🎉 Zigbee for Domoticz — stable9 / 9.1.001 is out!
Hi everyone,
A new stable release of the Zigbee plugin is available: **9.1.001 (2026.8)**. This is a big one — it lays the technical groundwork for the plugin's future while also fixing a handful of long-standing device issues. Here are the highlights.
🔧 Key change: DomoticzEx is now the primary framework
The plugin now runs on Domoticz's **Extended Framework (DomoticzEx)** by default, replacing the legacy Domoticz API it relied on until now.
[b]Why we made the move:[/b]
- DomoticzEx represents each Zigbee device as a single Domoticz object with multiple "Units" underneath, instead of a flat list of independent Idx-based widgets. This gives a much more natural, grouped representation of multi-endpoint/multi-cluster devices.
- It's the modern, actively developed Domoticz API — this move is what unlocks the reliability work described below (the new supervisor, thread-safety, smarter widget reuse) and is the foundation for features we have planned next.
- Less widget clutter and duplication, especially for devices that previously spread across many separate Idx's.
⚠️[b] Important constraint — please read before upgrading:[/b]
Widgets created under DomoticzEx are **not compatible with the legacy Domoticz framework**. Once your devices have been (re)created under DomoticzEx by this release, **downgrading the plugin to a pre-9.1.001 / legacy-framework version is no longer possible** — Domoticz would not be able to expose those widgets again under the old API.
In practice this means:
- Take a backup (Domoticz database + plugin `Data`/`Conf` folders) **before** upgrading, so you can restore to your current state if needed.
- Treat this as a one-way migration: plan for it rather than upgrading impulsively on a production system.
- If you're not ready to commit to DomoticzEx yet, stay on your current stable8 release until you are.
🛡️ [b]Much more robust in the background[/b]
- A new **HA-grade supervisor** watches over the Zigbee (zigpy) thread, with automatic retry and recovery if something goes wrong — no more silent stalls.
- Serial port drops are now detected and reconnected automatically, with a startup check/retry loop.
- Shutdown is cleaner: zigpy now gets up to 30s to stop gracefully, with a clear "Zigbee transport stopped" status message.
- Widget creation is smarter: it reports precise failure reasons and retries recoverable failures automatically instead of silently giving up.
- Group management and widget creation were refactored — pairing now reuses your existing matching widgets instead of creating duplicates.
Under the hood, several core modules (zigpy thread, `tools.py`) were split into smaller, dedicated pieces and covered by a lot of new unit tests — should make the plugin more reliable and easier to maintain going forward.
🩹 [b]Device fixes[/b]
- **ZLinky**: improved STGE and tariff (OP_TARIF) handling.
- **Tuya**: fixed multi-gang/multi-widget devices picking up the wrong datapoint on some commands.
- **Danfoss**: refactored eTRV handling, new OEM variant supported.
- Fixed ColorControl widget subtype selection.
🐞 [b]Other fixes[/b]
- OTA updates now work correctly with DomoticzEx, plus a couple of OTA bugs squashed (JSON loading, heartbeat handling).
- Fixed a bug requesting configuration reports when Min/Max were both 0x0000.
🧰 [b]New tools[/b]
- `Tools/replace_device.py` — replace a physical device while keeping its Domoticz history.
- `Tools/repair_clustertype.py` — protects your provisioned cluster types from being wiped on re-announcement.
As always, full details are in the [Release Notes](https://github.com/zigbeefordomoticz/Do ... seNotes.md), and questions/feedback are welcome here or on the [Wiki](https://zigbeefordomoticz.github.io/wiki/en-eng/).
Thanks to everyone who reported issues, tested, and contributed to this release! 🙏
🧰 [b]New tools[/b]
WouterO
Re: 🎉 Zigbee for Domoticz — stable9 / 9.1.001 is out!
Congrats, pipiche! Great that this development still leads to improvements. Will update when back from holiday.
- Domoticz version: 2026.3
Thanks pipiche for all the hard work. I will update soon!
- habahabahaba
- Domoticz version: 2024.4
Thank you!
But What about Win users?
Just updated, no issues until now!waltervl wrote: Saturday 01 August 2026 19:38 Thanks pipiche for all the hard work. I will update soon!
Rik60
Upgraded to stable9, unfortunately not succesfull. After the update and confirm the switch via the command line to stable9 i have the next error; see attachment.
I can't upgrade/ install even the virtual environment is active
Switched back to a backup with version8
Edit: Running Domoticz on a Rpi3 Trixie Domoticz 2026.3
- Z4D_error.txt
- (395 Bytes) Downloaded 26 times
Houthakker
- Target OS: -
I just upgraded to stable9 and everything works just fine for me.
Thanks for your work Pipiche
Rik60
To accept te upgrade via --i-understand, i have to execute that command as superuser from the command line, is that normaal? How did other users the upgrade?
It depends how you installed the plugin and/or running Domoticz, with or without root access.
Rik60
New try to upgrade to Stable9. Failing again. Someone has a clou?
- Z4D_update_log.txt
- (40.43 KiB) Downloaded 23 times
I had to run a specific update to stable 9 script.
Edit: I had to run from Z4D plugin directory
./tools/plugin-switch-stable9.sh --i-understandDomoticz running on Udoo X86 (on Ubuntu)
Rik60
Yes, i did that. Endded with no errors. The errors come after a Domoticz restart. Trying to upgrade fails during the requirements. The requirements should install the needed files?
WouterO
I updated today. Took some reading how to jump to the new stable branch, but I am now successfully and painlessly on 9.1.002. Thank you pipiche.
The reason I am commenting: my cpu-load (on my raspberry pi 4) became significantly less(!) after the update, making me happy (because the cpu warms up slightly less).
Rik60
If i try an upgrade i see this error, the upgrade is rejected because of the next errors:
But, are they nessesary, must they be on the system and if yes, how to install?
Flask-A-SQLAlchemy>=3.0.1, witch is not installed
pyopenssl 25.0.0 requeres cryptography<45, >=41.0.5, but you have cryptography 40.0.2 which is incompatible - waltervl
The install script for stable9 should tackle that all.
So it seems so ething after the switch to stable 9 is failing.
Fredom
Hi Walter,waltervl wrote: Tuesday 11 August 2026 19:07 The install script for stable9 should tackle that all.
Where can I find this script? Unfortunately, nothing I try works for upgrading to version 9.1.
Yours sincerely,
Fred
Rasberry Pi 3B+ - Debian Trixie - Domoticz 2026.3
RFLink - RFXCom - Z4D 9.1 (CC2652rb)
P1 Smart Meter - KaKu
Fred
WouterO
@Fredom: in Tools folder, I had to run: sudo ./plugin-switch-stable9.sh --i-understand
Then, I could update to stable9 newest version.
Fredom
Hi Wouter,WouterO wrote: Wednesday 12 August 2026 23:08 @Fredom: in Tools folder, I had to run: sudo ./plugin-switch-stable9.sh --i-understand
I've tried various methods, but I keep getting the same error message.
fredom@raspberrypi:~/domoticz/plugins/Domoticz-Zigbee/Tools $ sudo ./plugin-switch-stable9.sh --i-understand
Checking Domoticz version and stable9 migration notice...
File "/home/fredom/domoticz/plugins/Domoticz-Zigbee/Tools/check_stable9_migration.py", line 184, in <module>
main()
File "/home/fredom/domoticz/plugins/Domoticz-Zigbee/Tools/check_stable9_migration.py", line 168, in main
display_migration_notice(version_status)
File "/home/fredom/domoticz/plugins/Domoticz-Zigbee/Tools/check_stable9_migration.py", line 124, in display_migration_notice
print("English:\n" + english + "\n")
UnicodeEncodeError: 'latin-1' codec can't encode character '\u2014' in position 1292: ordinal not in range(256)
Error: Domoticz version requirement not met. Cannot switch to stable9 branch.
Yours sincerely,
Fred
Fred
Rik60
Finally succeded to switch to stable9 9.1.002 from stable8 8.1.008. This is what i did:
- From the ui (user interface) updated the plugin
Then from the comman line:
switch to the plugin directory: cd domoticz/plugins/Domoticz-Zigbee
- set owner to pi: sudo chown -R pi:pi .
- go to the tools directory: cd Tools
- from command line executed: bash plugin-switch-stable9.sh --i-understand
This fails now, had to stash: git stash
again: - from command line executed: bash plugin-switch-stable9.sh --i-understand
Ok, switched the stable9 without errors
switched to the ui and updated the plugin -> updated stable9 without errors
Restarted the plugin in the ui
In the domoticz log errors: something to do with domoticz and domoticzex framework, both running on the same time
Rebooted the Rpi
No errors in the log
No Zigbee tab in the main domoticz screen -> Settings -> settings -> save settings
Ah, Zigbee tab in main screen
Can control Zigbee powerplug -> plugin works and actual version is 9.1.002
So, finally succes to switch to Stable9.
I hope that this can help other users.
Rebooted the Rpi
BartSr
- Domoticz version: V2024.7
Just curious. Any advance compared to z2m?
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Chinese sensors temp (Dallas),movement
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
