Multibutton, Mutirelay in one node.
I have a problem with Domoticz software for multibutton/multirelay, the serial ouput is fine, gateway get ack and reply. but when I press the button, Domoticz isn't responding (sometimes responding), I don't think that is radio problem because serial output is fine. maybe the problem with the software.
below is the sketch from AWI
#include <MySensor.h>
#include <SPI.h>
#include <Bounce2.h>
#define RELAY_ON 1 //switch around for realy HIGH/LOW state
#define RELAY_OFF 0
MySensor gw;
#define noRelays 4
const int relayPin[] = {7, 8, A0, A1};
const int buttonPin[] = {3, 4, 5, 6};
class Relay // relay class, store all relevant data (equivalent to struct)
public:
int buttonPin; // physical pin number of button
int relayPin; // physical pin number of relay
byte oldValue; // last Values for key (debounce)
boolean relayState; // relay status (also stored in EEPROM)
Relay Relays[noRelays];
Bounce debouncer[noRelays];
MyMessage msg[noRelays];
void setup(){
gw.begin(incomingMessage, AUTO, false);
delay(250);
gw.sendSketchInfo("MultiRelayButton", "0.9b");
delay(250);
// initialize Relays with corresponding buttons
for (int i = 0; i < noRelays; i++){
Relays[i].buttonPin = buttonPin[i]; // assign physical pins
Relays[i].relayPin = relayPin[i];
msg[i].sensor = i; // initialize messages
msg[i].type = V_LIGHT;
debouncer[i] = Bounce(); // initialize debouncer
debouncer[i].attach(buttonPin[i]);
debouncer[i].interval(5);
pinMode(Relays[i].buttonPin, INPUT_PULLUP);
// pinMode(Relays[i].relayPin, OUTPUT);
Relays[i].relayState = gw.loadState(i); // retrieve last values from EEPROM
digitalWrite(Relays[i].relayPin, Relays[i].relayState? RELAY_ON:RELAY_OFF); // and set relays accordingly
gw.send(msg[i].set(Relays[i].relayState? true : false), true); // make controller aware of last status
gw.present(i, S_LIGHT); // present sensor to gateway
delay(250);
void loop()
gw.process();
for (byte i = 0; i < noRelays; i++)
debouncer[i].update();
byte value = debouncer[i].read();
if (value != Relays[i].oldValue && value == 0)
Relays[i].relayState = !Relays[i].relayState;
digitalWrite(Relays[i].relayPin, Relays[i].relayState);
gw.saveState( i, Relays[i].relayState ); // save sensor state in EEPROM (location == sensor number)
Relays[i].oldValue = value;
// process incoming message
void incomingMessage(const MyMessage &message)
if (message.isAck()){
Serial.println(F("This is an ack from gateway"));
if (message.type == V_LIGHT){
if (message.sensor <= noRelays){ // check if message is valid for relays
Relays[message.sensor].relayState = message.getBool();
digitalWrite(Relays[message.sensor].relayPin, Relays[message.sensor].relayState? RELAY_ON:RELAY_OFF); // and set relays accordingly
gw.saveState( message.sensor, Relays[message.sensor].relayState ); // save sensor state in EEPROM (location == sensor number)
and this is my serial output when I pressed the button
send: 26-26-0-0 s=0,c=1,t=2,pt=2,l=2,st=ok:1
read: 0-0-26 s=0,c=1,t=2,pt=2,l=2:1
send: 26-26-0-0 s=1,c=1,t=2,pt=2,l=2,st=ok:0
read: 0-0-26 s=1,c=1,t=2,pt=2,l=2:0
send: 26-26-0-0 s=1,c=1,t=2,pt=2,l=2,st=ok:1
read: 0-0-26 s=1,c=1,t=2,pt=2,l=2:1
send: 26-26-0-0 s=2,c=1,t=2,pt=2,l=2,st=ok:0
read: 0-0-26 s=2,c=1,t=2,pt=2,l=2:0
send: 26-26-0-0 s=2,c=1,t=2,pt=2,l=2,st=ok:1
read: 0-0-26 s=2,c=1,t=2,pt=2,l=2:1
send: 26-26-0-0 s=3,c=1,t=2,pt=2,l=2,st=ok:0
read: 0-0-26 s=3,c=1,t=2,pt=2,l=2:0
send: 26-26-0-0 s=3,c=1,t=2,pt=2,l=2,st=ok:1
read: 0-0-26 s=3,c=1,t=2,pt=2,l=2:1
and also if I control the relay from Domoticz it's also fine, the problem is only when I pressed the button, domoticz often not update the status.
