dzVents says device does not exist
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Kedi
Domoticz version: latest
Post by Kedi »
I have a some 30 devices that start with the name 'Zolder' and 1 group called 'Zolder'
All devices work fine and some are controlled by dzVents.
I have 1 device (switch) called 'Zolder Airco' which dzVents does not know about.
sName = dz.devices('Zolder Airco') give nil for sName
Half of the devices have a space in the name after 'Zolder' the other half not.
If I change the name to 'Zolder_Airco' (notice the underscore) then the dzVents scripts works fine.
There are no duplicate names that start with 'Zolder'
I deleted the device and let Domoticz create it again, but the problem is still present.
Has anyone a solution or knows what the problem is?
habahabahaba
Domoticz version: 2024.4
Re: dzVents says device does not exist
Post by habahabahaba »
The solution is to use idx of device
Kedi
Post by Kedi »
That's not a solution, but a workaround.
I don't use idx in my scripts, it is meaningless.
From a name you can follow the flow of a script.
I have scripts that use more then 3 devices, and then it hard to follow the flow when idxes are used.
Some of those script sizes are greater then 10 Kb (including comments and comments may be 60%)
habahabahaba
Meaningless??!! This is the only correct solution IMHO to avoid getting confused by device names if you have quite a lot of them.
What if you suddenly decide to rename a device? Will you look for all the scripts in which it is involved?
And if you know the device’s ID, there’s no problem with logging its name.
imautohuttraeger
Domoticz version: lat.beta
Post by imautohuttraeger »
I also use IDX in scripts in order to avoid problems when a device is renamed. For better "readability", I simply put the name of the device in a comment in the same line.
Stop, look and listen.
