Siri / HomeKit support for Domoticz
Heisenberg
Re: Siri / HomeKit support for Domoticz
Post by Heisenberg »
Thnx for the quick reply. Just to make sure I also reset Homekit configuration on my iPhone and started adding devices to Eve.
Raspberry Pi Type B
Raspberry Pi Type B2
RFXCOMtrx433e
drogert
Post by drogert »
Ok, I've got the homebridge server working and it responds when I try to connect with EVE or Insteon+. Only when I do so, I see some kind of node bridge to add as a device in the two apps. When I add the device it gives me a couple of devices which are not added in the roomplan(garagedoor, fan etc) i've set up in the config.json. It also does not responds to my commands when I talk to siri. (it says sometimes that the lights are switches off/on, when they are not responding at all, and sometimes it says it didnt find the lights.) removing the items in the persistent folder and reseting homekit does not make a difference...
Does anyone know what is going wrong?
RPI 3b+, PiFace 2, RFcom, Aeon Zwave USB, Aeon Home Energy Meter Gen 5, several Shelly switches, several ESP8266 sensors.
ivom74
Post by ivom74 »
Is there a solutions if i use secure web login on the website? Username and password required?
I really like the Siri solution but don't want to open my domoticz website.
drogert
Post by drogert »
Ok, after trying everything... Even buying a new Raspi 2 I have still no luck getting SIRI to work for me...
After allot of searching I see this in the output of people who are having a working example:
[Domoticz] TCP server accepting connection on port: 64708
HAP Server is listening
[Domoticz] Initializing device with name Study Printer...
[Domoticz] Loaded services for Study Printer
This is something I DO NOT get. It only states:
[pi@domoticzpi ~/homebridge/lib/HAP-NodeJS $ npm run start
> [email protected] start /home/pi/homebridge/lib/HAP-NodeJS
> node BridgedCore.js
*** WARNING *** The program 'node' uses the Apple Bonjour compatibility layer of Avahi.
*** WARNING *** Please fix your application to use the native API of Avahi!
*** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node>
*** WARNING *** The program 'node' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
*** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node&f=DNSServiceRegister>
HAP-NodeJS starting...
Cannot find secret key, creating One...
TCP server accepting connection on port: 51826
HAP Server is listening[
Which makes me believe the config.json is not working or the Server does not pull all the switches from domoticz or cannot connect with domoticz.
This is the config.json I use:
    "description": "Configuration file for Domoticz platform.",
    "platforms": [
            "platform": "Domoticz",
            "name": "Domoticz",
            "server": "192.168.1.150",
            "port": "8080",
            "roomid": 9,
            "usescenes": 0
    "accessories": [
Could anybody please help me because I think I have tried every option right now and still no luck.
terrarium
Post by terrarium »
/home/pi/homebridge/lib/HAP-NodeJS/node_modules/mdns/lib/advertisement.js:56
  dns_sd.DNSServiceRegister(self.serviceRef, flags, ifaceIdx, name,
Error: argument 8: port number is out of bounds.
    at Error (native)
    at new Advertisement (/home/pi/homebridge/lib/HAP-NodeJS/node_modules/mdns/lib/advertisement.js:56:10)
    at Object.create [as createAdvertisement] (/home/pi/homebridge/lib/HAP-NodeJS/node_modules/mdns/lib/advertisement.js:64:10)
    at Object.startAdvertising (/home/pi/homebridge/lib/HAP-NodeJS/Advertiser.js:7:28)
    at Object.publishAccessory (/home/pi/homebridge/lib/HAP-NodeJS/Accessory.js:10:29)
    at createHAPServer (/home/pi/homebridge/app.js:167:15)
    at /home/pi/homebridge/app.js:92:17
    at Request._callback (/home/pi/homebridge/platforms/Domoticz.js:62:5)
    at Request.self.callback (/home/pi/homebridge/node_modules/request/request.js:373:22)
    at Request.emit (events.js:110:17)
I have had this same error. This occurred after a reinstall of HomeKit. Somewhere (or in /root or elsewhere a config file still remains form a previous install. I resolved this by editing the config.json and changing name = "Domoticz" to a different value. That resolved the error. Hope this helps.
drogert
Post by drogert »
Found it!
Maybe you should add the line in the wiki where it states:
Start
Go to the homebridge directory
-> ADD THIS: cd homebridge (or something like this)
npm run start
For the noobs which can't always know which directory to start npm. Anywayz... thanks!
menno.vanmunster
Domoticz version: V4.9700
Post by menno.vanmunster »
I had this problem also, i using a passwor wheni remove the login then it is working fine...
drogert wrote:Ok, after trying everything... Even buying a new Raspi 2 I have still no luck getting SIRI to work for me...
> node BridgedCore.js
    "platforms": [
            "name": "Domoticz",
            "port": "8080",
            "roomid": 9,
            "usescenes": 0
    "accessories": [
h143
Post by h143 »
do sombody know if it is posible to show my temperature with homekit?
tcviper
Post by tcviper »
Everything seems to work but making it run forever:
pi@raspberrypi ~/homebridge $ npm install forever
npm WARN prefer global [email protected] should be installed with -g
[email protected] node_modules/forever
forever start app.js
-bash: forever: command not found
I followed:
Start at reboot
npm install forever
cd homebridge
G3rard
Domoticz version: No
Post by G3rard »
I have used "sudo npm install forever". I think that was the solution for this issue.
Not using Domoticz anymore
tcviper
Post by tcviper »
Yep is it indeed and with the -g option aswell.
h143
Post by h143 »
i have try to start homebridge at startup
i have try
sudo npm install forever -g
cd homebridge
sudo forever start /home/pi/homebridge/app.js
and get the follow response:
warn: --minUptime not set. Defaulting to: 1000ms
warn: --spinSleepTime not set. Your script will exit if it does not stay up for at least 1000ms
info: Forever processing file: /home/pi/homebridge/app.js
but i doesnt start when i reboot the raspberry
ivom74
Post by ivom74 »
h143 wrote:i have try to start homebridge at startup
i have try
cd homebridge
Same errors here. And I still wondering how I can setup a secure login to Domoticz website? Inlogname en password are of course required, but wil homebridge work then?
G3rard
Post by G3rard »
i have try
cd homebridge
Those are not errors. I have the same respone, it are just warnings and in the info part you can see that app.js is being processed.
After a reboot you indeed have to run forever again. There will certainly be a solution were you can autostart it after a reboot, check Google for that.
I think you can use username:password@IP in config.json.
h143
Post by h143 »
i have it working on my raspberry by installing it from the begin.
i can set in domoticz the adjustment of the lights is this with homebridge also posible?
the show only as light and not a dimmer.
ivom74
Post by ivom74 »
How further?
I started NPM, How can I test it?
The description on http://www.musified.nl/index.php/2015/0 ... z-homekit/ says that I have to install the app on like Insteon+ and search the server.
pi@domoticzpi ~ $ npm run start
npm ERR! Linux 3.18.16+
npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "run" "start"
npm ERR! node v0.12.1
npm ERR! npm v2.5.1
npm ERR! path /home/pi/package.json
npm ERR! code ENOENT
npm ERR! errno -2
npm ERR! enoent ENOENT, open '/home/pi/package.json'
npm ERR! enoent This is most likely not a problem with npm itself
npm ERR! enoent and is related to npm not being able to find a file.
npm ERR! enoent
npm ERR! Please include the following file with any support request:
npm ERR! /home/pi/npm-debug.log
What app and how can I test if NPM have a good secure connection to the domoticz server?
nigels0
Domoticz version: 3.8153
Post by nigels0 »
Well I've also got it working, but the device database doesn't seem to work well. Although it tends to read the list of devices, it removes a number of them due to already being in the database - though when looking for them in the Eve app, they are not there. I did notice that where I previously had deleted the device from the Eve app, then they would not appear again (because of this duplicate database record thingy). I've completely re-installed Domoticz, but the missing devices issue is the same.
I suspect that I need to clear the database in HomeKit, but really don't know how to do this.
pvm
Domoticz version: 4.10538
Post by pvm »
You can clear the persistancy directory, mentioned some posts ago
nigels0
Post by nigels0 »
Sure - but the database seems to reside in the HomeKit database as a fresh install of Domoticz image didn't clear it as I mentioned earlier.
G3rard
Post by G3rard »
nigels0 wrote:Sure - but the database seems to reside in the HomeKit database as a fresh install of Domoticz image didn't clear it as I mentioned earlier.
Also clear the Homekit settings in your iPhone. Go to Settings, Privacy, Homekit and then you can reset Homekit configuration.
Users browsing this forum: felek and 1 guest
