roblom
Post by roblom »
I have a custom page with the example that is included in Domoticz. This works like a charm.
Now I installed the frontpage of G3rard but I can't get it to work. What more do I have to do than change the user values in "frontpage_settings.js"?
I filled in the correct IP, changed the number of the roomplan (the same I use with the working custom page) and set some idx numbers (also the same like the other custom page). The only thing I get is.
G3rard
Domoticz version: No
Post by G3rard »
Luuc_a wrote: so I only have a up and down button and this is working for blinds with only On/Off status.
and what doe you mean with?
I have set the blinds with value Data in frontpage_settings.js, maybe a bit strange but it is working :D.
I meant the following line in frontpage_settings.js.
['71','Data',		'cell19',	'Scherm (V)','1','0'],
So I gave the value Data to the blinds. I thought maybe that could be of influence regarding the stop button. But if you have blinds without a stop function then that's the cause of the issue :).
Not using Domoticz anymore
G3rard
Post by G3rard »
roblom wrote:I have a custom page with the example that is included in Domoticz. This works like a charm.
Edit: I use the following html code in the template folder to show the frontpage in the menu Custom. That's working fine.
I think it's important that the frontpage files and folders are either in the www folder or on a webserver. Then in the HTML code below you can put that page in an i-frame.
<html>
<head>
<div align="center">
<iframe src="http://<ip>/<folder>/frontpage.html" name="targetframe" allowTransparency="true" scrolling="no" frameborder="0" width="1024" height="750">
</iframe>
</div>
</head>
</html>
PSYCHOTIC
Post by PSYCHOTIC »
Guys,
Is it possible to put a graph (voltage & counter) on the frontpage?
Greetz P.S.Y.C.H.O.T.I.C.
pimvolkert
Domoticz version: 2020.1
Post by pimvolkert »
Another feature request
Display Max and Min temperature of today in one cell. Or is this already possible?
(I must confess that as a happy Frontpage user I have difficulties finding information in this lloonngg thread)
SweetPants
Post by SweetPants »
Guys,
Great topic and nice work. I have been playing around with it on a desktop and looks really nice.
I want to use my old nexus 7 (1280x800) and hang it on the wall, but I can't get the screen size right.
Is there an easy way to set the screen size in frontpage?
G3rard
Post by G3rard »
PSYCHOTIC wrote:Guys,
If you have a webpage with the graph available, then you can add this to the frontpage.html file.
G3rard
Post by G3rard »
pimvolkert wrote:Another feature request
Do you have something for the min and max temperature? Because two values in a cell is possible.
G3rard
Post by G3rard »
SweetPants wrote:Guys,
I have my frontpage working on my Nexus 7, you can download it from this topic.
I changed the css a little bit and am using an app to hide the navigation and status bars.
SweetPants
G3rard wrote:I have my frontpage working on my Nexus 7, you can download it from this topic.
Mine is the old Nexus 7 (2012) one (1280 x 800), have tried yours but the bottom row of buttons fels of the screen
G3rard
Post by G3rard »
SweetPants wrote:Mine is the old Nexus 7 (2012) one (1280 x 800), have tried yours but the bottom row of buttons fels of the screen
That's a different resolution indeed than my Nexus 7 from 2013. The CSS is not responsive, so you can either make it responsive (the hard way) or remove some cells (the easy way) so it will fit your screen.
jossie67
Post by jossie67 »
G3rard wrote:Here is the link to my updated frontpage.
http://we.tl/Hl5AoKa7Md
Could you upload your version again,the download link doesn't work any more
Raspberry Pi (3x)
Master Domoticz installed on a Synology
RFXCOM RFXtrx433E USB
RFLink
USB Z-Wave Mini Adapter
Mi-light
QuinLED
Landis+Gyr ZME120ACd
Kamstrup_M401
USB-IR-Schreib-Lesekopf Alecto WS1700
Watermeter with TCRT5000
Kodi
DS18B20
G3rard
Post by G3rard »
I have uploaded my frontpage to Github :D
https://github.com/gerard33/frontpage
I am new to Github so let me know if I have to change something.
jossie67
Post by jossie67 »
G3rard wrote: I have uploaded my frontpage to Github :D
Raspberry Pi (3x)
RFLink
Mi-light
QuinLED
Kamstrup_M401
Kodi
DS18B20
pimvolkert
Yes, two values in a cell is a very nice feature and which actually inspired me to my feature request.l And no I do not have a min and max temperature. That is a problem (for me). The min/max temperature is probable not stored and needs to be calculated every so many minutes. Anyone an idea how to do that?
jannl
Domoticz version: 2022.2
Post by jannl »
Easiest way would be a perl or python script that runs continuously and computes min max temps and fills 2 virtual sensors.
pj-r
Domoticz version: V3.8650
Post by pj-r »
If it dont need to be fully real time.. For today or last 24 hours this way could work:
http://DOMO_IP:DOMO_PORT/json.htm?type=graph&sensor=temp&idx=TEMP_SENSOR_IDX&range=day
What results this kinda json:
   "result" : [
         "d" : "2015-06-19 09:35",
         "hu" : "93",
         "te" : 13.0
         "d" : "2015-06-19 09:40",
         "hu" : "93",
         "te" : 13.0
........... Just making it shorter ...........
         "d" : "2015-06-24 09:30",
         "hu" : "95",
         "te" : 14.90
         "d" : "2015-06-24 09:35",
         "hu" : "95",
         "te" : 14.90
   "status" : "OK",
   "title" : "Graph temp day"
Just loop it thru in js and pick min & max temps.
For just today you need to filter out yesterdays values.
EDIT:
It looks like domoticz already calculates that information for monthly graph:
http://DOMO_IP:DOMO_PORT/json.htm?type=graph&sensor=temp&idx=TEMP_SENSOR_IDX&range=month
What result is this:
   "result" : [
         "d" : "2015-05-24",
         "hu" : "73",
         "ta" : 10.660,
         "te" : 16.40,
         "tm" : 5.90
         "d" : "2015-06-24",
         "hu" : "95",
         "ta" : 15.17457627118640,
         "te" : 15.90,
         "tm" : 14.60
   "status" : "OK",
   "title" : "Graph temp month"
Where last entry "te" is the max and "tm" is min of today.
LXC(x64 Ubuntu Xenial), RFXtrx433E, MySensors
bizziebis
Domoticz version: 3.8805
Post by bizziebis »
One disadvantage of using the frontpage with a webcam stream enabled:
I can turn wifi off when the screen is off, but then you have to wait a while when you are in front of your tablet and want to switch something on or off..
BarryT
Domoticz version: 2024.3
Post by BarryT »
bizziebis wrote:One disadvantage of using the frontpage with a webcam stream enabled:
You can make a javascript with a timer/refresh/reload/redirect in it, then it shows only some minutes (or seconds) the webcam frame, and then goes to black (or another iframe/page)
jannl
Post by jannl »
Or use snapshots to regularly update the image in frontpage and start the stream in a popup when you select it.
