🎉 Zigbee for Domoticz — stable9 / 9.1.001 is out!
pipiche
Post by pipiche »
Hi everyone,
A new stable release of the Zigbee plugin is available: **9.1.001 (2026.8)**. This is a big one — it lays the technical groundwork for the plugin's future while also fixing a handful of long-standing device issues. Here are the highlights.
🔧 Key change: DomoticzEx is now the primary framework
The plugin now runs on Domoticz's **Extended Framework (DomoticzEx)** by default, replacing the legacy Domoticz API it relied on until now.
[b]Why we made the move:[/b]
- DomoticzEx represents each Zigbee device as a single Domoticz object with multiple "Units" underneath, instead of a flat list of independent Idx-based widgets. This gives a much more natural, grouped representation of multi-endpoint/multi-cluster devices.
- It's the modern, actively developed Domoticz API — this move is what unlocks the reliability work described below (the new supervisor, thread-safety, smarter widget reuse) and is the foundation for features we have planned next.
- Less widget clutter and duplication, especially for devices that previously spread across many separate Idx's.
⚠️[b] Important constraint — please read before upgrading:[/b]
Widgets created under DomoticzEx are **not compatible with the legacy Domoticz framework**. Once your devices have been (re)created under DomoticzEx by this release, **downgrading the plugin to a pre-9.1.001 / legacy-framework version is no longer possible** — Domoticz would not be able to expose those widgets again under the old API.
In practice this means:
- Take a backup (Domoticz database + plugin `Data`/`Conf` folders) **before** upgrading, so you can restore to your current state if needed.
- Treat this as a one-way migration: plan for it rather than upgrading impulsively on a production system.
- If you're not ready to commit to DomoticzEx yet, stay on your current stable8 release until you are.
🛡️ [b]Much more robust in the background[/b]
- A new **HA-grade supervisor** watches over the Zigbee (zigpy) thread, with automatic retry and recovery if something goes wrong — no more silent stalls.
- Serial port drops are now detected and reconnected automatically, with a startup check/retry loop.
- Shutdown is cleaner: zigpy now gets up to 30s to stop gracefully, with a clear "Zigbee transport stopped" status message.
- Widget creation is smarter: it reports precise failure reasons and retries recoverable failures automatically instead of silently giving up.
- Group management and widget creation were refactored — pairing now reuses your existing matching widgets instead of creating duplicates.
Under the hood, several core modules (zigpy thread, `tools.py`) were split into smaller, dedicated pieces and covered by a lot of new unit tests — should make the plugin more reliable and easier to maintain going forward.
🩹 [b]Device fixes[/b]
- **ZLinky**: improved STGE and tariff (OP_TARIF) handling.
- **Tuya**: fixed multi-gang/multi-widget devices picking up the wrong datapoint on some commands.
- **Danfoss**: refactored eTRV handling, new OEM variant supported.
- Fixed ColorControl widget subtype selection.
🐞 [b]Other fixes[/b]
- OTA updates now work correctly with DomoticzEx, plus a couple of OTA bugs squashed (JSON loading, heartbeat handling).
- Fixed a bug requesting configuration reports when Min/Max were both 0x0000.
🧰 [b]New tools[/b]
- `Tools/replace_device.py` — replace a physical device while keeping its Domoticz history.
- `Tools/repair_clustertype.py` — protects your provisioned cluster types from being wiped on re-announcement.
As always, full details are in the [Release Notes](https://github.com/zigbeefordomoticz/Do ... seNotes.md), and questions/feedback are welcome here or on the [Wiki](https://zigbeefordomoticz.github.io/wiki/en-eng/).
Thanks to everyone who reported issues, tested, and contributed to this release! 🙏
WouterO
Re: 🎉 Zigbee for Domoticz — stable9 / 9.1.001 is out!
Post by WouterO »
Congrats, pipiche! Great that this development still leads to improvements. Will update when back from holiday.
Thanks pipiche for all the hard work. I will update soon!
habahabahaba
Domoticz version: 2024.4
Post by habahabahaba »
Thank you!
But What about Win users? :)
waltervl wrote: Saturday 01 August 2026 19:38 Thanks pipiche for all the hard work. I will update soon!
Just updated, no issues until now!
Rik60
Post by Rik60 »
Upgraded to stable9, unfortunately not succesfull. After the update and confirm the switch via the command line to stable9 i have the next error; see attachment.
I can't upgrade/ install even the virtual environment is active
Switched back to a backup with version8
Edit: Running Domoticz on a Rpi3 Trixie Domoticz 2026.3
Z4D_error.txt
(395 Bytes) Downloaded 27 times
Houthakker
Post by Houthakker »
I just upgraded to stable9 and everything works just fine for me.
Thanks for your work Pipiche
Rik60
Post by Rik60 »
To accept te upgrade via --i-understand, i have to execute that command as superuser from the command line, is that normaal? How did other users the upgrade?
It depends how you installed the plugin and/or running Domoticz, with or without root access.
Rik60
Post by Rik60 »
New try to upgrade to Stable9. Failing again. Someone has a clou?
Z4D_update_log.txt
(40.43 KiB) Downloaded 24 times
I had to run a specific update to stable 9 script.
Edit: I had to run from Z4D plugin directory
./tools/plugin-switch-stable9.sh --i-understand
Rik60
Post by Rik60 »
Yes, i did that. Endded with no errors. The errors come after a Domoticz restart. Trying to upgrade fails during the requirements. The requirements should install the needed files?
WouterO
Post by WouterO »
I updated today. Took some reading how to jump to the new stable branch, but I am now successfully and painlessly on 9.1.002. Thank you pipiche.
The reason I am commenting: my cpu-load (on my raspberry pi 4) became significantly less(!) after the update, making me happy (because the cpu warms up slightly less).
Rik60
Post by Rik60 »
If i try an upgrade i see this error, the upgrade is rejected because of the next errors:
Flask-A-SQLAlchemy>=3.0.1, witch is not installed
pyopenssl 25.0.0 requeres cryptography<45, >=41.0.5, but you have cryptography 40.0.2 which is incompatible
But, are they nessesary, must they be on the system and if yes, how to install?
The install script for stable9 should tackle that all.
So it seems so ething after the switch to stable 9 is failing.
Fredom
Post by Fredom »
waltervl wrote: Tuesday 11 August 2026 19:07 The install script for stable9 should tackle that all.
Hi Walter,
Where can I find this script? Unfortunately, nothing I try works for upgrading to version 9.1.
Yours sincerely,
Fred
Rasberry Pi 3B+ - Debian Trixie - Domoticz 2026.3
RFLink - RFXCom - Z4D 9.1 (CC2652rb)
P1 Smart Meter - KaKu
WouterO
Post by WouterO »
@Fredom: in Tools folder, I had to run: sudo ./plugin-switch-stable9.sh --i-understand
Then, I could update to stable9 newest version.
Fredom
Post by Fredom »
WouterO wrote: Wednesday 12 August 2026 23:08 @Fredom: in Tools folder, I had to run: sudo ./plugin-switch-stable9.sh --i-understand
Hi Wouter,
I've tried various methods, but I keep getting the same error message.
fredom@raspberrypi:~/domoticz/plugins/Domoticz-Zigbee/Tools $  sudo ./plugin-switch-stable9.sh --i-understand
Checking Domoticz version and stable9 migration notice...
  File "/home/fredom/domoticz/plugins/Domoticz-Zigbee/Tools/check_stable9_migration.py", line 184, in <module>
    main()
  File "/home/fredom/domoticz/plugins/Domoticz-Zigbee/Tools/check_stable9_migration.py", line 168, in main
    display_migration_notice(version_status)
  File "/home/fredom/domoticz/plugins/Domoticz-Zigbee/Tools/check_stable9_migration.py", line 124, in display_migration_notice
    print("English:\n" + english + "\n")
UnicodeEncodeError: 'latin-1' codec can't encode character '\u2014' in position 1292: ordinal not in range(256)
Error: Domoticz version requirement not met. Cannot switch to stable9 branch.
Yours sincerely,
Fred
Rik60
Post by Rik60 »
Finally succeded to switch to stable9 9.1.002 from stable8 8.1.008. This is what i did:
- From the ui (user interface) updated the plugin
Then from the comman line:
switch to the plugin directory: cd domoticz/plugins/Domoticz-Zigbee
- set owner to pi: sudo chown -R pi:pi .
- go to the tools directory: cd Tools
- from command line executed: bash plugin-switch-stable9.sh --i-understand
This fails now, had to stash: git stash
again: - from command line executed: bash plugin-switch-stable9.sh --i-understand
Ok, switched the stable9 without errors
switched to the ui and updated the plugin -> updated stable9 without errors
Restarted the plugin in the ui
In the domoticz log errors: something to do with domoticz and domoticzex framework, both running on the same time
Rebooted the Rpi
No errors in the log
No Zigbee tab in the main domoticz screen -> Settings -> settings -> save settings
Ah, Zigbee tab in main screen
Can control Zigbee powerplug -> plugin works and actual version is 9.1.002
So, finally succes to switch to Stable9.
I hope that this can help other users.
BartSr
Domoticz version: V2024.7
Post by BartSr »
Just curious. Any advance compared to z2m?
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
