domoticz in synology as package! Available now.
- mvveelen
Yes, that's the right location. And....you don't have to change the permissions of the lua scripts. You just don't have to
RPi3b+/RFXCOM rfxtrx433E/Shelly/Xiaomi Gateway/Philips HUE Lights/Atag Zone One/2 SunnyBoy inverters/AirconWithMe/P1 smartmeter/Domoticz latest Beta
Yup, thanks for your help guys... it was the location of the script
- LouiS22
Looks like making a working version with Synology is quite a big task - and it's well beyond my skills. So far I managed to make a manual update using a downloaded version of the current repo, and manually deleting the update-related code sources but I'm stuck with the version numbering and to make it worse, I've wiped the working folder so 2 hours of code fiddling went to the almighty Code God...
- jumbotroll
It's well beyond my skills to, I've spent many hours trying to figure this out , but will see if I take hold of it again when the cold autumn arrives.
Cross compiling can be a pain sometimes.
Jumbotroll
Jumbotroll
https://paypal.me/Jumbotroll
Jumbotroll
http://www.jadahl.com
Jumbotroll
- Minglarn
- Domoticz version: v3.8153
Hi guys! My first post here and have a question...
What to prefer: Domoticz on a Raspberry PI2 or Domoticz on a Synology D213?
Have tried both and have a feeling that the Raspberry version is easier to program whit special scripts ect?
//Minglarn...
//Minglarn...
“When you eliminate the impossible, whatever remains, however improbable, must be the truth.” -Spock in Star Trek VI
- LouiS22
Right now the RPI is a better choice as there's no working method to cross compile domoticz to Synology.Minglarn wrote:Hi guys! My first post here and have a question...
//Minglarn...
- mvveelen
@Jumbotroll: isn't there anyone on Github with who you can try to compile new packages?
I wish I could help you, but I'm a real n00b with this. I can only test it for you
- LouiS22
I tried it but eventually gave it up. Too much changes, especially for the update code (which is of course not for Synology).mvveelen wrote:@Jumbotroll: isn't there anyone on Github with who you can try to compile new packages?
- gizmocuz
Please tell me what are the current problems, and if i can assist in any way.
I hoped the code would be cross platform, and should not cause any troubles compiling for the synology!
- LouiS22
Well, according to my tries the main problem is with the update module you applied (had to uncomment those lines to start the compiler, but after that I ran into other obstacles, and that was the point when I gave it up and ordered an RPIgizmocuz wrote:Please tell me what are the current problems, and if i can assist in any way.
- gizmocuz
For sure the update module would not apply for the synology users.
So i cant see a reason why it should not work on a synology ?
- LouiS22
That's true, but it causes problems with the current cross compiler (spksrc).gizmocuz wrote:For sure the update module would not apply for the synology users.
- gizmocuz
Plz show me the compile error
- jumbotroll
I have done some testing and tweaks, but I am far from a nice solution.
Problem with OpenZwave cross compiling after version 1.3.328.
This test versions is without OpenZwave.
I have not made a new spksrc that working, but manually downloaded domoticz source and cross compiled "a lot of work"
Here are some test without OpenZwave, but with usb drivers.
************DELETED*************
Jumbotroll
Jumbotroll
Last edited by jumbotroll on Tuesday 25 August 2015 22:16, edited 1 time in total.
Jumbotroll
Jumbotroll
- mvveelen
Good to see there is some progress with this, @Jumbotroll and @gizmocuz. Unfortunately I need ZWave, so I won't test this version.....
- gizmocuz
are you able to make a patch against openzwave, so this would compile ?
I would not expect issues with cross compiling domoticz, did you need to make any changes?
- LouiS22
Might be my fault, but upon ugrading, Synology crashed and thus erased the previous version as welljumbotroll wrote:I have done some testing and tweaks, but I am far from a nice solution.
I have not made a new spksrc that working, but manually downloaded domoticz source and cross compiled "a lot of work"![]()
domoticz_x86-5.2_2.0.2820-7.spk
http://www.jadahl.com/test/domoticz_x86 ... 2820-7.spk
domoticz_armadaxp-5.2_2.0.2820-7.spk
http://www.jadahl.com/test/domoticz_arm ... 2820-7.spk
domoticz_88f6281-5.2_2.0.2820-7.spk
http://www.jadahl.com/test/domoticz_88f ... 2820-7.spk
Jumbotroll
- gizmocuz
Whaa... your whole synology crashed ?
- LouiS22
Yup, during the update of the package it went to a loop or something. It recovered from them but the result was the wipe of the domoticz folder and the subsequent files. Doublechecked everything, there's no domoticz.db Well, I can only blame myself not to make a backup beforegizmocuz wrote:Whaa... your whole synology crashed ?
- jumbotroll
Sorry for your problemLouiS22 wrote:Yup, during the update of the package it went to a loop or something. It recovered from them but the result was the wipe of the domoticz folder and the subsequent files. Doublechecked everything, there's no domoticz.db Well, I can only blame myself not to make a backup beforegizmocuz wrote:Whaa... your whole synology crashed ?Price of using betas I guess, and one more reason to switch to an RPI. I'm tired of Synology's way of handling 3rd party spk-s and fiddling with the cross compiler and lack of proper OZW support. Otherwise, synology is a great platform
The arch-x86 running nice on my DS-712+
I have deleted the test files from my server.
Still have problem patching OpenZwave and moore, but I don't have time or skills to fix this.
Maybe it's time to buy a RPI
Time will show if someone have the time to fix a working spksrc?
I think I leave the spksrc updating to the experts.
Jumbotroll
Jumbotroll
Jumbotroll
