Netatmo thermostat support Topic is solved
joske522
Post by joske522 »
Hi guys,
Does anyone know how to integrate the Netatmo thermostat into Domoticz?
There is an API available: https://dev.netatmo.com/doc/devices/thermostat
Thanks in advance!
leplan73
Re: Netatmo thermostat support
Post by leplan73 »
Working on a native support !
I will keep you posted
Seb
gizmocuz
Post by gizmocuz »
joske522 wrote:Hi guys,
Thanks in advance!
Send you a PM
joske522
Post by joske522 »
Thanks guys! :-)
umbr3lla
Post by umbr3lla »
Hi, did you manage to get your Netatmo Thermostat linked with Domoticz. I also have a netatmo thermostat and would like to the same.
Any help would be great.
gizmocuz
Post by gizmocuz »
Just add it from the hardware settings, and supply your username/password
mcflyyy
Post by mcflyyy »
Any news on native support ?
umbr3lla
Post by umbr3lla »
gizmocuz wrote:Just add it from the hardware settings, and supply your username/password
This is only for if you have Netatmo Weatherstation.
Still waiting support for the thermostat device.
toutazimuth
Post by toutazimuth »
No news about the support of Netatmo thermostat ?
I'm very interesting about this support by Domoticz, for this new heating season.
Btw, the Domoticz support of the Netatmo weather station is so perfect ;)
Thx
gizmocuz
Post by gizmocuz »
If someone can send me PM with there login details, i can have a look at implementing support for this
toutazimuth
For me, this is the same account and password for netatmo station weather and netatmo thermostat.
For information, the team netatamo weather station and Domoticz, is currently perfect.
Thx for your amazing work
Mommeke
Post by Mommeke »
Did you get an account login already from somebody, to work on implementation?
If not, I'm prepared to provide mine...
For now I'm controlling my netatmo thermostat through shell scripts (via domotiga and smartvisu)
It seems to work although I'm not using the refreshtoken (cause I'm not sure how), so I think the authentication part is not the best way.
Also I'm not a bash nor json expert. So I'm sure this could be written a lot better. But it all works...
Sharing this anyway, maybe it helps people to do more with their thermostat. It's an example how the api can be called.
Feel free to comment and improve.
client_id and client_secret can be retrieved from dev.netatmo.com when you 'create an app'
device_id and module_id were found in the data reply (written to /tmp/netatmo_data)
email and pass are the ones used for logging in to the thermostat webinterface.
Obviously I replaced the real values with dummy ones for this post.
away.sh: execute 'away.sh On' to enable away mode on the thermostat
#!/bin/bash
#request token
curl -s -d "grant_type=password&client_id=12345&client_secret=6789&[email protected]&password=somepassword&scope=read_thermostat write_thermostat" "https://api.netatmo.net/oauth2/token" >/tmp/netatmo_token
#extract token values
access=`jq -r '.access_token' /tmp/netatmo_token`
refresh=`jq -r '.refresh_token' /tmp/netatmo_token`
#use token to request data
curl -s -d "access_token=$access" "https://api.netatmo.net/api/getthermostatsdata" >/tmp/netatmo_data
#extract data values
#this line seems to work best if not set to manual
setpoint=`jq -r '[.body.devices[].modules[].measured.setpoint_temp] | unique | .[]' /tmp/netatmo_data`
#this line seems better when set to manual mode, else the step up or down is calculated with a previous set value instead of the most current value. still have to figure this out better.
#setpoint=`jq -r '[.body.devices[].modules[].setpoint.setpoint_temp] | unique | .[]' /tmp/netatmo_data`
temp=`jq -r '[.body.devices[].modules[].measured.temperature] | unique | .[]' /tmp/netatmo_data`
mode=`jq -r '[.body.devices[].modules[].setpoint.setpoint_mode] | .[]' /tmp/netatmo_data`
# echo some values
if [ "$mode" == "away" ]
then status="On"
status="Off"
fi
echo "$status"
echo "$setpoint"
echo "$temp"
#switch
if [ "$1" == "On" ]
then
#set to away
curl -s -d "access_token=$access&device_id=70:ee:50:12:34:56&module_id=04:00:00:12:34:56&setpoint_mode=away" "https://api.netatmo.net/api/setthermpoint" >/dev/null
fi
replace setpoint_mode=away with setpoint_mode=program for normal operation (follows your schedule) or with setpoint_mode=hg for antifrost. Adjust the
line accordingly.
this script sets the desired temperature 0,5 degrees celcius higher for one hour: execute as "up.sh On"
#!/bin/bash
#request token
#setpoint=`jq -r '[.body.devices[].modules[].measured.setpoint_temp] | unique | .[]' /tmp/netatmo_data`
tijd=`jq -r '[.body.devices[].modules[].measured.time] | unique | .[]' /tmp/netatmo_data`
# echo some values
if [ "$mode" == "manual" ]
then status="On"
status="Off"
fi
echo "$status"
echo "$setpoint"
echo "$temp"
#switch
if [ "$1" == "On" ]
then
#calculate new temp
step="0.5"
newtemp=`echo "($setpoint + $step)" | bc`
#endtime
end=`date -d '+1 hour' "+%s"`
#increase temp
curl -s -d "access_token=$access&device_id=70:ee:50:12:34:56&module_id=04:00:00:12:34:56&setpoint_mode=manual&setpoint_temp=$newtemp&setpoint_endtime=$end" "https://api.netatmo.net/api/setthermpoint"
fi
to lower the temperature instead, you can use almost the same script but replace the + with a -
newtemp=`echo "($setpoint - $step)" | bc`
more options and documentation at https://dev.netatmo.com/doc
DomoArie
Domoticz version: 3.5877
Post by DomoArie »
Hi, I am wondering where this very good start of getting Netatmo thermostat integrated into Domoticz is at the moment.
I am considering buying this piece, but would like to steer it from my RBpi2 with Domoticz.
@Mommeke did put some interesting scripting material in this topic, but I noticed @gizmocuz was also active here... Any news and advise?
sbebrone
Post by sbebrone »
I've submitted a PR to support this hardware last night:
https://github.com/domoticz/domoticz/pull/188
Following features are supported:
  • Temperature sensor
    Set point switch
Should be easy to add support for "away" mode switch.
Hope it'll get to the main repo soon. Feeback are more than welcome :)
Gtz,
Stéphane.
gizmocuz
Post by gizmocuz »
sbebrone wrote:Hi,
    Set point switch
Gtz,
Stéphane.
Hello Stephane,
Thank you very much for the hard work, left a bit feedback on github
Is it possible to send me a PM with the credentials so i can test it ? I think i want to merge this code in the existing netatmo class, and maybe if needed add a special constructor so we can differentiate it
course66
Domoticz version: V2.3202
Post by course66 »
Hi gizmocuz,
if you need user/password to test netatmo thermostat over domoticz I can provide it to you.
ciao,
gabriele
gizmocuz
Post by gizmocuz »
course66 wrote:Hi gizmocuz,
ciao,
gabriele
I am also working on this with Stephane, but yes this would help a lot (double testing), send you a PM
Thanks in advance
qqlapraline
Post by qqlapraline »
I own a Netatmo thermostat and would be happy to help.
I guess I have to explicitely get the sources, recompile and run it ?
If this is the case, it will want for next weekend or the week after.
As I understand this is done as a new hardware, would that be possible to merge to the trunk so that I can't get this and try it ?
Regards.
QQ.
3 Raspberry PI (Raspbian + Rfxcom, teleinfo or mysensors gateway)
Bunch of OS THGR810n (5)
Some THN122
1 WGR800 and PCR800
Some BMP085
Bunch of TS34C (4)
Bunch of DIO plugs (3)
Teleinfo
Various mysensors devices (Temp, Hygro, ...)
gizmocuz
Post by gizmocuz »
I think it should work now in the latest beta version
course66
Post by course66 »
Yes, it works: thermostat temperature, away switch and set-point (only minor issues with set-point)
ciao,
gabriele
