For anyone struggling (like I did) to get the initial setup done with automatic creation of devices:
The username and password that you need to fill on the config screen when you add this Intergas Gateway in Domoticz is NOT !!! the username and password of your Intergas account that you use for the Intergas App.
Instead, you need to use username "admin" and the password that is shown on the back of your gateway. (which you can change via the web interface if you point your browser at the IP address of the gateway).
Intergas Incomfort Heater control
- Domoticz version: 2026.3
Re: Intergas Incomfort Heater control
Is there a post that describes the correct implementation? Then I can use this post to create a wiki page for this.
willemd
This post viewtopic.php?p=317232#p317232 earlier in this thread shows a word document with the installation guide.waltervl wrote: Thursday 19 June 2025 11:27 Is there a post that describes the correct implementation? Then I can use this post to create a wiki page for this.
Thanks, created wiki page https://wiki.domoticz.com/Intergas_Inco ... er_controlwillemd wrote: Thursday 19 June 2025 12:50This post viewtopic.php?p=317232#p317232 earlier in this thread shows a word document with the installation guide.waltervl wrote: Thursday 19 June 2025 11:27 Is there a post that describes the correct implementation? Then I can use this post to create a wiki page for this.
I also modified the starting post of this topic.
Let me know when something needs to be changed.
hvoorend
- Domoticz version: 2026.4
Hi I just got an Intergas InComfort LAN2RF V1 (FW V1.13 22-9-2026). The whole setup works fine through the Comfort Touch app. I added the gateway HW to Domoticz via procedure described in the WiKi https://wiki.domoticz.com/Intergas_Inco ... er_control. However from the log I see, as soon as the worker starts
No devices are being added. Anyone any idea where to look?
Not sure if that is the culprit but I know there is a newer firmware for the GW (V1.3 2022). However according to what I can find only Intergas Service people are allowed to update Gateway FW. Since this thing is no longer supported, I guess that is a dead end street.
Someone happens to know how to do that myself?
Thanks in advance for your help!
2026-11-11 21:39:23.401 Status: Intergas InComfort: Worker started...
2026-11-11 21:39:26.680 Error: Intergas InComfort: Error getting current state!
2026-11-11 21:39:26.680 Error: Intergas InComfort: Invalid data received. Data is not json formatted.Not sure if that is the culprit but I know there is a newer firmware for the GW (V1.3 2022). However according to what I can find only Intergas Service people are allowed to update Gateway FW. Since this thing is no longer supported, I guess that is a dead end street.
Raspberry Pi 2
Raspbian Bookworm
Aeon zStick Gen5 fw 1.0
RFXCOM USB
Domoticz 2024.2
Raspbian Bookworm
RFXCOM USB
Domoticz 2024.2
hvoorend
No one any suggestions?
Raspberry Pi 2
Raspbian Bookworm
RFXCOM USB
Domoticz 2024.2
Raspbian Bookworm
RFXCOM USB
Domoticz 2024.2
