need some help making a hardware plugin (UniPi)
spudgunman
Post by spudgunman »
I have checked out some of the basics, but could use a little help here..
I want to make a new hardware device for domoticz that will make JSON calls the device will have a few relays and digital sensors and would like to have it as easy to use as possible (hence the hardware addition)
can anyone help I am not good with CPP but could fumble around if I have a example of something like this working.
Reason: Edited topictitle ('UniPi' added).
Dnpwwo
Re: need some help making a hardware plugin
Post by Dnpwwo »
I assume you looked at http://www.domoticz.com/wiki/Developing ... are_plugin.
There are plugins that use JSON that you can copy, not a trivial task tho.
spudgunman
Yes I did see that haven't found a clear path yet.
Which plugins that use JSON that I can copy - if I can find a good start of the path I can stumble along. Right now finding a starting point that isn't ground zero would be nice
I see that the ecodevices has JSON include, and yea I see its not an easy task..
spudgunman
I am attempting to make the unipi hardware compatible with domoticz BTW http://unipi.technology/
its likely over my head, but I am going to give it a shot.
BlackSoll
Domoticz version: 3.5877
Post by BlackSoll »
Hi ! Me too having big trouble with unipi.
Did you make any progress ?
Not much a software guy, so any help would be appreciated.
spudgunman
BlackSoll wrote:Hi ! Me too having big trouble with unipi.
I am slowly making a LUA scrip that will handle it all i think.. hold tight for a bit I only work on it once a week but I have good stuff so far.
BlackSoll
Re: need some help making a hardware plugin (UniPi)
Post by BlackSoll »
I can beta test your LUA script for unipi. I'm not that smart too to make my own C++ file.........
I can't sent pm cause i am new here without many posts and forum board doen't let me.
dejf
Post by dejf »
Hi guyes some progress in Unipi board and domoticz?
Users browsing this forum: willemd and 1 guest
