TFA Device Type Wind Subtype TFA Fails To Render Temp As Expected
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
wergeld
Post by wergeld »
I am using the Visual Crossing weather hardware. Domoticz creates several devices. I will focus on these two:
Type / SubType /Data
Temp + Humidity + Baro / THB1 - BTHR918, BTHGN129 / 90.5 F, 72 %, 1019 hPa
Wind / TFA / 256.00;WSW;19;43;32.5;42.7
The Wind device (I will call it DSwind) creates two sensors. One under Weather and one under Temperature.
This is the Temperature tab (along with the Temp + Humidity + Baro type called DStemp:
This is the Weather tab entries:
Note the values in the header are different.
I would expect if I clicked on the log on the Weather tab for DSwind, I would get wind information (speed, direction, etc).
I would expect if I clicked on the log on the Temperature tab for DSwind, I would get the temperature + feels like temperature graph.
This is what it used to do in previous version of Domoticz:
Yes, yes. Odd that it says "Chill" for that feels like temperature. Florida gets very humid so that hardcoded label of "Chill" should maybe get looked at also.
