Blockly examples
thecosmicgate
Domoticz version: newest
Re: Blockly examples
Post by thecosmicgate »
ThinkPad wrote:Some events that i created:
Detect if there is someone home
Almost all my other events are based on this one. This event will tell Domoticz if there is someone home or not.
This event is based on two virtual switches, where one is switched by a geofence app on iPhone, and the other by this script: http://www.domoticz.com/wiki/Presence_detection
'IemandThuis' translates to 'SomeoneHome'
Switch on lights when we are home, and it is getting dark
This event turns on some lights when we are home, and it is starting to get dark. The variable is used so that the event is only triggered once. Otherwise it would trigger again when we turn off the lights by hand when we go to bed.
The '15min_before_zononder' is a virtual switch that turns on 15 min before sunset, and off at 0:01
Turn on lights when we arrive home and it is dark outside
This event turns on some lights when we arrive home and it is dark outside. The variable is used so that the event is only triggered once. Otherwise it would trigger again when we turn off the lights by hand when we go to bed.
First line ends with "IsDonker = On"
The "IsDonker" switch i use, is a virtual switch that is turned on/off by timers. It is turned on at sunset, and turned off at sunrise. This way it covers the whole 'dark' period of the evening/night. This is easy to use in events. By doing this my lights will never switch on accidentaly at daytime.
Unfortunately they are in Dutch, but i hope they are still useful for someone...
I use this someone home switch, but whe try to open the log the browser crashes.
Are there more people who use this blockly and having this log issue ?
Or maybe better , the solution ;)
It's nice to be important, but it's more important to be nice
Scooter ;)
djoeney
Post by djoeney »
I have followed a example from this forum only it doesn't work?
Compute RPi 2 : Domoticz latest beta, Synology : Domoticz tested beta on failover system.
Peripherals RFXCOM - RFXtrx433, Z-Wave.Me ZME_UZB1 USB Stick,P1 cable on smartmeter, Logitech Harmony Hub, 3 IP camera's
ThinkPad
Post by ThinkPad »
Hi, welcome to this forum! :)
The 'IemandThuis = Off' part is not correct. Make it like this:
IemandThuis = Off AND [Anna = On OR Jeroen = On]
Same for the 'ELSE IF' line. The rest of it is correct.
So you have 1 AND block, and inside is:
- IemandThuis = Off
- [Anna = On OR Jeroen = On]
See this one: http://i.imgur.com/0lQrGcL.png i made (also shown a few posts above)
djoeney
Post by djoeney »
Hi ThinkPad,
What a warm welcome, thanks for the quick reply. This does the trick, now i can put off the radio in the morning when nobody is home:). Cant wait till my RFXtrx433E is delivered.
ThinkPad
Post by ThinkPad »
Hehe this is only the tip of the iceberg :twisted: I can guarantee you that you will spend a looooooooooot of time in configuring the most fantastic events and such :lol:
Have fun! ;)
ThinkPad
Post by ThinkPad »
I found this nice event which triggers a switch if movement is detected by a motion sensor. If no motion is detected anymore after 1 minute, the light will turn off.
If within that minute there is still motion, the light will stay on until no motion is detected anymore.
Works great!
Credits go to bizziebis: http://www.domoticz.com/forum/viewtopic ... pir#p14415
Add another (dummy) switch which will switch off after 1 minute (it's a setting of the switch) and call it for example 1 Min Timer (in my example)
Every time the PIR detects motion the timer will be activated again and starts counting down from 60 seconds. Until the last movement is detected, then the light will go off.
spudgunman
Post by spudgunman »
That's great! I am working on making lights turn on around the house when you walk in to rooms automatically. Thanks
dressie
Domoticz version: V2020.2
Re: SCRIPS - EVENT MANAGEMENT SAMPLE
Post by dressie »
Jochen wrote:Turn on a Light when open a door
This example will turn on a light when
1. A door is opening
2. It is between 22:00 and 07:00
A notification will be send everytime the is opening (00:00 - 24:00)
PS: The device Garagentor is the door (Garagentor = Garagedoor), the light is light is Licht Garage (Light Garage)
How did you get the double IF /DO option?
havnegata
Domoticz version: V4.10162
Post by havnegata »
This is exactly what I want, but where is this setting for the countdown timer?
dressie
Post by dressie »
Hello!
I'm new to Domoticz and pretty happy with it! Slowly I'm having Domoticz take over tasks from Homewizard, but I can't seem to figure this "simple" one out. Do you guy know what's going wrong?
The light goes on when the door opens, but it does it for 24hours and not according the set Sunset-Sunrise time. Already did my research in this form, copied many examples but with no success.
ThinkPad
Post by ThinkPad »
IF [Frontdoor = Open] AND [Time > Sunset] OR [Time < Sunrise]
DO SET .....
The nesting of the elements (with the AND/OR parts) is not correct.
Build it like this:
dressie
Post by dressie »
ThinkPad wrote:IF [Frontdoor = Open] AND [Time > Sunset] OR [Time < Sunrise]
DO SET .....
How would I be able to solve this one? I haven't figured out the "inline" and "outline" inputs.
I simply want: IF the frondoor opens, and it's between Sunset and Sunrise, turn on the hall-light.
ThinkPad
Post by ThinkPad »
I have updated my post with a screenshot. Pay attention to the boxes around items in the screenshot (the brackets in my text written event)
dressie
Post by dressie »
ThinkPad wrote:I have updated my post with a screenshot. Pay attention to the boxes around items in the screenshot (the brackets in my text written event)
I start to see it now! Thanks! Just trying to figure out how to make these sepperate "event" between the brackets.
dressie
Post by dressie »
Perhaps my Google-skills arn't that great, but I can't seem to find a blockly example of doorbel = send snapshot to email? :?:
This is the last function that's still being done by my HomeWizard :?
Luuc_a
Blockly examples
Post by Luuc_a »
You van do this without a blocky. Go to Settings -> More options -> Camera. Select the camera and at the bottom select the doorbell and click on add.
When you've done this and go to switches then to your doorbell you'll see a camera icon.
leoncornelissen
Domoticz version: 3.8258
Post by leoncornelissen »
I created two events to switch on the fan if the humidity is too high but the events won't trigger. Do I need to set something special in the configuration?
dressie
Post by dressie »
Luuc_a wrote:You van do this without a blocky. Go to Settings -> More options -> Camera. Select the camera and at the bottom select the doorbell and click on add.
Thanks! It was that simple!
ThinkPad
Post by ThinkPad »
leoncornelissen wrote:I created two events to switch on the fan if the humidity is too high but the events won't trigger. Do I need to set something special in the configuration?
No.
Probably there is an error in your event. If you post it here maybe we can help.
leoncornelissen
I stopped the block service and started it again. Now it works fine. Still limited in functionality but more reason to learn lua
