🎉 Zigbee for Domoticz — stable9 / 9.1.001 is out!
Domoticz version: 2026.3
Re: 🎉 Zigbee for Domoticz — stable9 / 9.1.001 is out!
BartSr wrote: Saturday 15 August 2026 12:19 Just curious. Any advance compared to z2m?
No need for MQTT when you have no other MQTT integrations.
No need for docker of you don't like docker (but z2m can also run without docker).
Functional it has no real advantages only that it does not make a lot of usesless devices for all node options.
Fredom
Post by Fredom »
Rik60 wrote: Friday 14 August 2026 19:39 Finally succeded to switch to stable9 9.1.002 from stable8 8.1.008. This is what i did:
- From the ui (user interface) updated the plugin
Then from the comman line:
switch to the plugin directory: cd domoticz/plugins/Domoticz-Zigbee
- set owner to pi: sudo chown -R pi:pi .
- go to the tools directory: cd Tools
- from command line executed: bash plugin-switch-stable9.sh --i-understand
This fails now, had to stash: git stash
again: - from command line executed: bash plugin-switch-stable9.sh --i-understand
Ok, switched the stable9 without errors
switched to the ui and updated the plugin -> updated stable9 without errors
Restarted the plugin in the ui
In the domoticz log errors: something to do with domoticz and domoticzex framework, both running on the same time
Rebooted the Rpi
No errors in the log
No Zigbee tab in the main domoticz screen -> Settings -> settings -> save settings
Ah, Zigbee tab in main screen
Can control Zigbee powerplug -> plugin works and actual version is 9.1.002
So, finally succes to switch to Stable9.
I hope that this can help other users.
Hi Rik60
Unfortunately, still the same error message.
fredom@raspberrypi:~/domoticz/plugins/Domoticz-Zigbee/Tools $ sudo git stash
No local changes to save
fredom@raspberrypi:~/domoticz/plugins/Domoticz-Zigbee/Tools $ bash plugin-switch-stable9.sh --i-understand
Checking Domoticz version and stable9 migration notice...
  File "/home/fredom/domoticz/plugins/Domoticz-Zigbee/Tools/check_stable9_migration.py", line 184, in <module>
    main()
  File "/home/fredom/domoticz/plugins/Domoticz-Zigbee/Tools/check_stable9_migration.py", line 168, in main
    display_migration_notice(version_status)
  File "/home/fredom/domoticz/plugins/Domoticz-Zigbee/Tools/check_stable9_migration.py", line 124, in display_migration_notice
    print("English:\n" + english + "\n")
UnicodeEncodeError: 'latin-1' codec can't encode character '\u2014' in position 1292: ordinal not in range(256)
Error: Domoticz version requirement not met. Cannot switch to stable9 branch.
Yours sincerely,
Fred
Rasberry Pi 3B+ - Debian Trixie - Domoticz 2026.3
RFLink - RFXCom - Z4D 9.1 (CC2652rb)
P1 Smart Meter - KaKu
Rik60
Post by Rik60 »
Fredom wrote: Saturday 15 August 2026 15:44
Rebooted the Rpi
Hi Rik60
    main()
I was able to switch to Stable9 before but ran into problems after that. In the Zigbee-Domoticz folder i found some files that had 'root' as owner so thats why i did the 'chown'. Also had to 'stash' because there were some local changes in some files. I don't where the changes came from, i was always to preform an update thru the ui.
Are you able to switch back to Stable8 (restore a backup?) and do to update again. Otherwise someone else (Pipiche?) can help, knows what it means.
Fredom
Post by Fredom »
Z4D is already on version 8.1, so that’s not the problem; the issue is simply that the update to 9.1 isn't working.
Thanks for your help and your reply; I hope Pipiche can look into this and provide a solution.
Yours sincerely,
Fred
Rik60
Post by Rik60 »
Fredom wrote: Saturday 15 August 2026 21:34 Z4D is already on version 8.1, so that’s not the problem; the issue is simply that the update to 9.1 isn't working.
I have ask Chatgpt what the problem could be, uploaded the file 'check_stable9_migration.py' and your error into chatgpt, the answer was that there is an letter isn't a latin-1 code, with a solution. You could try it yourself with chatgpt.
This was the answer Chatgpt gave me:
Ja. Het probleem is vrij duidelijk: je Python-script zelf werkt, maar de terminal gebruikt latin-1 als output-encoding terwijl het script een Unicode-teken probeert te printen dat niet in Latin-1 zit.
De fout is:
'\u2014' is de em dash:
Die staat in jouw script op meerdere plekken. Bijvoorbeeld op regel 158:
version_status = f"Detected Domoticz {detected[0]}.{detected[1]} at http://{args.ip}:{args.port} — Extended Framework requirement satisfied."
Ook in de Franse tekst staat er één:
"  Le basculement lui-même est rétrocompatible : ... 'stable9' —\n"
Dat wordt ook bevestigd door de encoding van je bestand: het bestand is netjes als UTF-8 gedeclareerd met # -*- coding: utf-8 -*-, dus het Python-bestand is op zichzelf correct UTF-8.
I don't know why i didn't have this error, i almost have the same system as you.
Fredom
Post by Fredom »
Thanks, I'll give this a try.
I never thought to run this by ChatGPT.
Yours sincerely,
Fred
Rik60
Post by Rik60 »
Fredom wrote: Sunday 16 August 2026 12:30 Thanks, I'll give this a try.
Another point to look at, wat is your region setting?
If you type: 'locale' (without the ') on the rpi command line, what is the answer? Latin-1 or utf-8? If it is latin-1 then that could be the problem. You can change it running the rpi config (sudo raspi-config, then option 5) and set it to UTF-8
Fredom
Post by Fredom »
Hi Rik60,
Thanks to your tip about ChatGPT, I managed to get onto Z4D 9.1, but unfortunately, the plugin stopped working after that. So, I went back to ChatGPT; I spent over two hours on it, but I feel like I'm just going in circles. I’ve stopped for now and restored a backup. If there’s no solution, so be it—luckily, it runs well without errors on 8.1. Thanks for your help, though.
Yours sincerely,
Fred
Fredom
Post by Fredom »
I finally managed to upgrade Z4D to version 9.1 on my test system using ChatGPT. I'll probably have to re-pair everything, but that’s not a big deal. ZigBeeforDomoticZ plug-in Admin Interface
Version 9.1.002
Yours sincerely,
Fred
Rik60
Post by Rik60 »
Fredom wrote: Monday 17 August 2026 10:47 I finally managed to upgrade Z4D to version 9.1 on my test system using ChatGPT. I'll probably have to re-pair everything, but that’s not a big deal. ZigBeeforDomoticZ plug-in Admin Interface
Version 9.1.002
Nice job. What did you had to do to make ik work?
Fredom
Post by Fredom »
Hi Rik60,
After a review by ChatGPT, almost everything related to Zigbee was redone. I think I executed at least 50 commands from ChatGPT before I got version 9.1 working.
Yours sincerely,
Fred
pipiche
Post by pipiche »
fredom@raspberrypi:~/domoticz/plugins/Domoticz-Zigbee/Tools $  sudo ./plugin-switch-stable9.sh --i-understand
    main()
Root cause: when plugin-switch-stable9.sh is run under sudo, the locale environment variables (LANG/LC_ALL) are typically stripped (sudo's env_reset default), so Python falls back to latin-1/ascii for stdout instead of UTF-8. The script's text contains an em dash (—, U+2014) and French accented characters, which don't exist in latin-1 in that context — print() then throws UnicodeEncodeError.
Try with:
sudo env PYTHONIOENCODING=utf-8 ./plugin-switch-stable9.sh --i-understand
or
 sudo env LC_ALL=C.UTF-8 ./plugin-switch-stable9.sh --i-understand
Fredom
Post by Fredom »
Hi Pipiche,
Thanks for your reply.
I’ve got it all working now, thanks to AI, and indeed there was a permissions issue as well—that’s been resolved too.
Yours sincerely,
Fred
