new installation Added "hardware" does not work
schipper
Post by schipper »
Hello, new here and a new user of Domoticz.
Have installed it (I think local) and have added in "hardware" my "NEFIT EASY server over LAN interface" and also my "Enphase Envoy with LAN (HTTP) interface". Also my DAHUA IPCam. Nothing worked in the Dashboard. I don't know why but suddenly the IPCam came up on the Dashboard, so that is working now, but the other two still do not show up and I don't know how I should do that.
Soon I will get me a P1 meter (I guess that works on wifi and will also be on my router). NEFIT and ENPHASE are on my router and I inserted the IP adresses of them in "hardware"
So question is: What am I doing wrong or have I forgot, or do I not understand. Please HELP
RNEE
Domoticz version: 2026.4
Re: new installation Added "hardware" does not work
Post by RNEE »
Something is wrong with the clock? Its 19.00 now over here.
Did you run “allow new hardware devices” on the settings page.
Are devices created on the devices page ?
Domoticz (since 2016) on Docker on Raspberry PI 5 with 500 Gb NVMe|Milight|KaKu + RFXCOM|Goodwe|Smartstuff P1 meter|Buienradar|Afval kalender|Tuya-wifi|Zigbee + deCONZ Conbee II|Marstek Homebattery 5,12Kwh via Modbus on Pusr-dr134|MQTTMapper|Quatt v2|
schipper
Post by schipper »
I run Domoticz on a windows 10 laptop
I added the hardware via the settingspage top "hardware"
The Dahua IPCam via "more options" and that is now working.
The NEFIT and ENPHASE are the items connected to my router and I used the IP's of those according to the router.
I have no idea how to see those items in Dashboard and how to get that done.
I want tot see my solarpanels via ENPHASE (same as in the Enphase software also)
RNEE
Post by RNEE »
https://wiki.domoticz.com/Getting_started
When you configure hardware that is step 1, you then need Domoticz to create devices for the data coming in. (step 2)
For that you have to allow devices to be created in the settings menu.
Setup->settings->system-> accept new hardware devices.
You then can see communication from these devices in the Setup -> Log
When you click Setup->devices you can then see the devices but they have to be activated (set : used) (Step 3) to be seen in their device page in the menu. A lamp switch comes then in Switches, others in temperature , weather, utility etc.
At that group device page you can then by using the favoriet star (step 4) to add the devices you want on your Dashboard.
schipper
Post by schipper »
Yes I did all that, but I did and don't see any new devices.
I'm not talking about switches, lights, etc.
I want to see my thermostat NEFIT EASY and my solarpanels (8) Enphase Envoy
There are special tutorials about those two items and I followed what's in there. But still no results.
RNEE
Post by RNEE »
We need more info than this.
Can you post pictures of your hardware setup pages, the devices page and log ?
jannl
Domoticz version: 2026.1.x
Post by jannl »
Can you ping the ip's of the hardware? No firewall running on your windows?
