Yeah pleasemarkk wrote:Hi Tlpetertlpeter wrote:Hi Hans i know, that is the problem![]()
I use a different script now and i have it working.
But thanks anyway.
Would you mind sharing your windows script please?
Mark
Is it gonna rain within the next X minutes?
- Brutus
Re: Is it gonna rain within the next X minutes?
1x Intel NUC8i5BEK (Windows 10 x64) Domoticz on Virtualbox with DietPi.
1x Aeon Labs USB Z-Stick S2
1x P1 Smart Meter USB
28x Fibaro Modules
SMA Solar System
Daikin Airco / Heating
Denon DHT-S716H & DSW-1H
28x Fibaro Modules
SMA Solar System
Luuc_a
I have taken the script of tlpeter and made it to my needs.
I have done the following
- Integrate the script with the rain prediction of 'buienradar'.
- made user variables from the thresholds in Domoticz so I can control it from the web interface.
There is a little question. In the settings of Domoticz you can set the langitude and longitude. Is it possible to read this out by LUA?
-- LUA Script
-- Extract values from Weather Underground device and 'Buienradar'-rain
-- prediction to control the sunscreen
-- Auteur: Luuc_A
-- Datum : 29-05-2014
-- Setup uservariables:
-- 1) Weather_Debug = String = True / False
-- 2) Weather_WindSpeedThreshold = integer
-- 3) Weather_WindGustThreshold = integer
-- 4) Weather_RainThreshold = integer
-- 5) Weather_UVThreshold = integer
-- 6) Weather_TempThreshold = integer
-- Create Switches:
-- 1) Regen = Dummy Humiditysensor
-- 2) WindSnelheid = Dummy Text
-- 3) WindRichting = Dummy Text
-- 4) Barometer = Weather Underground/Forecast IO
-- 5) Wind = Weather Underground/Forecast IO
-- 6) Regen = Weather Underground/Forecast IO
-- 7) Zon = Weather Underground/Forecast IO
-- 8) Zonnescherm = Up/Down switch
-- 9) Zonnescherm manual override = Dummy switch
-- Variabelen
lat='52.025526' -- example lat/lon for Gouda
lon='4.692806'
sDebug = tostring(uservariables["Weather_Debug"])
UVThreshold = uservariables["Weather_UVThreshold"]
WindSpeedThreshold = uservariables["Weather_WindSpeedThreshold"]
WindGustThreshold = uservariables["Weather_WindGustThreshold"]
RainThreshold = uservariables["Weather_RainThreshold"]
TempThreshold = uservariables["Weather_TempThreshold"]
tempfilename = '/var/tmp/rain.tmp' -- can be anywhere writeable
idx = 220 --idx regen
idx2 = 221 -- idx windrichting
idx3 = 222 -- idx windsnelheid
minuten = 5
sBarometer = 'Barometer Gouda'
sWind = 'Wind Gouda'
sRain = 'Regen Gouda'
sUV = 'UV Gouda'
sSolar = 'Zon Gouda'
--Sunscreen thresholds:
-- Windspeed = 100.0 (value is multiplied by 100)
-- Rain = 0.0
-- UV = 2.0
-- Temperature = 12.0
-- Closed = Down = On
-- Open = Up = Off
-- Functies
function Message(fMessage, fDebug)
if (fDebug == "True") then
print("Weather: " .. fMessage)
function Notification(fNotification, fDebug)
if (fDebug == "False") then
commandArray['SendNotification'] = "" .. fNotification .. ""
function IsItGonnaRain( minutesinfuture )
url='http://gps.buienradar.nl/getrr.php?lat='..lat..'&lon='..lon
Message("-- "..url,sDebug)
read = os.execute('curl -s -o '..tempfilename..' "'..url..'"')
file = io.open(tempfilename, "r")
totalrain=0
rainlines=0
-- now analyse the received lines, format is like 000|15:30 per line.
while true do
line = file:read("*line")
if not line then break end
Message("-- Line:" ..line,sDebug)
linetime=string.sub(tostring(line), 5, 9)
Message("-- Linetime: "..linetime,sDebug)
-- Linetime2 holds the full date calculated from the time on a line
linetime2 = os.time{year=os.date('%Y'), month=os.date('%m'), day=os.date('%d'), hour=string.sub(linetime,1,2), min=string.sub(linetime,4,5), sec=os.date('%S')}
difference = os.difftime (linetime2,os.time())
-- When a line entry has a time in the future AND is in the given range, then totalize the rainfall
if ((difference > 0) and (difference<=minutesinfuture*60)) then
Message("-- Line in time range found",sDebug)
rain=tonumber(string.sub(tostring(line), 0, 3))
totalrain = totalrain+rain
rainlines=rainlines+1
Message("-- Rain in timerange: "..rain,sDebug)
Message("-- Total rain now: "..totalrain,sDebug)
file:close()
averagerain=totalrain/rainlines
return(averagerain)
regen = IsItGonnaRain(minuten)
Message("-- Regen verwacht: "..regen.." binnen "..minuten.." minuten.",sDebug)
if (regen > 0 ) then verw = 3 else verw = 2 end
--Weatherstation data:
sWeatherTemp, sWeatherHumidity, sWeatherUV, sWeatherPressure, sWeatherUV2 = otherdevices_svalues[sBarometer]:match("([^;]+);([^;]+);([^;]+);([^;]+);([^;]+)")
sWeatherTemp = tonumber(sWeatherTemp);
sWeatherHumidity = tonumber(sWeatherHumidity);
sWeatherPressure = tonumber(sWeatherPressure);
sWeatherUV = tonumber(sWeatherUV);
sWeatherUV2 = tonumber(sWeatherUV2);
Message("______________________________________________________________________________________",sDebug)
Message("Weather station: Temperature is " .. sWeatherTemp .. " ",sDebug)
Message("Weather station: Humidity is " .. sWeatherHumidity .. " ",sDebug)
Message("Weather station: Pressure is " .. sWeatherPressure .. " ",sDebug)
Message("Weather station: UV is " .. sWeatherUV .. " ",sDebug)
Message("Weather station: UV2 is " .. sWeatherUV2 .. " ",sDebug)
--Windmeter data:
sWindDirectionDegrees, sWindDirection, sWindSpeed, sWindGust, sWindTemperature, sWindFeel = otherdevices_svalues[sWind]:match("([^;]+);([^;]+);([^;]+);([^;]+);([^;]+);([^;]+)")
sWindDirectionDegrees = tonumber(sWindDirectionDegrees);
sWindDirection = (sWindDirection);
sWindSpeed = tonumber(sWindSpeed);
sWindGust = tonumber(sWindGust);
sWindTemperature = tonumber(sWindTemperature);
sWindFeel = tonumber(sWindFeel);
Message("Windmeter: Winddirection (in degrees) is: " .. sWindDirectionDegrees .. " ",sDebug)
Message("Windmeter: Winddirection is: " .. sWindDirection .. " ",sDebug)
Message("Windmeter: Windspeed is: " .. sWindSpeed .. " ",sDebug)
Message("Windmeter: Windgust is: " .. sWindGust .. " ",sDebug)
Message("Windmeter: Windtemperature is: " .. sWindTemperature .. " ",sDebug)
Message("Windmeter: Windfeel is: " .. sWindFeel .. " ",sDebug)
Message("______________________________________________________________________________________")
--Rainmeter data:
sRainmeterCurrent, sRainmeterTotal = otherdevices_svalues[sRain]:match("([^;]+);([^;]+)")
sRainmeterCurrent = tonumber(sRainmeterCurrent);
sRainmeterTotal = tonumber(sRainmeterTotal);
Message("Rainmeter: Actual rain is: " .. sRainmeterCurrent .. " ",sDebug)
Message("Rainmeter: Total rain is: " .. sRainmeterTotal .. " ",sDebug)
Message("Rainmeter: Predicted rain is: " .. regen .. " ",sDebug)
--UV data:
sUV = otherdevices_svalues[sUV]:match("([^;]+)")
sSolar = otherdevices_svalues[sSolar]:match("([^;]+)")
sUV = tonumber(sUV);
sSolar = tonumber(sSolar);
Message("UV: UV Strength is: " .. sUV .." ",sDebug)
Message("UV: Solar radiation is: " .. sSolar .." ",sDebug)
--Thresholds:
Message("Thresholds: Temp threshold is: " .. TempThreshold .." ",sDebug)
Message("Thresholds: UV threshold is: " .. UVThreshold .." ",sDebug)
Message("Thresholds: WindSpeed threshold is: " .. WindSpeedThreshold .." ",sDebug)
Message("Thresholds: WindGust threshold is: " .. WindGustThreshold .." ",sDebug)
Message("Thresholds: Rain threshold is: " .. RainThreshold .." ",sDebug)
if (timeofday['Daytime']) then
Message('It is past sunrise, monitoring variables for sunscreen',sDebug)
if (otherdevices['Zonnescherm'] == 'Open' ) then
Message ('Sunscreen is up',sDebug)
Message ('Sunscreen is down',sDebug)
and sRainmeterCurrent == RainThreshold
and sWeatherTemp > TempThreshold
and sUV > UVThreshold
and sWindSpeed < WindSpeedThreshold
and sWindGust < WindGustThreshold)
then
Message ('Sun is shining, all thresholds OK, lowering sunscreen',sDebug)
Message('______________________________________________________________________________________',sDebug)
Notification('Sunscreen#Sunscreen down --> Sun is shining',sDebug)
commandArray['Zonnescherm']='On'
elseif (otherdevices['Zonnescherm'] == 'Closed' and (sRainmeterCurrent > RainThreshold or regen > 0)) then
Message ('It is raining, raising sunscreen')
Notification('Sunscreen#Sunscreen up --> It is raining',sDebug)
commandArray['Zonnescherm']='Off'
elseif (otherdevices['Zonnescherm'] == 'Closed' and sWeatherTemp < TempThreshold and otherdevices['Zonnescherm manual override'] == 'Off') then
Message ('Temperature too low, raising sunscreen',sDebug)
Notification('Sunscreen#Sunscreen up --> It is too cold',sDebug)
elseif (otherdevices['Zonnescherm'] == 'Closed' and sUV < UVThreshold and otherdevices['Zonnescherm manual override'] == 'Off') then
Message ('Sun not shining too bright, raising sunscreen',sDebug)
Notification('Sunscreen#Sunscreen up --> Sunshine not too bright',sDebug)
elseif (otherdevices['Zonnescherm'] == 'Closed' and sWindSpeed > WindSpeedThreshold) then
Message ('Windspeed too high, raising sunscreen',sDebug)
Notification('Sunscreen#Sunscreen up --> Windspeed too high',sDebug)
elseif (otherdevices['Zonnescherm'] == 'Closed' and sWindGust > WindGustThreshold) then
Message ('Windgust too high, raising sunscreen',sDebug)
Notification('Sunscreen#Sunscreen up --> Windgust too high',sDebug)
Message('Sunscreen status OK --> No action',sDebug)
::done::
Message("At the end of the script",sDebug)
elseif (timeofday['Nighttime'] and otherdevices['Zonnescherm'] == 'Closed') then
Message('It is night, raising sunscreen',sDebug)
Notification('Sunscreen#Sunscreen up --> It is night',sDebug)
Message('Sunscreen already up --> No action',sDebug)
commandArray[1] = {['UpdateDevice'] = idx .. '|'..tostring(regen)..'|'..tostring(verw)}
commandArray[2] = {['UpdateDevice'] = idx2 .. '|0|'.. sWindDirection}
commandArray[3] = {['UpdateDevice'] = idx3 .. '|0|'.. sWindSpeed}
return CommandArray
Justintime
Thanks for the script. I tested it (only on temperature).Luuc_a wrote:I have taken the script of tlpeter and made it to my needs.
There is a little question. In the settings of Domoticz you can set the langitude and longitude. Is it possible to read this out by LUA?Code: Select all
----------------------------------------------------------------------------- -- LUA Script -- Extract values from Weather Underground device and 'Buienradar'-rain -- prediction to control the sunscreen -- Auteur: Luuc_A -- Datum : 29-05-2014 ----------------------------------------------------------------------------- -- Setup uservariables: -- 1) Weather_Debug = String = True / False -- 2) Weather_WindSpeedThreshold = integer -- 3) Weather_WindGustThreshold = integer -- 4) Weather_RainThreshold = integer -- 5) Weather_UVThreshold = integer -- 6) Weather_TempThreshold = integer -- Create Switches: -- 1) Regen = Dummy Humiditysensor -- 2) WindSnelheid = Dummy Text -- 3) WindRichting = Dummy Text -- 4) Barometer = Weather Underground/Forecast IO -- 5) Wind = Weather Underground/Forecast IO -- 6) Regen = Weather Underground/Forecast IO -- 7) Zon = Weather Underground/Forecast IO -- 8) Zonnescherm = Up/Down switch -- 9) Zonnescherm manual override = Dummy switch ----------------------------------------------------------------------------- commandArray = {} ------------------------------------------------------------------------ -- Variabelen lat='52.025526' -- example lat/lon for Gouda lon='4.692806' sDebug = tostring(uservariables["Weather_Debug"]) UVThreshold = uservariables["Weather_UVThreshold"] WindSpeedThreshold = uservariables["Weather_WindSpeedThreshold"] WindGustThreshold = uservariables["Weather_WindGustThreshold"] RainThreshold = uservariables["Weather_RainThreshold"] TempThreshold = uservariables["Weather_TempThreshold"] tempfilename = '/var/tmp/rain.tmp' -- can be anywhere writeable idx = 220 --idx regen idx2 = 221 -- idx windrichting idx3 = 222 -- idx windsnelheid minuten = 5 sBarometer = 'Barometer Gouda' sWind = 'Wind Gouda' sRain = 'Regen Gouda' sUV = 'UV Gouda' sSolar = 'Zon Gouda' ------------------------------------------------------------------------ --Sunscreen thresholds: -- Windspeed = 100.0 (value is multiplied by 100) -- Rain = 0.0 -- UV = 2.0 -- Temperature = 12.0 -- Closed = Down = On -- Open = Up = Off ------------------------------------------------------------------------ -- Functies function Message(fMessage, fDebug) if (fDebug == "True") then print("Weather: " .. fMessage) end end function Notification(fNotification, fDebug) if (fDebug == "False") then commandArray['SendNotification'] = "" .. fNotification .. "" end end function IsItGonnaRain( minutesinfuture ) url='http://gps.buienradar.nl/getrr.php?lat='..lat..'&lon='..lon Message("-- "..url,sDebug) read = os.execute('curl -s -o '..tempfilename..' "'..url..'"') file = io.open(tempfilename, "r") totalrain=0 rainlines=0 -- now analyse the received lines, format is like 000|15:30 per line. while true do line = file:read("*line") if not line then break end Message("-- Line:" ..line,sDebug) linetime=string.sub(tostring(line), 5, 9) Message("-- Linetime: "..linetime,sDebug) -- Linetime2 holds the full date calculated from the time on a line linetime2 = os.time{year=os.date('%Y'), month=os.date('%m'), day=os.date('%d'), hour=string.sub(linetime,1,2), min=string.sub(linetime,4,5), sec=os.date('%S')} difference = os.difftime (linetime2,os.time()) -- When a line entry has a time in the future AND is in the given range, then totalize the rainfall if ((difference > 0) and (difference<=minutesinfuture*60)) then Message("-- Line in time range found",sDebug) rain=tonumber(string.sub(tostring(line), 0, 3)) totalrain = totalrain+rain rainlines=rainlines+1 Message("-- Rain in timerange: "..rain,sDebug) Message("-- Total rain now: "..totalrain,sDebug) end end file:close() averagerain=totalrain/rainlines return(averagerain) end regen = IsItGonnaRain(minuten) Message("-- Regen verwacht: "..regen.." binnen "..minuten.." minuten.",sDebug) if (regen > 0 ) then verw = 3 else verw = 2 end --Weatherstation data: sWeatherTemp, sWeatherHumidity, sWeatherUV, sWeatherPressure, sWeatherUV2 = otherdevices_svalues[sBarometer]:match("([^;]+);([^;]+);([^;]+);([^;]+);([^;]+)") sWeatherTemp = tonumber(sWeatherTemp); sWeatherHumidity = tonumber(sWeatherHumidity); sWeatherPressure = tonumber(sWeatherPressure); sWeatherUV = tonumber(sWeatherUV); sWeatherUV2 = tonumber(sWeatherUV2); Message("______________________________________________________________________________________",sDebug) Message("Weather station: Temperature is " .. sWeatherTemp .. " ",sDebug) Message("Weather station: Humidity is " .. sWeatherHumidity .. " ",sDebug) Message("Weather station: Pressure is " .. sWeatherPressure .. " ",sDebug) Message("Weather station: UV is " .. sWeatherUV .. " ",sDebug) Message("Weather station: UV2 is " .. sWeatherUV2 .. " ",sDebug) Message("______________________________________________________________________________________",sDebug) ------------------------------------------------------------------------ --Windmeter data: sWindDirectionDegrees, sWindDirection, sWindSpeed, sWindGust, sWindTemperature, sWindFeel = otherdevices_svalues[sWind]:match("([^;]+);([^;]+);([^;]+);([^;]+);([^;]+);([^;]+)") sWindDirectionDegrees = tonumber(sWindDirectionDegrees); sWindDirection = (sWindDirection); sWindSpeed = tonumber(sWindSpeed); sWindGust = tonumber(sWindGust); sWindTemperature = tonumber(sWindTemperature); sWindFeel = tonumber(sWindFeel); Message("______________________________________________________________________________________",sDebug) Message("Windmeter: Winddirection (in degrees) is: " .. sWindDirectionDegrees .. " ",sDebug) Message("Windmeter: Winddirection is: " .. sWindDirection .. " ",sDebug) Message("Windmeter: Windspeed is: " .. sWindSpeed .. " ",sDebug) Message("Windmeter: Windgust is: " .. sWindGust .. " ",sDebug) Message("Windmeter: Windtemperature is: " .. sWindTemperature .. " ",sDebug) Message("Windmeter: Windfeel is: " .. sWindFeel .. " ",sDebug) Message("______________________________________________________________________________________") ------------------------------------------------------------------------ --Rainmeter data: sRainmeterCurrent, sRainmeterTotal = otherdevices_svalues[sRain]:match("([^;]+);([^;]+)") sRainmeterCurrent = tonumber(sRainmeterCurrent); sRainmeterTotal = tonumber(sRainmeterTotal); Message("______________________________________________________________________________________",sDebug) Message("Rainmeter: Actual rain is: " .. sRainmeterCurrent .. " ",sDebug) Message("Rainmeter: Total rain is: " .. sRainmeterTotal .. " ",sDebug) Message("Rainmeter: Predicted rain is: " .. regen .. " ",sDebug) Message("______________________________________________________________________________________",sDebug) ------------------------------------------------------------------------ --UV data: sUV = otherdevices_svalues[sUV]:match("([^;]+)") sSolar = otherdevices_svalues[sSolar]:match("([^;]+)") sUV = tonumber(sUV); sSolar = tonumber(sSolar); Message("UV: UV Strength is: " .. sUV .." ",sDebug) Message("UV: Solar radiation is: " .. sSolar .." ",sDebug) --Thresholds: Message("______________________________________________________________________________________",sDebug) Message("Thresholds: Temp threshold is: " .. TempThreshold .." ",sDebug) Message("Thresholds: UV threshold is: " .. UVThreshold .." ",sDebug) Message("Thresholds: WindSpeed threshold is: " .. WindSpeedThreshold .." ",sDebug) Message("Thresholds: WindGust threshold is: " .. WindGustThreshold .." ",sDebug) Message("Thresholds: Rain threshold is: " .. RainThreshold .." ",sDebug) Message("______________________________________________________________________________________",sDebug) if (timeofday['Daytime']) then Message('It is past sunrise, monitoring variables for sunscreen',sDebug) if (otherdevices['Zonnescherm'] == 'Open' ) then Message ('Sunscreen is up',sDebug) else Message ('Sunscreen is down',sDebug) end if (otherdevices['Zonnescherm'] == 'Open' and sRainmeterCurrent == RainThreshold and sWeatherTemp > TempThreshold and sUV > UVThreshold and sWindSpeed < WindSpeedThreshold and sWindGust < WindGustThreshold) then Message ('Sun is shining, all thresholds OK, lowering sunscreen',sDebug) Message('______________________________________________________________________________________',sDebug) Notification('Sunscreen#Sunscreen down --> Sun is shining',sDebug) commandArray['Zonnescherm']='On' elseif (otherdevices['Zonnescherm'] == 'Closed' and (sRainmeterCurrent > RainThreshold or regen > 0)) then Message ('It is raining, raising sunscreen') Message('______________________________________________________________________________________',sDebug) Notification('Sunscreen#Sunscreen up --> It is raining',sDebug) commandArray['Zonnescherm']='Off' elseif (otherdevices['Zonnescherm'] == 'Closed' and sWeatherTemp < TempThreshold and otherdevices['Zonnescherm manual override'] == 'Off') then Message ('Temperature too low, raising sunscreen',sDebug) Message('______________________________________________________________________________________',sDebug) Notification('Sunscreen#Sunscreen up --> It is too cold',sDebug) commandArray['Zonnescherm']='Off' elseif (otherdevices['Zonnescherm'] == 'Closed' and sUV < UVThreshold and otherdevices['Zonnescherm manual override'] == 'Off') then Message ('Sun not shining too bright, raising sunscreen',sDebug) Message('______________________________________________________________________________________',sDebug) Notification('Sunscreen#Sunscreen up --> Sunshine not too bright',sDebug) commandArray['Zonnescherm']='Off' elseif (otherdevices['Zonnescherm'] == 'Closed' and sWindSpeed > WindSpeedThreshold) then Message ('Windspeed too high, raising sunscreen',sDebug) Message('______________________________________________________________________________________',sDebug) Notification('Sunscreen#Sunscreen up --> Windspeed too high',sDebug) commandArray['Zonnescherm']='Off' elseif (otherdevices['Zonnescherm'] == 'Closed' and sWindGust > WindGustThreshold) then Message ('Windgust too high, raising sunscreen',sDebug) Message('______________________________________________________________________________________',sDebug) Notification('Sunscreen#Sunscreen up --> Windgust too high',sDebug) commandArray['Zonnescherm']='Off' else Message('Sunscreen status OK --> No action',sDebug) Message('______________________________________________________________________________________',sDebug) end ::done:: Message("At the end of the script",sDebug) Message("______________________________________________________________________________________",sDebug) elseif (timeofday['Nighttime'] and otherdevices['Zonnescherm'] == 'Closed') then Message('It is night, raising sunscreen',sDebug) Message('______________________________________________________________________________________',sDebug) Notification('Sunscreen#Sunscreen up --> It is night',sDebug) commandArray['Zonnescherm']='Off' else Message('Sunscreen already up --> No action',sDebug) Message('______________________________________________________________________________________',sDebug) end commandArray[1] = {['UpdateDevice'] = idx .. '|'..tostring(regen)..'|'..tostring(verw)} commandArray[2] = {['UpdateDevice'] = idx2 .. '|0|'.. sWindDirection} commandArray[3] = {['UpdateDevice'] = idx3 .. '|0|'.. sWindSpeed} return CommandArray
Outside temp. is 25 degrees. When i set the treshold variable on 30 the screen is Up (off). When is switch manually down (on) it goes up. so thats ok. Because temperature is too low.
But when i set the treshold temperature on 12 degrees nothing happens.... Up or down, the status is ok.
Which blinds switch did you use?? Looks like up/down, open/close on/off are mixed?
Luuc_a
Do you have a override switch called "Zonnescherm manual override"? The first time I used it I had the same sort of issues. Then I saw that I don't had the override switch.
When you don't want to use the override script you can edit the code:
to
and the same for the UV check.
elseif (otherdevices['Zonnescherm'] == 'Closed' and sWeatherTemp < TempThreshold) then
Luuc_a
I have made a new script with the following adaptions:
- 2 new variables (RainPredThreshold and SolarThreshold)
- Check if UV or Solar is right to open or close the sunscreen
- Check if Rain Current of Rain Predicted is right to open or close the sunscreen
- More loging when debug is on
For me this would be the latest version because in my case I can not trust on WU of Forecast IO.
When there is a clear blue sky WU sometimes think it's rain. As long as I don't have a dedicated weather station I will leave it like this. If anyone has any comments or want something else let me know and I will take a look into it.
-- LUA Script
-- Extract values from WU device
-- Auteur: Luuc Alarm
-- 5) Weather_RainPredThreshold = integer
-- 6) Weather_UVThreshold = integer
-- 7) Weather_SolarThreshold = integer
-- 8) Weather_TempThreshold = integer
-- Create Switches:
-- 9) Zonnescherm manual override = Dummy On/Off switch
-- tijd ophalen
time = os.date("*t")
-- Variabelen
lon='4.692806'
SolarThreshold = uservariables["Weather_SolarThreshold"]
RainPredThreshold = uservariables["Weather_RainPredThreshold"]
minuten = 5 -- time within rainprediction
sUV = 'UV Gouda'
-- Rain = 0.0
-- UV = 2.0
-- Open = Up = Off
-- Functies
totalrain=0
rainlines=0
while true do
file:close()
return(averagerain)
--Windmeter data:
--Rainmeter data:
--UV data:
--Thresholds:
Message("Thresholds: Solar threshold is: " .. SolarThreshold .." ",sDebug)
Message("Thresholds: Rain Prediction threshold is: " .. RainPredThreshold .." ",sDebug)
Message("Override: ".. otherdevices['Zonnescherm manual override'],sDebug)
and (sUV > UVThreshold or sSolar > SolarThreshold)
then
elseif (otherdevices['Zonnescherm'] == 'Closed' and (sRainmeterCurrent > RainThreshold or regen > RainPredThreshold)) then
elseif (otherdevices['Zonnescherm'] == 'Closed' and sWeatherTemp < TempThreshold-1 and otherdevices['Zonnescherm manual override'] == 'Off') then
elseif (otherdevices['Zonnescherm'] == 'Closed' and (sUV < UVThreshold-1 or sSolar < SolarThreshold) and otherdevices['Zonnescherm manual override'] == 'Off') then
::done::
return CommandArray
- Brutus
For the people who are interested, I made the rain prediction script usable for Windows.
Steps to make it work:
- Make a virtual Humidity device in Domoticz and remember the IDX number.
- Go to the following website: http://curl.haxx.se/dlwiz/ and download the needed setup. (x86, x64).
In my case I selected "curl executable", "Win64", "Generic", "Any" and "x86_64" (I use Windows 8.1 64Bits)
- Create A new folder on your Domoticz Computer (For example: C:\Rain ).
- Extract the downloaded "Curl" zip file in this map.
- Make also a new file in this folder called: "rain.tmp"
- Make a new lua file called: "script_time_rain_prediction.lua" Fill the file with the following code:
Change the following data in your script:
- Change the longitude and latitude to your location. You can find these numbers in your Domoticz Settings.
- Change the path after: "tempfilename" if you have chosen another location.
- Change the path after: "read = os.execute: if you have chosen another location.
Greetings.
-- IsItGonnaRain( int minutesinfuture)
-- returns: int avarage rainfall for the next minutesinfuture
-- Function to get rain prediction from Buienradar.nl (dutch)
-- http://gratisweerdata.buienradar.nl/#Buienradar You may use their free service for non-commercial purposes.
-- Written in LUA by Hans van der Heijden (h4nsie @ gmail.com)
-- Spring 2015
-- 28-03-2015 v0.3 bug: quotes around url added.
-- 27-03-2015 v0.2 return value is now average for next time
-- 26-03-2015 v0.1 Initial release
-- todo: some error checking on http and file handling (tmp file)
-- config ---------------------------------------------------------
lat='50.891508' -- example lat/lon for Heerlen
lon='5.960975'
debug=False
tempfilename = 'C:\\Rain\\rain.tmp' -- can be anywhere writeable
if debug then print(url) end
read = os.execute('"C:/Rain/Curl/bin/curl.exe -s -o '..tempfilename..' "'..url..'"')
totalrain=0
rainlines=0
while true do
if debug then print('Line:'..line) end
if debug then print('Linetime: '..linetime) end
if debug then print('Line in time range found') end
if debug then print('Rain in timerange: '..rain) end
if debug then print('Total rain now: '..totalrain) end
file:close()
-- Returned value is average rain fall for next time
-- 0 is no rain, 255 is very heavy rain
-- When needed, mm/h is calculated by 10^((value -109)/32) (example: 77 = 0.1 mm/hour)
return(averagerain)
----- REGEN ------
minuten=15
print('Regen verwacht(0-255 hoe hoger hoe meer regen): '..regen..' binnen '..minuten..' minuten.')
commandArray['UpdateDevice'] = '170|'..tostring(regen)..'|'..tostring(verw)
Greetings.
28x Fibaro Modules
SMA Solar System
28x Fibaro Modules
SMA Solar System
- Siewert308SW
- Domoticz version: Stable
Just wanna say thx for the script.
Gonna use it for my Garden Irrigation.
Why irrigating while rain is coming up
Setup:
- DS923+ Docker
Domoticz Latest Stable
Mosquitto / ZwaveJSUI @ Aeotec Z-Stick Gen5+ / PiHole Unbound
P1 USB Gas/Power, HW watermeter
- A lot of Zwave switches, contacts, plugs, smoke/Co2 ect
- DiY 7.5kWh Solar Storage @ GitHuB
- DS923+ Docker
Justintime
It's a great script!! And two nice thresholds added.
Now some playing with the settings to get it right.
Thanks Luuc and Hansbit
Bram81
- Domoticz version: 4.9700
Hi Hans,
I've tried to send you a PM (in Dutch) but it seems that I can't get any messasges sent. I'm not familiar witch lua just yet but I would like to get data from Buienradar as well to add to my garden irrigation system and moisture sensors already in place. Can you put me on the right track about how to integrate this in domoticz exactly?
Thank in advance!
Thank in advance!
- Siewert308SW
Maybe you could try my script, just finished it and does what you want...Bram81 wrote:Hi Hans,
Thank in advance!
viewtopic.php?f=23&t=7290
Setup:
- DS923+ Docker
- DS923+ Docker
jjnj
I would like to use the outcome of the rain value/virtual humidity sensor in blocky. But for some reason blocky doesn't seem to respond to the value of the virtual humidity sensor. anybody has an idea?
- Brutus
Can you post an example of your Blockly?jjnj wrote:I would like to use the outcome of the rain value/virtual humidity sensor in blocky. But for some reason blocky doesn't seem to respond to the value of the virtual humidity sensor. anybody has an idea?
28x Fibaro Modules
SMA Solar System
28x Fibaro Modules
SMA Solar System
jjnj
Just a plain and simple blocky just to testBrutus wrote:Can you post an example of your Blockly?jjnj wrote:I would like to use the outcome of the rain value/virtual humidity sensor in blocky. But for some reason blocky doesn't seem to respond to the value of the virtual humidity sensor. anybody has an idea?
- Brutus
jjnj wrote:Just a plain and simple blocky just to testBrutus wrote:Can you post an example of your Blockly?jjnj wrote:I would like to use the outcome of the rain value/virtual humidity sensor in blocky. But for some reason blocky doesn't seem to respond to the value of the virtual humidity sensor. anybody has an idea?
I think you need to compare something like in my Blockly:
And I have my doubts about the "open" command.
Maybe test to write something in the log file or send a notification.
Timer Regen = virtual switch that is on when there is rain and off when there isn't. (needed for not creating loops in blockly).
Screens Dicht = Virtual switch for indicating if the screens are closed. (needed for not creating any loops in blockly).
28x Fibaro Modules
SMA Solar System
28x Fibaro Modules
SMA Solar System
Bram81
Thanks! Haven't worked with lua before, so I guess there is a lot to learn but this will help me for sure!Siewert308SW wrote:Maybe you could try my script, just finished it and does what you want...Bram81 wrote:Hi Hans,
Thank in advance!
Hansbit
Posted a install instruction in the Wiki
https://www.domoticz.com/wiki/Is_it_gonna_rain
Please note that a threshold of 70 is (in my opinion) the best value to trigger for rain.
jjnj
Why a threshold for 70? Then it would already be raining right below 70? So that would be to lateHansbit wrote:Posted a install instruction in the Wiki
Hansbit
With lower values to trigger for rain you'll get too many false positives. Even on sunny days with clear blue sky, Buienrader sometimes reports values like 35 or 40.jjnj wrote:Why a threshold for 70? Then it would already be raining right below 70? So that would be to late
RayAmsterdam
The wiki script gives me the following error: Error: EventSystem: Lua script did not return a commandArray
Any idea what's wrong?
- jvdz
- Domoticz version: 4.107
Do you have this line at the bottom of the script?
Jos
return CommandArray
