Does Pro1 firmware support the Prologue-TH protocol under another protocol name?
losholmen
Post by losholmen »
**Subject: RFXtrx433E Pro1 firmware – Prologue-TH sensor support**
I have an RFXtrx433E running Pro1 firmware version 1048.
I have a Chinese 433.92 MHz temperature/humidity sensor that is successfully decoded by rtl_433 as:
- Protocol: Prologue-TH
- Channel: 2
- Sensor ID: 61
- Temperature and humidity decoded correctly
However, the sensor is not detected by my RFXtrx433E.
If not, is there another firmware version (Ext, Ext2, Pro2) that supports it?
Thank you!
gizmocuz
Re: Does Pro1 firmware support the Prologue-TH protocol under another protocol name?
Post by gizmocuz »
Best to read the manual of the device on their website, if it is not there you can always try to contact RFXCom directly.
