**Subject: RFXtrx433E Pro1 firmware – Prologue-TH sensor support**
I have an RFXtrx433E running Pro1 firmware version 1048.
I have a Chinese 433.92 MHz temperature/humidity sensor that is successfully decoded by rtl_433 as:
- Protocol: Prologue-TH
- Channel: 2
- Sensor ID: 61
- Temperature and humidity decoded correctly
However, the sensor is not detected by my RFXtrx433E.
Does Pro1 firmware support the Prologue-TH protocol under another protocol name?
If not, is there another firmware version (Ext, Ext2, Pro2) that supports it?
Thank you!
