domoticz in synology as package! Available now.
I have a DS213+ running DSM 5.2-5592 Update 1 with Domotics V2.2621 set up as master
The slave is A Exchange 2008 server running Domoticsz V2.2657 and Open Hardware monitor to monitor it's motherboard sensors
The connectivity between Master and slave is OK, remote sensors from the Exchange server show up but the info is completely meaningless.
Is there an issue on the Synology, if not which versions work together or...... even better.... can we expect build V2.2657 for the Synology and does this solve the issue?
Many thanks!
Many thanks!
- kraades
- Domoticz version: Stable
Does anyone have the S0 Pulse Counter Module working connected to the Synology?
https://sites.google.com/site/nta8130p1 ... er/webshop
Any change of having the drivers included in the package?
I think it is Arduino Leonardo based.
I have troubles to get the event working with a timestamp.
Is there some bug arround with Synology and Domoticz?
- mvveelen
Hi Jumbotroll, I've been running the V2.2621 for a while now and also installed it on the DS414 my father-in-law just bought: works great. But, will there be an update in the near future for the armadaxp (DSM5.2, latest) to keep up with the latest developments
? Thanks for your great work, much appreciated !
RPi3b+/RFXCOM rfxtrx433E/Shelly/Xiaomi Gateway/Philips HUE Lights/Atag Zone One/2 SunnyBoy inverters/AirconWithMe/P1 smartmeter/Domoticz latest Beta
- jumbotroll
There is so much changes in the domoticz source and Openzwave source , so there is a lot of work and many changes to cross- compile for synology at the moment that I await further updates. I do not have time to change the code. Time will tell if I sit down and work on it.mvveelen wrote:Hi Jumbotroll, I've been running the V2.2621 for a while now and also installed it on the DS414 my father-in-law just bought: works great. But, will there be an update in the near future for the armadaxp (DSM5.2, latest) to keep up with the latest developments? Thanks for your great work, much appreciated !
Jumbotroll
https://paypal.me/Jumbotroll
Jumbotroll
http://www.jadahl.com
Jumbotroll
- Domoticz version: 2.0.2276
Hi, jumbotroll
I've been using your package USBserialDriver http://www.domoticz.com/forum/viewtopic ... 120#p35984
on my DS3615 (bromolow) DSM5.1-5022 for other applications that use AeonLab Stick S2 (not Domoticz).
On my second DS3615 (bromolow) DSM5.2-5592.
You have a package USBserialDriver for DSM5.2-5592?
Syn DS3615xs DMS 5.1-5022U5(xpenology;Intel2700MUD;4GbRAM;2*3TbHDD->JBOD)
Syn DS3615xs DMS 5.2-5592(xpenology;asus p8-z68;I3;4GbRAM;6*2TbHDD->JBOD)
Z-Wave Aeon Labs Z-Stick S2->OpenRemote;Domoticz
- jumbotroll
USBSerialDrivers_5.2_5592_Test.spktehnoinstyle wrote:Hi, jumbotroll
Deleted
Jumbotroll
Jumbotroll
Jumbotroll
- LouiS22
Hey, I also did the above modification, it seems working on my config, at least RFXCOM is happyjumbotroll wrote:USBSerialDrivers_5.2_5592_Test.spktehnoinstyle wrote:Hi, jumbotroll
THIS IS ONLY A TEST!
I have tested on arch-x86 DS-712+ and it worked here.
Modified some foldername.
You can download from my server and test USBSerialDrivers_5.2_5592_Test.spk : http://jadahl.dscloud.me/sspks/packages ... 2_Test.spk
REMEMBER THIS IS ONLY A TEST!!!
Jumbotroll
Jumbotroll, may I request you to upload your modified spksrc files somewhere? I'm interested in 88f6281, I have successfully build my own versions up to 2730, but without OZW, since I couldn't figure out one thing with that (I think it's just a symlink, or something trivial). If so, then probably I could provide updates (though I have to find a solution to grab the latest beta from github
Hey there,
I have been using the package successfully for the last weeks and it works great!
But I'm having issues with the USB coz randomly the port changes from ttyACM0 to ttyACM1, i read there's an option for persistence but no clue on how to perform that on the NAS.
Any clues?
Thank you
PS: The Lua Scripts folder has changed the location and it's not updated within the package
Any clues?
Thank you
Synology NAS 415+ | Raspberry + Aeon Z-Stick Gen5
- jumbotroll
I do not have the spksrc files, USBSerialDrivers, source is made by Noam Lebovitz.Jumbotroll, may I request you to upload your modified spksrc files somewhere? I'm interested in 88f6281, I have successfully build my own versions up to 2730, but without OZW, since I couldn't figure out one thing with that (I think it's just a symlink, or something trivial). If so, then probably I could provide updates (though I have to find a solution to grab the latest beta from github).
Jumbotroll
Jumbotroll
Jumbotroll
- LouiS22
Forgive me, I should have request more clearlyjumbotroll wrote:I do not have the spksrc files, USBSerialDrivers, source is made by Noam Lebovitz.Jumbotroll, may I request you to upload your modified spksrc files somewhere? I'm interested in 88f6281, I have successfully build my own versions up to 2730, but without OZW, since I couldn't figure out one thing with that (I think it's just a symlink, or something trivial). If so, then probably I could provide updates (though I have to find a solution to grab the latest beta from github).
Jumbotroll
- jumbotroll
I Use Gkroone spksrc files and have change the OpenZwave and domoticz version.LouiS22 wrote:Forgive me, I should have request more clearlyjumbotroll wrote:I do not have the spksrc files, USBSerialDrivers, source is made by Noam Lebovitz.Jumbotroll, may I request you to upload your modified spksrc files somewhere? I'm interested in 88f6281, I have successfully build my own versions up to 2730, but without OZW, since I couldn't figure out one thing with that (I think it's just a symlink, or something trivial). If so, then probably I could provide updates (though I have to find a solution to grab the latest beta from github).
JumbotrollI'm interested in the spksrc files for compiling domoticz.spk, not he USB drivers!
You can downlod it here : https://github.com/gkroone/spksrc/tree/Domoticz2563
Jumbotroll
Jumbotroll
- LouiS22
No additional changes at all? I use gkroone's repo too, but have problems compiling OZW. Thought you might have changed there something.I Use Gkroone spksrc files and have change the OpenZwave and domoticz version.
- jumbotroll
Same problem hereLouiS22 wrote:No additional changes at all? I use gkroone's repo too, but have problems compiling OZW. Thought you might have changed there something.I Use Gkroone spksrc files and have change the OpenZwave and domoticz version.
Cross Compiling fails after OpenZwave 1.3.328 Thats the reason I don't have updated.
I don't have time to look at it right now.
If you find a solution, let me know.
Jumbotroll
Jumbotroll
Jumbotroll
Many thanks. I downloaded, I will try.jumbotroll wrote: USBSerialDrivers_5.2_5592_Test.spk
Will the release, not a test version?
- jumbotroll
I do not have the spksrc files, USBSerialDrivers Source code is made by Noam Lebovitz.tehnoinstyle wrote:Many thanks. I downloaded, I will try.jumbotroll wrote: USBSerialDrivers_5.2_5592_Test.spk
Noam Lebovitz is the man that can make releases, not me
I only make some modifications from USBSerialDrivers_3.0.2.
But it seems that he have left the project, he haven't made new releases for a long time.
Jumbotroll
Jumbotroll
Jumbotroll
- LouiS22
Hehe. And now, after moving domoticz to github, there'll be another issue: to fix the source code download and correcting the version numbers.jumbotroll wrote:Same problem hereLouiS22 wrote:No additional changes at all? I use gkroone's repo too, but have problems compiling OZW. Thought you might have changed there something.I Use Gkroone spksrc files and have change the OpenZwave and domoticz version.
You can downlod it here : https://github.com/gkroone/spksrc/tree/Domoticz2563![]()
Jumbotroll
Hi, I've just installed the domoticz package, and im new to domoticz.
I am trying to get a script to run -
The script is place in /volume1/@appstore/domoticz/samplescripts/lua
However looking at the logs in never runs, do I need to do anything else to get the script to run -
permissions on the script is -rwxrwxrwx 1 root root 1842 Aug 21 14:36 script_device_sensorWU.lua
Any help is much appreciated.
- G3rard
- Target OS: -
- Domoticz version: No
The lua scripts that you want to use must be in domoticz/var/scripts/lua (or something like that, I am not in front of my PC right now so can not check).
I think my scripts have domoticz as user instead of root (again can't check that right now). So maybe change that as well.
Not using Domoticz anymore
- jumbotroll
On my Synology it is /volume1/@appstore/domoticz/var/scripts/lua
Jumbotroll
Jumbotroll
Jumbotroll
Jumbotroll
