SMA SB 1300-TL
groetg
Domoticz version: V2.4025
SMA SB 1300-TL
Post by groetg »
What hardware do i need to get de data of my solar "omvormer" into domoticz?
I have a sb 1300 TL from SMA. But now i doet have the option to Any data from it.
Master: RPI Model 2B
Sub 1: RPI Model 2B
RFX transmitter/receiver 433 Mhz
13 KAKU units (3 window sensors, 1 door sensor, 7 light switches, 1 dusk sensor, 1 motion sensor)
4 IP cam
Meteostick
OTGW
P1 cable
Davis Vantage Pro weatherstation (incl. solar/UV)
groetg
Re: SMA SB 1300-TL
Post by groetg »
This are my options qua hardware:
http://www.sma-benelux.com/nl_BE/produc ... temen.html
To het the data in domoticz i Will have to use sbfspot i understand?
Sub 1: RPI Model 2B
4 IP cam
Meteostick
OTGW
P1 cable
gizmocuz
Re: SMA SB 1300-TL
Post by gizmocuz »
SBFspot will work
bbqkees
Domoticz version: 4.1x
Re: SMA SB 1300-TL
Post by bbqkees »
You would need to add a SMA Piggy Back (Webconnect) module to the converter with either ethernet of Bluetooth.
In the latter case you also need to add a bluetooth stick to the Pi.
And then use SBFSpot.
Derik
Re: SMA SB 1300-TL
Post by Derik »
Or when your inverter has Bluetooth...
Buy a cheap bt usb, that on your rpi...
And then use SBF spot the old version....[ u can also upload data to pv output]
Or if you uplod no your data to PVO you can import it directly from PVO...
groetg
Re: SMA SB 1300-TL
Post by groetg »
I bought and installed the Piggy Back and my rpi sees the Mac address of the piggy Back.
I am following everything at: http://www.domoticz.com/wiki/SMASpot_Mo ... n_Domoticz
When I must move the SBFspot.cfg to /bin/Release_MySQL I got an error:
mv: cannot move `SBFspot.cfg' to `bin/Release_MySQL/SBFspot.cfg': Permission denied
rights on SBFspot.cfg are on 0777, so that shouldn't be a problem.
Also creating a database like below, won't work
sql
sql
pi@raspberrypi ~/smadata $ sqlite3 SBFspot.db < /home/pi/SMAspot/SBFspot/CreateSQLiteDB.sql
-bash: sqlite3: command not found
Sub 1: RPI Model 2B
4 IP cam
Meteostick
OTGW
P1 cable
Derik
Re: SMA SB 1300-TL
Post by Derik »
are you pi or root?
Perhaps sudo before the command?
groetg
Re: SMA SB 1300-TL
Post by groetg »
pi, sudo worked, thanx!
Now I am stuck at:
sql2
sql2
Sub 1: RPI Model 2B
4 IP cam
Meteostick
OTGW
P1 cable
Derik
Re: SMA SB 1300-TL
Post by Derik »
Login with winscp.;...
And when you make a mv or you make a document...
Click the refresh button in winscp and check or the document is there where you want.
refresh and check of the document ave the good rights...
Do this with all the steps..
tcviper
Re: SMA SB 1300-TL
Post by tcviper »
I actually found out today that Domoticz doesnt pick up multi inverters within the same config file of SBFSpot :)
It only logs like half of the energy. Since latest release you can put multiple inverters into the same SBFSpot.cfg file:
IP_ADDRESS=xx.xx.xx.xx,xx.xx.xx.xx
That will basically log both inverters (both each it's own ip) into the same log files.
It looks like domoticz doesnt support this yet? I started a discussion here about it: https://sbfspot.codeplex.com/discussions/645764
gizmocuz
Re: SMA SB 1300-TL
Post by gizmocuz »
tcviper wrote:I actually found out today that Domoticz doesnt pick up multi inverters within the same config file of SBFSpot :)
Send you a PM
tcviper
Re: SMA SB 1300-TL
Post by tcviper »
Anyone any idea? I setup SBFspot again today (fresh start with latest version 3.1.2) im using 2 local inverters in the SBFspot.cfg file (both LAN). The smadata is being built but in domoticz it shows as 3501.441 Kwh today, and that is a bit much since the day just started :P The SMA app on my iphone shows 0,10 Kwh so far.Looks like the comma is wrong or something? No idea where to change that?
bbqkees
Re: SMA SB 1300-TL
Post by bbqkees »
Isn't the 3501 value the total from start?
So the first day has all the production ever up until that day and the next day it should be just the actual daily consumption.
