domoticz in synology as package! Available now.
fwehrle
Thank you. But my firewall id disabled. I think it is a spk limitation.
ThinkPad
With the newest v2.2284 of Domoticz i can't choose a different icon for a switch anymore. When i choose one, and save, it does not remember it, the setting does not stick.
Maybe something with rights/permissions between Domoticz <> Synology?
I was able to choose a custom icon earlier, with v2.2211 (?) or so, but since 2283/2284 it is not working anymore.
I am running Domoticz on a DS114 (Armada 370) with DSM 5.1-5022 Update 2, but i know someone with a DS214+ (Armada XP MV78230) with DSM5.1 where the same problem is occuring.
Derik
- Domoticz version: BETA
Why not the icon from Domoticz?
tehnoinstyle
- Domoticz version: 2.0.2276
Hi.tehnoinstyle wrote:Hi.Decipher wrote:@technoinstyle,
Was about to start on those two architectures, and it occurred you didn't tell me which versions (4.3, 5.0, 5.1). Let me know and I'll get them created as soon as I can.
Version DSM on my devices in my signature.
When you try to install a package
bromolow-5.1: https://dl.dropboxusercontent.com/u/180 ... 2276-6.spk, on Xpenology DS3615 with DSM 5.1-5022U2, I get a message:
"This package does not contain a digital signature."
Syn DS3615xs DMS 5.1-5022U5(xpenology;Intel2700MUD;4GbRAM;2*3TbHDD->JBOD)
Syn DS3615xs DMS 5.2-5592(xpenology;asus p8-z68;I3;4GbRAM;6*2TbHDD->JBOD)
Z-Wave Aeon Labs Z-Stick S2->OpenRemote;Domoticz
- jumbotroll
In Package Center, go to settings and choose Any Publisher and try to install.tehnoinstyle wrote:Hi.tehnoinstyle wrote:Hi.Decipher wrote:@technoinstyle,
/Jumbotroll
https://paypal.me/Jumbotroll
Jumbotroll
http://www.jadahl.com
Jumbotroll
tehnoinstyle
Thanks for the help. I installed package, but do not run it. Version: 2.0.2276-6. How to upgrade a package?jumbotroll wrote:
/Jumbotroll
- jumbotroll
what do you mean " but do not run it" ? Does not domotics start?tehnoinstyle wrote:Thanks for the help. I installed package, but do not run it. Version: 2.0.2276-6. How to upgrade a package?jumbotroll wrote:
/Jumbotroll
Remember that domoticz running on port 8084 on synology!
I think Version: 2.0.2276-6 is the latest compiled version, so you can not upgrade before there is a newer version.
Jumbotroll
Jumbotroll
tehnoinstyle
Yes. I thought the first upgrade, and then start.jumbotroll wrote: what do you mean " but do not run it" ? Does not domotics start?
I got it.jumbotroll wrote: I think Version: 2.0.2276-6 is the latest compiled version, so you can not upgrade before there is a newer version.
Domotics start. I See OZW support.
Another question, in this package have USBSerial driver for AeonLab Stick 2, or need to install your USBSerial driver package?
- jumbotroll
This package from Decipher have USBSerial driver for AeonLab Stick 2 inckluded, so no need for the USBSerial driver package.tehnoinstyle wrote:Yes. I thought the first upgrade, and then start.jumbotroll wrote: what do you mean " but do not run it" ? Does not domotics start?I got it.jumbotroll wrote: I think Version: 2.0.2276-6 is the latest compiled version, so you can not upgrade before there is a newer version.
Jumbotroll
Jumbotroll
tehnoinstyle
Got it, thanks. Package starting well, the z-wave stick and the devices properly defined. I will try to testing any further.jumbotroll wrote: This package from Decipher have USBSerial driver for AeonLab Stick 2 inckluded, so no need for the USBSerial driver package.
PS Your USBSerial driver package, where i can download? It runs on evansport and bromolow?
- jumbotroll
tehnoinstyle wrote:Got it, thanks. Package starting well, the z-wave stick and the devices properly defined. I will try to testing any further.jumbotroll wrote: This package from Decipher have USBSerial driver for AeonLab Stick 2 inckluded, so no need for the USBSerial driver package.
You can download USBserialDriver3.0.2 modified for DSM 5.1-5022 here: http://jadahl.dscloud.me/sspks/packages ... _3.0.2.spk
I think it will work on evansport and bromolow
Jumbotroll
Jumbotroll
tehnoinstyle
Hi.jumbotroll wrote:tehnoinstyle wrote:Got it, thanks. Package starting well, the z-wave stick and the devices properly defined. I will try to testing any further.jumbotroll wrote: This package from Decipher have USBSerial driver for AeonLab Stick 2 inckluded, so no need for the USBSerial driver package.
Thanks, I downloaded your package. It may be necessary for other packages.
ctve
I've been using for several monthes Domoticz on a Raspberry Pi but the SD card has been corrupted several times so I want now to use Domoticz on my Synology NAS.
I'm sorry but I'm a bit confused by the list of architectures shown at the top of the page presenting Domoticz on SynoCommunity.
Does it mean that the package work with all the architectures shown ?
If It's the case, will it work with my old DS 209 (Marvell Kirwood mv6281ARM processor) ? I think the answer is yes because I can see 88f628x in the architecture list but I'm not sure.
Some help would be appreciated.
Sorry for my poor English.
- jumbotroll
The answer is yes
You can use the package Decipher made and you can download it here: http://jadahl.dscloud.me/sspks/packages ... 2276-6.spk
The package Decipher made include USBSerial drivers and support Zwave.
/Jumbotroll
/Jumbotroll
Jumbotroll
Jumbotroll
ctve
Thank you very much for your very fast reply.
I'll try it in the next few days.
ctve
@jumbotroll
Unfortunately your link doesn't work on my DS 209 because when I try to install the package it says that DSM 5.0 is required and DSM 5.0 isn't available for the DS 209 ...
I've tried with the "normal" package link of the SynoCommunity and this problem desapeared.
Domoticz is now running "alone" on my DS 209.
I'll try to connect my Zstick Aeon Labs and my Rfx433 to see if everything is ok.
Does anybody know if there is a simple solution to copy the complete configuration of a working Domoticz running on a Raspberry Pi to Domoticz on Synology ?
Thanks for your help.
- jumbotroll
Ok. Then you have to ask Decipher to build a version for your DSM version (DSM 4.2).
The "normal" version of domoticz only support RFXCOM with USBSerial package not Zstick Aeon Labs an Zwave.
/Jumbotroll
/Jumbotroll
Jumbotroll
Jumbotroll
ctve
I've found another solution.
I've "transformed" my DS 209 in a DS 212j according to the method shown here : http://forum.synology.com/enu/viewtopic ... 0&start=30
It worked well and my "false" DS 212j can now accept DSM 5 and I can install your file which will support my Aeon Lab Zstick and my RFXtrx433.
ctve
Unfortunately, it doesn't work for me.jumbotroll wrote: ... The "normal" version of domoticz only support RFXCOM with USBSerial package ...
/Jumbotroll
My RFXCOM isn't detected which is confirmed by the fact that the log shows an error message saying that the /dev/ttyUSB0 port is in error (error code 19).
- jumbotroll
@ctve
Maybe there is a compatibility problem with USBSerial package and your Synology.
Try to describe your problem on this forum : http://forum.synology.com/enu/viewtopic ... 55&t=82843
Jumbotroll
Jumbotroll
Jumbotroll
Jumbotroll
