I am using the Visual Crossing weather hardware. Domoticz creates several devices. I will focus on these two:
Type / SubType /Data
Temp + Humidity + Baro / THB1 - BTHR918, BTHGN129 / 90.5 F, 72 %, 1019 hPa
Wind / TFA / 256.00;WSW;19;43;32.5;42.7
The Wind device (I will call it DSwind) creates two sensors. One under Weather and one under Temperature.
This is the Temperature tab (along with the Temp + Humidity + Baro type called DStemp:
This is the Weather tab entries:
Note the values in the header are different.
I would expect if I clicked on the log on the Weather tab for DSwind, I would get wind information (speed, direction, etc).
I would expect if I clicked on the log on the Temperature tab for DSwind, I would get the temperature + feels like temperature graph.
This is what it used to do in previous version of Domoticz:
Yes, yes. Odd that it says "Chill" for that feels like temperature. Florida gets very humid so that hardcoded label of "Chill" should maybe get looked at also.
TFA Device Type Wind Subtype TFA Fails To Render Temp As Expected
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
wergeld
- dom_Weather.jpg (44.95 KiB) Viewed 389 times
- gizmocuz
Re: TFA Device Type Wind Subtype TFA Fails To Render Temp As Expected
To find out what changed we need to see the screenshots side by side and the version you are on now. Could you open an issue on GitHub (https://github.com/domoticz/domoticz/issues) with the Domoticz version, the screenshots of the Temperature and Weather tab logs (old and new) and the device data line? Then we can follow it up there.
