriq-5.2_2.0.2841-7.spk
domoticz_x86-5.2_2.0.2841-7.spk
Jumbotroll
i have try to install the domoticz_alpine-5.2_2.0.2841-7.spk on a 215 syno.
syno do not regnonise this spk
ias there a other option?
Greetz apepannetje
- jumbotroll
Greetz apepannetje
DS215+ use alpine4k.
domoticz_alpine-5.2_2.0.2869-7.spk
I have added arch- alpine4k arch="alpine alpine4k" in this file : http://jadahl.dscloud.me/sspks/packages ... 2869-7.spk
Please try again
Jumbotroll
Jumbotroll
Jumbotroll
apepannetje
Thanks jumbotroll,
I Will give it a Tray
Gr. Apepannetje
Gr. Apepannetje
apepannetje
Greetz apepannetje
Please try again![]()
Jumbotroll
Greetz Apepannetje
