Controlling Nefit Easy with Domoticz
njlammerts
- Domoticz version: 2022.2
I have been searching for an answer/topic , but could not find it in the Heating/Cooling section.
I have a Nefit Central Heating Unit wich is controlled by a Nefit-Easy Temperature Control Unit, placed central in the living room.
I Installed the Nefit-Easy tool in Domoticz on Raspberry 4+ and previous on a Pi Zero W (alternative json and npm installation) and now I can read temperature, Gas use, time when Unit is on-off and can also set temperature via Domoticz if I want to. (https://tech.ligthartnet.nl/make-your-n ... h-domoticz)
The upper floor with bathroom and bedrooms have a thermostatic valve on the CV radiators. A problem of this setup is, that the upper floor can be cold if the living room sensor is "out" because the temperature is = or > then the set temperature (the sun can warm up the room, even in winter)
On the first floor the temperature can be chill (nice for sleeping) but I want to use on of the rooms as a kind of office to do work from home.
My idea is to place a temp sensor on the first floor and fit remote (Zigbee/Zwave) Thermostat Valves on the radiators below and set them to a certain temp (20.5C) and set the room sensor (Nefit Easy) to 20C , so the temperature is regulated by the Nefit Easy Room sensor.
When I want extra heat on the first floor, I want to use Domoticz to use the temperature sensor from first floor and temporarily set the temperature of the Nefit Easy to 21C, so the heater keeps on heating, although the temperature on first floor is > 20.5C , so the thermostats are closed and the warm water is send all to first floor. When the set temp for first floor is reached , Domoticz should switch of the "bypass" temperature and the CV heater goes down or in modulating mode.
What is the best way to achieve this?
What are the best remote Thermostatic valve controllers (Zigbee/Zwave)?
How to "control" the SetPoint of Nefit-Easy appliance on Raspberry?
What is a good remote temperature sensor (Xiaomi Aqara)?
Can I use Blocky to control the Remote Thermostatic valve controllers?
Any positive answer would be nice
Tukker
- Domoticz version: 2023.2
Re: Controlling Nefit Easy with Domoticz
Aquara is a beautiful solution.
Another solution is ESP8266 with BMP280 or BME280 which allows you to build it up from ground.
Bugs bug me.
njlammerts
Which devices are compatible with Philips Hue? All my Hue Devices (lights, INNR smart socket) are seen by Domoticz (through Philips Hue Bridge)
Aquara / Aqara / Xiaomi
Sonoff
Tuya
or do I need a new bridge/Gateway to connect the devices to Domoticz?
I would prefer Zigbee over Zwave and WiFi because it uses much less power wich is important for battery driven devices.
Sonoff
Tuya
- Domoticz version: 2026.3
I have a Nefit Easy thermostat and Maxcube smart radiator valves. I also have Zigbee devices controlled by Zigate. I do not know if it is possible to use Zigbee radiator valves through a Huge bridge. Zigate supports at least the Eurotronics spirit valves.
I have my bathroom radiator always open. Normally this is enough. I also have a fireplace so when the fireplace is in operation you can use the nefit easy fireplace option to have some heat to the upper floors. I then lower the temperatures of the valves in the living room.
I programm this in dzvents as this is more flexible than blocks
Jan-
I would also try to manage the temperature settings by Domoticz for the Nefit easy. I have installed domoticz on a windows 10 pc. Can anyone describe what i need to do to make it work? I understand that the option for the easy is not fully integrated in the domoticz software it self?
Regards,
Jan.
Regards,
Jan.
The installation of the prerequisites and the scripts on a Linux machine are described here: https://www.domoticz.com/wiki/NefitEasy
You will have to find a way to install all the prerequisites like nodejs, npm and pm2 on windows. I am not familiar with those.
Are you sure you have a Nefit Easy? As there is also a new Bosch EasyControl that is not fully compatible yet with Domoicz.
Jan-
Yes I'm using the Nefit easy.
Sorry, this isn't really a/the answer to your question, so see this post as a side note...
I do not know the advantages of the "Nefit Easy", but it seems to me it isn't easy at all with domoticz.
I have a Nefit Boiler, the most cheap Themostat(Moduline 100) there is, and have complete control of the Nefit system from domoticz/mqtt with only this: https://bbqkees-electronics.nl . Just plug the device in the boiler, set it up for MQTT, install the domoticz plugin, and go. No need for Nefit Easy server, no external scripts, java or other things that will keep you from backing up/restoring your domiticz(working config backup) on ANY other device with just a few clicks when somethings goes wrong.
https://bbqkees-electronics.nl/ems-devi ... atibility/ --> however, it seems that Nefit Easy isn't supported for "write".
As a alternative, buy another thermostat that is supported(moduline 100 costs about 50 euro's) and use that.
schipper
I have a Nefit Easy thermostat. I run Domoticz on a windows 10 laptop.
In the "hardware" I have installed the Nefit Easy and saved it.
In the Nefit Domoticz wiki document are a lot of things I do not understand as f.i. installing something to access a Nefit server. But the lines in there do not look familiar to me.
So what am I doing wrong ?
aircendro
Hi schipper — you are not doing anything wrong, you are just hitting the Windows part of the setup. Adding the Nefit Easy hardware in Domoticz only creates the device in Domoticz; the actual connection to the thermostat is done by a separate helper (nefit-easy-server), which is what the wiki page is describing with Node.js, npm and pm2.
On Windows 10 the practical route is:
1. Install the Node.js LTS package from nodejs.org (this also gives you npm).
2. Install the nefit-easy-server package with npm and run it once from a command prompt, entering your Nefit Easy serial number, access key and password when it asks. If it starts without errors and shows the thermostat data, the server side is working.
3. Then check that Domoticz can reach it on localhost, and look at the Domoticz log (Setup > Log) — if it reports it cannot connect, the helper is not running or is listening on a different port.
One thing waltervl also flagged above that is worth double-checking first: make sure your thermostat really is a Nefit Easy and not the newer Bosch EasyControl, which uses a different connection and is not fully compatible with this hardware.
If the helper fails to start, paste the exact error message from the command prompt here and someone can point at the failing step. Good luck!
@schipper
Step 1, install nefit-easy-server https://github.com/robertklep/nefit-easy-http-server
Please read the wiki for Nefit Easy carefully:https://wiki.domoticz.com/NefitEasyI really don't know what you mean by
1. installing a Nefit Easy SERVER (what "server"? on what platform ? )
2. on a Domoticz SERVER (what is a Domoticz "server" and where do I find it ?
3. the line that you mentioned starting with "curl", what is it and what should I do with it ? I still remind you I'm using a Windows 10 laptop so I would not know what to do with that line and where to place it.
schipper
@ aircendro
So I understand that something more is needed.
But the problem is that all you say there is abacadabra to me.
I have downloaded from node and then all I see is totally new to me and I do not know what to do with it.
I do not want to make mistakes and ruin my laptop, because I need the thing for several purposes
What do I have to do to get it done ?
jannl
- Domoticz version: 2026.1.x
A laptop is propably not the best applicance to run Domoticz, unless you are only testing.
The links waltervl provides are linux links and should executed in Linux.
I used to have Nefit Easy untill I upgraded to Tado.
Opensource software requires some manual interaction. Bottom line, you will learn a lot
schipper
I clearly said time after time that I use a laptop Windows 10
I think that not so many users run linux. So I think it must be possible to use it under windows when you can install on Windows.
Tado is again something I've never heard of
I'm 79 but I can learn when it is easy. I'm to old to start learning programming again. An d as saif I think that is not what Domoticz is made for. Most people don'know anything abaout Linux, Tado and whatever.
So If anybody van give an step by step explication of what to do, I would be grateful.
Thank you.
Thank you.
RNEE
- Domoticz version: 2026.4
This not going to work this way, too bad.
Also the "Nefit not so easy to setup thermostat" is like my own thermostat very difficult to setup for a newcomer
Options are using an AI assistant to help set up step by step. You can use Google or Claude.
I have very good results with Claude.
You can input your questons, other problems and errors in the AI assistant.
It can help with solving your problems.
By the way : not everything works with Windows, thats why most of us are on Linux.
Domoticz (since 2016) on Docker on Raspberry PI 5 with 500 Gb NVMe|Milight|KaKu + RFXCOM|Goodwe|Smartstuff P1 meter|Buienradar|Afval kalender|Tuya-wifi|Zigbee + deCONZ Conbee II|Marstek 5,12Kwh via Modbus on Pusr-dr134|MQTTMapper|Quatt v2|DTGbot|
This what I get when i google on installing nefit-easy-server on windows system:schipper wrote: Friday 20 November 2026 13:56 I clearly said time after time that I use a laptop Windows 10
Thank you.
To run the Nefit Easy HTTP server (nefit-easy-http-server) on Windows, install Node.js and use npm to install the easy-server CLI globally.
1. Install Node.js
• Download and install the Node.js LTS installer for Windows from the official Node.js website (this includes npm).
• Restart your Command Prompt or PowerShell window after installation so node and npm are available in your PATH.
2. Install nefit-easy-http-server
Open Command Prompt or PowerShell and run:
powershellThis installs the easy-server command-line tool globally.Code: Select all
npm install nefit-easy-http-server -g
3. Start the Server
Run easy-server with your Nefit Easy credentials (without spaces or hyphens):
powershellAlternatively, set environment variables in PowerShell before running easy-server:Code: Select all
easy-server --serial=YOUR_SERIAL --access-key=YOUR_ACCESS_KEY --password=YOUR_PASSWORD --host=127.0.0.1 --port=3000
powershellBy default, the server listens on http://127.0.0.1:3000/ and exposes /bridge/ and /api/ endpoints,for example:Code: Select all
$env:NEFIT_SERIAL_NUMBER="YOUR_SERIAL" $env:NEFIT_ACCESS_KEY="YOUR_ACCESS_KEY" $env:NEFIT_PASSWORD="YOUR_PASSWORD" easy-serverCode: Select all
http://127.0.0.1:3000/api/status
jannl
I disagree, most users propably use Linux as far as I know. Also the explanation in the Wiki mostly refer to Linux.schipper wrote: Friday 20 November 2026 13:56 I clearly said time after time that I use a laptop Windows 10
Thank you.
Also a tool like Domoticz requires a lot of user interaction and inverstigation. In spite of being on the Domoticz forum a being a big fan of Domoticz, I would say you are better of with HomeAssistant which (as far as I know) is configuration wise easier nowadays.
Using a AI chatbot like chatgpt, claude, copilot or gemini (or some other) are of great assistance.
What I remember from the time I used Nefit Easy, it was never one of the easier integrations. I also had to downgrade the firmware on the thermostat in order to enable XMPP, which was disabled bij Bosch.
