Version: v2026.4
Platform: RaspberryPi 5 / Trixie
Plugin/Hardware: MQTT AD / IKEA Starkvind
Description:
After updating from 2026.3 to 2026.4 everything worked except the IKEA Starkvind airpurifier. When trying to change the Fan Mode in Domoticz trough the Selector Switch it now gives the following error in the log:
Error: MQTT AD: fan device unhandled mode_state_template (0x2c1165fffea62ad2_fan_zigbee2mqtt/0x2c1165fffea62ad2)
And control off the device is not posible. But all the info like air quality and pm2 value's are coming in. It's just not possible anymore to control the device.
When going to the Zigbee2MQTT page and i want to change the fan mode there it works and it changes the Fan Mode. Also the good fan modes are displayed on the Selector switch in Domoticz.
But when i want to change the fan mode trough Domoticz again, it gives the same error as above again.
This behavior was not present before the update to v2026.4, therefore i posted it here.
Is there a way to fix this?
MQTT Auto Discovery, fan device unhandled mode_state_template Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
- Didi
- Domoticz version: 2026.4
Main: RPI-5 / Zigbee / Sonoff / RFLink433 / Camera's / Wifi / Custom Interface / Alarm / GPS / MQTT / MiLight
- gizmocuz
Re: MQTT Auto Discovery, fan device unhandled mode_state_template
Did you try upgrading to the latest beta version?
Always try this first
- Didi
I updated to v2026.4 (build 18645) and indeed i can control all again! This seems to fix itgizmocuz wrote: Tuesday 17 November 2026 7:01 Did you try upgrading to the latest beta version?
Thank you so much for the quick reply!
