I use this someone home switch, but whe try to open the log the browser crashes.ThinkPad wrote:Some events that i created:
Detect if there is someone home
Almost all my other events are based on this one. This event will tell Domoticz if there is someone home or not.
This event is based on two virtual switches, where one is switched by a geofence app on iPhone, and the other by this script: http://www.domoticz.com/wiki/Presence_detection
'IemandThuis' translates to 'SomeoneHome'
Switch on lights when we are home, and it is getting dark
This event turns on some lights when we are home, and it is starting to get dark. The variable is used so that the event is only triggered once. Otherwise it would trigger again when we turn off the lights by hand when we go to bed.
The '15min_before_zononder' is a virtual switch that turns on 15 min before sunset, and off at 0:01
Turn on lights when we arrive home and it is dark outside
This event turns on some lights when we arrive home and it is dark outside. The variable is used so that the event is only triggered once. Otherwise it would trigger again when we turn off the lights by hand when we go to bed.
First line ends with "IsDonker = On"
The "IsDonker" switch i use, is a virtual switch that is turned on/off by timers. It is turned on at sunset, and turned off at sunrise. This way it covers the whole 'dark' period of the evening/night. This is easy to use in events. By doing this my lights will never switch on accidentaly at daytime.
Unfortunately they are in Dutch, but i hope they are still useful for someone...
Are there more people who use this blockly and having this log issue ?
Or maybe better , the solution
