Fibaro Dimmer 2 FGD-212 supported? New type!
kdejong01
Post by kdejong01 »
On Fibaro.com there is an article about à brand new dimmer. The FGD-212 is direct available in stores now.
New features: power consumption, status led, automatic light detection (led/traditional), scène support etc.
Is this brand new device supported in DOMOTICZ/open z-wave ?
xs4me
Re: Fibaro Dimmer 2 FGD-212 supported? New type!
Post by xs4me »
Yes it will, I have got the configuration already done, just waiting for the actual device to be delivered so I can test it and submit it to OZW.
pvm
Domoticz version: 4.10538
Post by pvm »
Nice i hope to get mine in a few weeks
mbliek
Post by mbliek »
This new module is available from 30th of July.
kdejong01
Post by kdejong01 »
I am very curious. I love to hear your experiences! I need three dimmers and i can wait :D
mbliek
Post by mbliek »
xs4me wrote:Yes it will, I have got the configuration is already done, just waiting for the actual device to be delivered so I can test it and submit it to OZW.
Could you send me the file? So I can test it when it arrives?
xs4me
Post by xs4me »
mbliek wrote:Could you send me the file? So I can test it when it arrives?
Sure you can find it here https://github.com/xs4/open-zwave/blob/ ... fgd212.xml
Config section is done, just untested, I am missing the type and id info to identify the device in the manufacturer_specific.xml file.
mbliek
Post by mbliek »
Thanks, Mine stock will arrive tomorrow.
xs4me
Post by xs4me »
Can you report the type and id info for the manufacturer_specific.xml file? And possible other issues? so I can complete the config and submit it to OZW?
mbliek
Post by mbliek »
Dimmer 2 is now available in my store.
Sorry they arrived very late. Haven't got time to test them yet.
Timbels
Domoticz version: V3.8747
Post by Timbels »
I'm getting this dimmer today!
What is the best way to test? Just put the .xml from xs4me in the /config/fibaro folder and include the dimmer with domoticz? (no need to change the id?)
Is it safe to do this in my existing stable database or is it better to wait till an experienced user adds this to the ozw database?
"newbie" here but willing to help/share! :)
xs4me
Post by xs4me »
The configuration has been submitted to OZW (see https://github.com/OpenZWave/open-zwave/pull/640)
(If you have copied an earlier version, please update.)
I am using the dimmer in a 3-wire setup with a 9.5W led bulb. Works like a charm.
Timbels
Post by Timbels »
Sounds good! (9.5W led bulb without bypass??)
Does the power metering also work?
I don't know how to update openzwave manually but i just copied over the 2 modified files. Hope that will also work.
Keep you updated! :)
mbliek
Post by mbliek »
Yes 9.5W led will work without bypass.
Here are my findings:
2-wire setup:
The Dimmer works correctly from 9.5W without bypass
Everything under 9.5W will need the bypass in a 2-wire setup (but the dimmer is reacting very strange when the dimmer is at 100%, parameter 2 should be at 50%).
3-wire setup:
The Dimmer works correctly from 7W without bypass
Everything under 7W will need the bypass in a 3-wire setup.
Timbels
Post by Timbels »
Also got it working!
Energy reading works really good.
Using it with 2 gu10 50w halogeen spots at the moment. Will replace them for 2 led spots very soon.
Its also really silent (no humming in the device,my old ones make a lot of noise)
Just out of curiosity, how many devices did it create in you're config? I got 9.
Added just 2 at the moment. (lighting/usage) The others don't seem to do much.. (Heat/Alarm Type/Alarm Level/Power Management/Level/System/Unknown).
mbliek
Post by mbliek »
Sorry. I have only tested it with the Fibaro Home Center.
mcmikev
Post by mcmikev »
Well got them today and I like them. So small so advanced.
Had trouble adding it to my setup but that was due to some corruption (see other topic) Now it is running and no flickering of the (free) led bulb.
Thanks @mbliek for the fast shipping !!
Anyone know how to switch a scene or switch a other z wave module when using a double pulse switch ?
One switches on the light and you can dim it, second button does nothing. Someone figured that part out with domoticz?
G3rard
Domoticz version: No
Post by G3rard »
This dimmer will not work with my Aeon Labs ZWave stick (no plus) I think?
Not using Domoticz anymore
mbliek
Post by mbliek »
G3rard wrote:This dimmer will not work with my Aeon Labs ZWave stick (no plus) I think?
Sure it will. The home centers of Fibaro doesn't have zwave plus ether.
G3rard
Post by G3rard »
mbliek wrote:Sure it will. The home centers of Fibaro doesn't have zwave plus ether.
That's interesting, will have a look at this dimmer.
