domoticz in synology as package! Available now.
G3rard
Domoticz version: No
Post by G3rard »
mvveelen wrote:Kudo's for jumbotroll and his effort to make regular updates for the packages so far. I've updated my Domoticz twice today without any problems. Thanks for your effort and (please) keep up the good work !
I second that.
Are your LUA scripts and frontpage files still available after you have updated? I have updated yesterday (manual install of spk in DSM package center) and all the files I added were gone.
Not using Domoticz anymore
Templar
Domoticz version: V4.9700
Post by Templar »
JesseKlaasse wrote:
jumbotroll wrote:Domoticz v2.0.2383-7 with openzwave and usbserial driver included.
DSM-5.1 5022.
Hi! First of all, thank you very much for this excellent package. It's working perfectly fine!
I have a question. By default, Domoticz is installed on the Synology as a http web site. Would it be possible to include the option to run it as https? I don't like the idea of a password transported plain text over http.
Hello jumbotroll, nice effort you did for compiling those Synology packages. it worked like a charm on my DS114! :D
Just like JesseKlaasse I was trying to enable https too. Is the Synology-Domoticz package compiled with SSL support?
Greetings Templar
Synology DS114 NAS Domoticz package
jumbotroll
Post by jumbotroll »
Templar wrote:
DSM-5.1 5022.
Greetings Templar
Hmm..Maybe something missing from the source i am using?
Here is the source i am building from: https://github.com/gkroone/spksrc/tree/openzwave
I do not have time to look at this now, but maybe later 8-)
Happy testing!
https://paypal.me/Jumbotroll
Jumbotroll
http://www.jadahl.com
ThinkPad
Post by ThinkPad »
2386 also working fine here (on DS114), installed from jadahl repo. USB driver package also not needed anymore, nice.
Keep up the good work jumbotroll!
jumbotroll
Use Domoticz 2.0-2431 with Open Zwave!
http://jadahl.dscloud.me/sspks/index.php?fulllist=true
Jumbotroll
Jumbotroll
mvveelen
Post by mvveelen »
I've updated to V2.2391 yesterday..... Wow, the speed in which the versions are available at the moment :D !? Thanks!
RPi3b+/RFXCOM rfxtrx433E/Shelly/Xiaomi Gateway/Philips HUE Lights/Atag Zone One/2 SunnyBoy inverters/AirconWithMe/P1 smartmeter/Domoticz latest Beta
jumbotroll
Re: Domoticz in synology as package! Available now.
Jumbotroll
Jumbotroll
ThinkPad
Post by ThinkPad »
Thanks again, really appreciated.
Just updated, package center said an update for domoticz was available. The ease of updating is comparable to Synology's own packages due to your effort :)
ThinkPad
Post by ThinkPad »
Ooops, my Z-Wave stick is gone? (Aeon labs S2). And i can't choose it from the dropdown menu under hardware anymore (i thought i had it added as "Openzwave USB").
No Openzwave support in the package that i got through the package center?
Luckily i barely use Z-Wave, so i can wait untill after your vacation :)
jumbotroll
ThinkPad wrote:Ooops, my Z-Wave stick is gone? (Aeon labs S2). And i can't choose it from the dropdown menu under hardware anymore (i thought i had it added as "Openzwave USB").
Forgot to implement openzwave in the 2.0-2436 build :cry:
Jumbotroll
G3rard
Post by G3rard »
The V.2.2431 from Jumbotroll (http://jadahl.dscloud.me/sspks/) is with OpenZWave and working fine over here.
joshimosh
Post by joshimosh »
Good morning,
I would like to use Domoticz on my Synology DS114. How can I configure where the database should be located ?
I have an USB stick attached to the Synology and would like to have the Domoticz database on it.
Thank you for your help.
J.
Nicogluck
Post by Nicogluck »
joshimosh wrote:I would like to use Domoticz on my Synology DS114. How can I configure where the database should be located ?
I think the best is to write a script which copy the database from the Domoticz folder to your USB stick, every hour/day/week/...
On my side, I have two questions :
1) Does someone know how to install any Domoticz add-on like the link with Google Agenda, ImperiHome (via MyDomoAtHome), etc. ?
2) I have a Shell script to launch at each Domoticz start up, but I didn't find any domoticz.sh file ! Where is it or where to place the launching line to my script ?
Many thanks to all.
Skippiemanz
Domoticz version: 4.10233
Post by Skippiemanz »
Because I use my Synology also for business purposes I already updated it to the 5.2 dsm version. Is there some solution for the USB drivers?
jumbotroll
DSM 5.2 Test
Domoticz OpenZwave with USB drivers.
V2.2563 for Synology DSM 5.2 for manual install.
Big Thanks to gkroone.
Jumbotroll
Jumbotroll
Skippiemanz
Really great work!
G3rard
Post by G3rard »
Just installed it an it's working okay :D
One minor issue, the folder for the scripts is not present. See https://github.com/SynoCommunity/spksrc ... -112209141.
Skippiemanz
The folder for the scripts is called samplescripts at least in my case
RogerSch
Post by RogerSch »
Hello Jumbotroll, I've added your link to my packages in my Synology DS413j (Marvell Kirkwood mv6282). I have already enabled that the all packages are allowed. But unfortunately your version of the Domoticz doesn't appear on the list. I only see the older version of the SynoCommunity. Is it correct that your package list doesn't contain a version for the 413j? Is there a specific reason for like hardware limitation?
Thanks in advance for your reply.
roblom
Post by roblom »
I've exactly the same but then for my DS213+
