new installation Added "hardware" does not work
schipper
Hello, new here and a new user of Domoticz.
Have installed it (I think local) and have added in "hardware" my "NEFIT EASY server over LAN interface" and also my "Enphase Envoy with LAN (HTTP) interface". Also my DAHUA IPCam. Nothing worked in the Dashboard. I don't know why but suddenly the IPCam came up on the Dashboard, so that is working now, but the other two still do not show up and I don't know how I should do that.
Soon I will get me a P1 meter (I guess that works on wifi and will also be on my router). NEFIT and ENPHASE are on my router and I inserted the IP adresses of them in "hardware"
So question is: What am I doing wrong or have I forgot, or do I not understand. Please HELP
RNEE
- Domoticz version: 2026.4
Re: new installation Added "hardware" does not work
Something is wrong with the clock? Its 19.00 now over here.
Did you run “allow new hardware devices” on the settings page.
Are devices created on the devices page ?
Domoticz (since 2016) on Docker on Raspberry PI 5 with 500 Gb NVMe|Milight|KaKu + RFXCOM|Goodwe|Smartstuff P1 meter|Buienradar|Afval kalender|Tuya-wifi|Zigbee + deCONZ Conbee II|Marstek 5,12Kwh via Modbus on Pusr-dr134|MQTTMapper|Quatt v2|DTGbot|
schipper
I run Domoticz on a windows 10 laptop
I added the hardware via the settingspage top "hardware"
The Dahua IPCam via "more options" and that is now working.
The NEFIT and ENPHASE are the items connected to my router and I used the IP's of those according to the router.
I have no idea how to see those items in Dashboard and how to get that done.
I want tot see my solarpanels via ENPHASE (same as in the Enphase software also)
RNEE
https://wiki.domoticz.com/Getting_started
When you configure hardware that is step 1, you then need Domoticz to create devices for the data coming in. (step 2)
For that you have to allow devices to be created in the settings menu.
Setup->settings->system-> accept new hardware devices.
You then can see communication from these devices in the Setup -> Log
When you click Setup->devices you can then see the devices but they have to be activated (set : used) (Step 3) to be seen in their device page in the menu. A lamp switch comes then in Switches, others in temperature , weather, utility etc.
At that group device page you can then by using the favoriet star (step 4) to add the devices you want on your Dashboard.
schipper
Yes I did all that, but I did and don't see any new devices.
I'm not talking about switches, lights, etc.
I want to see my thermostat NEFIT EASY and my solarpanels (8) Enphase Envoy
There are special tutorials about those two items and I followed what's in there. But still no results.
RNEE
We need more info than this.
Can you post pictures of your hardware setup pages, the devices page and log ?
jannl
- Domoticz version: 2026.1.x
Can you ping the ip's of the hardware? No firewall running on your windows?
schipper
I pinged the Enphase solarpanels IP and that did reply. However the Nefit IP did not reply (timed out).
There is a standard Enphase tool to show my solarpanels and that works on my laptop so the connection on the router is working.But not on Domoticz.
There is also a Nefit app running on the smartphone of my wife and that is also running, but on my laptop no ping reply.
Yes Windows firewall is up.
Pictures of the hardware are the standard picture as you choose the items Enphase and Nefit and I used the ports that are told in the tutorials of both on wiki. And of course I will not show you pictures with IP's and everything in it. I hope you'll understand.
Picture of the "devices" is the standard list in "device". The tutorial says there should be added devices for every solarpanel . But that is not.
The IPCam (Dahua) also on the same router does work on Domoticz. So that signal comes through.
Rik60
- Domoticz version: 2026.3
This is my Enphase hardware setup. I have hide the information what i don't want to share. Normaly you only see the totals of the power/ energy. To see the individual inverters you have to enable 'Poll Inverters'. Remote address is your Enphase ip address.
- Schermafbeelding 2026-11-17 114146.png (53.33 KiB) Viewed 280 times
peterchef
- Domoticz version: 2024.7
On my envoy installation on windows i have used port 80
Windows, Domoticz
Aeotec Z-Stick Gen5, Aeotec Multisensor 6, Horstmann HRT4-ZW Thermostat Transmitter, Horstmann ASR-ZW Thermostat Receiver
Zipato Mini Keypad RFID, Everspring AN157 Plug
Rik60
Maybe you can check the security settings, see screenshot
- Schermafbeelding 2026-11-17 123535.png (170.28 KiB) Viewed 242 times
jannl
Those settings are mainly(only) for connection to the user interface, not for connected hardware.
schipper
Thank you all.
1. I do not have switched etc. Just Enphase Envoy Solarpanels and my NEFIT Easy thermostat
2. You all use different ports for Enphase (I used what was said in the tutorial (80)) But it makes no difference
3. checked security panel and added the own router IP as trusted netword
from the log
Error: Zonnepanelen: Invalid data received! (no xml/envoy_info Don't know what it means
Error: NEFIT: Error getting http data! Don't know what it means
About NEFIT as I said a ping does not reply, but Enphase does reply.
from the log
For a Nefit Easy, did you install the Nefit Easy server on the Domoticz server?
And what happens if you type in the following command line on the Domoticz server:
If it does not give results the Nefit Easy server is not running. Install it or troubleshoot as mentioned in the Nefit Easy wiki page.
curl http://127.0.0.1:3000/api/statusDomoticz running on Udoo X86 (on Ubuntu)
Ah I see now you already mentioned the Nefit issue in another topic but you did not reply yet. Better have the Nefit Easy part discuss there : viewtopic.php?p=336528#p336528waltervl wrote: Tuesday 17 November 2026 22:53 For a Nefit Easy, did you install the Nefit Easy server on the Domoticz server?
And what happens if you type in the following command line on the Domoticz server:If it does not give results the Nefit Easy server is not running. Install it or troubleshoot as mentioned in the Nefit Easy wiki page.Code: Select all
schipper
I hope you don't mind but this Nefit Easy question was my topic (together with the solarpanels issue).
So I'll go on with it here. I fear that otherwise things will cross or will not be clear but confusing .
It does not mind that my topic is answered in my question, is it ?
So Waltervl about your answer:
I really don't know what you mean by
1. installing a Nefit Easy SERVER (what "server"? on what platform ? )
2. on a Domoticz SERVER (what is a Domoticz "server" and where do I find it ?
3. the line that you mentioned starting with "curl", what is it and what should I do with it ? I still remind you I'm using a Windows 10 laptop so I would not know what to do with that line and where to place it.
Sorry but I'm just an ols man and simple "user" and nothing more.I don't know what it means but I can learn. That's why I ask my questions here.
Rik60
For your Enphase problem,
As a test i have Domoticz installed on my Windows computer. 2 questions:
Do you have an api key in the user variables?
Have you enabled Accept new hardware (System settings)?
After saving an Api key in the user variables and accept new hardware i received data from my Envoy.
- Schermafbeelding 2026-11-18 105414.png (60.92 KiB) Viewed 86 times
schipper
@Rik60
No idea what api key is.
Accept new hardware was enabled.
I found the picture you sent. Added as in the picture but what should be in the red box ? It says user varaiable saved, but then it is nowhere visible anymore. I did not fill anything in the red box. Don't know what.
RNEE
Most of us over here are ols man and simple users, ahum...schipper wrote: Wednesday 18 November 2026 1:08 Sorry but I'm just an ols man and simple "user" and nothing more.I don't know what it means but I can learn. That's why I ask my questions here.
This is an open-source community so we try to help each other.
It helps to read about things like "api " and using a "rest api" tool as a plugin in your browser or so.
i use Rester in Firefox on Ubuntu linux.
It opens a completely new communication world.
You can even use the command line in windows if you like, but that is another problem.
Rik60
If you don't have an api key (or access code), you have to create one, go to this website:schipper wrote: Wednesday 18 November 2026 13:01 @Rik60
https://entrez.enphaseenergy.com/
