dzVents says device does not exist
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Kedi
Domoticz version: latest
Post by Kedi »
I have a some 30 devices that start with the name 'Zolder' and 1 group called 'Zolder'
All devices work fine and some are controlled by dzVents.
I have 1 device (switch) called 'Zolder Airco' which dzVents does not know about.
sName = dz.devices('Zolder Airco') give nil for sName
Half of the devices have a space in the name after 'Zolder' the other half not.
If I change the name to 'Zolder_Airco' (notice the underscore) then the dzVents scripts works fine.
There are no duplicate names that start with 'Zolder'
I deleted the device and let Domoticz create it again, but the problem is still present.
Has anyone a solution or knows what the problem is?
habahabahaba
Domoticz version: 2024.4
Re: dzVents says device does not exist
Post by habahabahaba »
The solution is to use idx of device
Kedi
Post by Kedi »
That's not a solution, but a workaround.
I don't use idx in my scripts, it is meaningless.
From a name you can follow the flow of a script.
I have scripts that use more then 3 devices, and then it hard to follow the flow when idxes are used.
Some of those script sizes are greater then 10 Kb (including comments and comments may be 60%)
habahabahaba
Meaningless??!! This is the only correct solution IMHO to avoid getting confused by device names if you have quite a lot of them.
What if you suddenly decide to rename a device? Will you look for all the scripts in which it is involved?
And if you know the device’s ID, there’s no problem with logging its name.
imautohuttraeger
Domoticz version: lat.beta
Post by imautohuttraeger »
I also use IDX in scripts in order to avoid problems when a device is renamed. For better "readability", I simply put the name of the device in a comment in the same line.
Stop, look and listen.
Domoticz version: 2026.3
Using IDX is NOT the solution.
Dzvents is developed on top of the Domoticz Lua integration and the Lua integration can only select devices based on name.
So if you use IDX in a dzvents script dzvents asks Lua which device could be the given IDX. It will return the first device name.
But why it cannot find device 'Zolder Airco' while it could find something like 'Zolder Light' is indeed a little bit strange.
imautohuttraeger
waltervl wrote: Wednesday 25 November 2026 18:58 So if you use IDX in a dzvents script dzvents asks Lua which device could be the given IDX. It will return the first device name.
It seems that I am too dull-witted and missing something. Why do I have to care that in the background it searches for the match of the idx to it's name? It works (never had problems) and I can rename a device whenever I want ...
Last edited by imautohuttraeger on Wednesday 25 November 2026 22:31, edited 1 time in total.
habahabahaba
Try this code
-- hexdump.lua
local function hex(s)
	return (s:gsub('.', function(c) return string.format('%02X ', c:byte()) end))
local function byteAt(s, i)
	local b = s:byte(i)
	return b and string.format('0x%02X', b) or '(нет)'
local function firstDiff(a, b)
	for i = 1, math.max(#a, #b) do
		if a:byte(i) ~= b:byte(i) then return i end
	return nil
	on = { timer = { 'every minute' } },
	execute = function(dz, _)
		-- IMPORTANT: COPY problem device name byte to byte from script
		local target = 'Zolder Airco'
		dz.log(('LITERAL: [%s] len=%d hex=%s'):format(target, #target, hex(target)), dz.LOG_FORCE)
		local found = false
		dz.devices().forEach(function(dev)
			if dev.name:find('Zolder', 1, true) or dev.name:find('Airco', 1, true) then
				local eq = (dev.name == target)
				if eq then found = true end
				dz.log(('idx=%d [%s] len=%d hex=%s%s'):format(
					dev.id, dev.name, #dev.name, hex(dev.name),
					eq and '  <== direct entry' or ''), dz.LOG_FORCE)
				if not eq and dev.name:find('Airco', 1, true) then
					local d = firstDiff(dev.name, target)
					if d then
						dz.log(('  the first discrepancy in the byte %d: device=%s, literal=%s'):format(
							d, byteAt(dev.name, d), byteAt(target, d)), dz.LOG_FORCE)
		end)
		if not found then
			dz.log('No direct entry in dzVents (Used / hardware).', dz.LOG_FORCE)
May be there are hidden simbols in the name
imautohuttraeger wrote: Wednesday 25 November 2026 21:02
As long as you have unique names there is no issue. But when you have the same names for devices you can have issues with using either IDX or names in dzvents. It could go right but it also can go wrong and select the incorrect device (in both cases).
habahabahaba
waltervl wrote: Wednesday 25 November 2026 18:58 Using IDX is NOT the solution.
Waltervl, i think you are wrong.
In dzVents/runtime/Domoticz.lua - link there is the function
function self._getItemFromData(baseType, id)
		local res
		for index, item in pairs(_G.domoticzData) do
			if (item.baseType == baseType) then
				if (item.id == id or item.name == id) then
					if (res == nil) then
						res = item
						utils.log('Multiple items found for ' .. tostring(id) .. ' (' .. tostring(baseType) .. '). Please make sure your names are unique or use ids instead.', utils.LOG_ERROR)
		return res
And the first condition "if (item.id == id or item.name == id) then" is a search by ID.
Yes, it is somewhat more complicated, see issue: https://github.com/domoticz/domoticz/issues/7143
imautohuttraeger
waltervl wrote: Wednesday 25 November 2026 23:37
Ah - thank you for the explanation. Now I've got you. This is indeed a problem. But if you use a device name and two devices have identical names, it can also go wrong, if the first match is not the intended one, right?
imautohuttraeger wrote: Thursday 26 November 2026 12:21
waltervl wrote: Wednesday 25 November 2026 23:37 As long as you have unique names there is no issue. But when you have the same names for devices you can have issues with using either IDX or names in dzvents. It could go right but it also can go wrong and select the incorrect device (in both cases).
Yes, that was what I am trying to tell ;-)
For identical names in Domoticz beta, dzvents will warn about it in the log file when you try to find a device that has a twin device (see the github issue I mentioned before)
