domoticz in synology as package! Available now.
jumbotroll
Post by jumbotroll »
RogerSch wrote:Hello Jumbotroll, I've added your link to my packages in my Synology DS413j (Marvell Kirkwood mv6282). I have already enabled that the all packages are allowed. But unfortunately your version of the Domoticz doesn't appear on the list. I only see the older version of the SynoCommunity. Is it correct that your package list doesn't contain a version for the 413j? Is there a specific reason for like hardware limitation?
Thanks in advance for your reply.
Try this: http://jadahl.dscloud.me/sspks/
Remember this is just Beta for DSM 5.2. 8-)
Jumbotroll
https://paypal.me/Jumbotroll
Jumbotroll
http://www.jadahl.com
RogerSch
Post by RogerSch »
Cool thanks. Installation gave no errors and I can access the Web front-end..
Now I need to order an RFXcom in order to control my Somfy screens. :)
Thanks again for the fast reply.
jumbotroll
Nice!
Remember to order RFXtrx433E version with Somfy support.
Jumbotroll
steef84
Domoticz version: DS213+
Post by steef84 »
Using the precompiled package from Jumbo also with pleasure... But got an issue. It seems the System Alive Checker does not seems to function on my system. My arch is qoriq. Does this function works on other Syno architectures? Im aware of the python script presence detection but wanna try the buildin native ping functionality...
- Stefan
G3rard
Domoticz version: No
Post by G3rard »
The system alive checker doesn't work on my Synology (x86 version) as well.
Not using Domoticz anymore
kraades
Domoticz version: Stable
Post by kraades »
Any idea when the DS715 (alpine) will be supported? Thank you!
jumbotroll
kraades wrote:Any idea when the DS715 (alpine) will be supported? Thank you!
Hi.
I have compiled a test for you here 8-)
Remember this is Beta!
http://jadahl.dscloud.me/sspks/?arch=alpine
Jumbotroll
Jumbotroll
kraades
Post by kraades »
Great! Thanks a lot Jumbotroll! I will let you know how it works...
kraades
Post by kraades »
I wanted to let you know that the package works on the DS715. I see data on the P1 Smart Meter USB.
Thanks again!
BTW
Minor minor detail:
In Package Center the Developer show as SynoCommunity/ (with a trailing slash?), shouldn't this be Jumbotroll or something?
jumbotroll
kraades wrote:I wanted to let you know that the package works on the DS715. I see data on the P1 Smart Meter USB.
Thanks again!
BTW
Minor minor detail:
The "SynoCommunity/" is just a typo :shock:
Fixed in this build:
Jumbotroll
kraades
Post by kraades »
Yes, installed the update. Thanks again for your work.
BTW
Now we are at it...
The Domoticz picture shows Beta, but the package also shows up in the list when the option "Yes, I want to see beta version!" is disabled at Package Center, Settings, Beta.
Nitpicking I know... :D
jumbotroll
G3rard wrote:The system alive checker doesn't work on my Synology (x86 version) as well.
Think I found the problem with system alive checker.
Domoticz have to run as root.
Now it´s working on my DS712+ arch=x86
You can manually download new build here and test.
domoticz_x86-5.2_2.0.2619-7
Jumbotroll
jumbotroll
steef84 wrote:Using the precompiled package from Jumbo also with pleasure... But got an issue. It seems the System Alive Checker does not seems to function on my system. My arch is qoriq. Does this function works on other Syno architectures? Im aware of the python script presence detection but wanna try the buildin native ping functionality...
Fixed!
I have compiled with fix for qoriq.
domoticz_qoriq-5.2_2.0.2619-7.spk
Jumbotroll
steef84
Post by steef84 »
Nice.... ... will try later and report.... thanks
EDIT: working like a charm!
- Stefan
Giome
Post by Giome »
I'm new in this forum and for using Domoticz. I manage my user account by LDAP server and I can't see the Domoticz's icon when I'm logged with LDAP account. I think a modification like this in the config file can fix this :
- "allUsers": true,
- "grantPrivilege": "local"
+ "allUsers": false
Also, my NAS is configure to be only on ssl (https) and I have a domain and a certificate but I can't access to Domoticz with this address : https://mydomain.info:8084
My router is already configure for this port.
Can you help me please.
For information : NAS RS2414+ with DSM 5.2-5592 and Domoticz 2.0.2644-7
Thanks a lot
kraades
Post by kraades »
If I reboot the Synology I experience two problems:
1. The usb ports are not always linked to the same usb device (rfxcom, p1 cable)
2. I always need to unplug the usb device one time before the usb devices are recognized again in Domoticz
For the first issue I have added the following script:
DS715> cat 50-tty-serial.rules
SUBSYSTEM!="tty", GOTO="tty_end"
ATTRS{idVendor}=="0403", ATTRS{idProduct}=="6001", ATTRS{product}=="RFXtrx433", SYMLINK+="ttyUSB21"
ATTRS{idVendor}=="0403", ATTRS{idProduct}=="6001", ATTRS{product}=="P1 Converter Cable", SYMLINK+="ttyUSB22"
LABEL="tty_end"
DS715>
This creates a symlink that can be used in Domoticz:
DS715> ls -las /dev/ttyUSB*
   0 crw-rw-rw-    1 root     root      188,   0 Jul 11 11:02 /dev/ttyUSB0
   0 crw-rw-rw-    1 root     root      188,   1 Jul 11 11:00 /dev/ttyUSB1
   0 lrwxrwxrwx    1 root     root             7 Jul 11 11:00 /dev/ttyUSB21 -> ttyUSB0
   0 lrwxrwxrwx    1 root     root             7 Jul 11 11:00 /dev/ttyUSB22 -> ttyUSB1
DS715>
Any ideas how to fix the second issue?
BTW
The following script was already present:
DS715> cat 60-synocommunity.domoticz.rules
#rules for USB ACM serial devices
KERNEL=="ttyACM*", ACTION=="add", MODE="0666"
KERNEL=="ttyUSB*", ACTION=="add", MODE="0666"
DS715>
apepannetje
Post by apepannetje »
Any idea when the DS215+ (annapurna) will be supported? Thank you!
jumbotroll
apepannetje wrote:Any idea when the DS215+ (annapurna) will be supported? Thank you!
Have you tested Alpine build?
I have compiled domoticz_alpine-5.2_2.0.2619-7.spk and Alpine and Alpine4K uses same toolchain.
Manually download this file and try to install.
http://jadahl.dscloud.me/sspks/packages ... 2619-7.spk
Jumbotroll
Jumbotroll
apepannetje
Jumbotroll
It Works!!!
i have only one problem.
i cant see te pictogram from Domoticz on my Desk
Update!!!!!!!!
After restart i can see the icon on my desk
Regards Apepannetje
Hartenj
Post by Hartenj »
I have a DS213+ running DSM 5.2-5592 Update 1 with Domotics V2.2621 set up as master
The slave is A Exchange 2008 server running Domoticsz V2.2657 and Open Hardware monitor to monitor it's motherboard sensors
The connectivity between Master and slave is OK, remote sensors from the Exchange server show up but the info is completely meaningless.
Is the an issue on the Synology, if not which versions work together or...... even better.... van we expect V2.2657 for the Synology and does this solve the issue?
