Invalid Buienradar data?
madpatrick
Domoticz version: 2026.1
Re: Invalid Buienradar data?
Post by madpatrick »
vespino wrote: Thursday 11 June 2026 14:13 Is there a way I can make the necessary changes and push an update somewhere? I'd be glad to help if I know where to look.
You can make a PR in Git
vespino
Post by vespino »
Done! Done!
WouterO
Post by WouterO »
vespino wrote: Thursday 11 June 2026 14:50Done! Done!
Thumbs up :)
The waiting starts…
Jeweettoch13
Domoticz version: 2026.4
Post by Jeweettoch13 »
WouterO wrote: Thursday 11 June 2026 15:26
Thumbs up :)
The waiting starts…
So there's nothing we can fix at the moment if i read correctly?
WouterO
Post by WouterO »
No, it’s hard-coded in Domoticz (it’s not a separate plugin).
You might install another weather supplier, check the hardware such as Open Weather Map or Open-Meteo
madpatrick
A fix had been posted by Vestino at Domoticz GIT as you can read above
Once accepted by Gizmocus it might get released with the next beta
Domoticz version: 2026.3
Is being worked on as we speak, hopefully fixed in beta soon.
Gizmocuz has fixed the issue, there were also some other impacts in the change, see the discussion in https://github.com/domoticz/domoticz/pull/6850
New beta is available.
WouterO
Post by WouterO »
waltervl wrote: Friday 12 June 2026 10:20 Gizmocuz has fixed the issue, there were also some other impacts in the change, see the discussion in https://github.com/domoticz/domoticz/pull/6850
Thanks, Gizmocuz! I just installed the beta, and everything is working fine again. Thanks for fixing the Buienradar issue!
kuifje
Domoticz version: latest
Post by kuifje »
Gizmocuz for president.
Rik60
Post by Rik60 »
Can confirm that its working again. Thanks. How can i see what station is used?
Domoberry
Domoticz version: 2026.2
Post by Domoberry »
pulled the latest Docker beta image: all working again!
Thanks for the very fast fix!
Rik60 wrote: Friday 12 June 2026 12:10 Can confirm that its working again. Thanks. How can i see what station is used?
It is in the log. When you update the buienradar hardware gateway (click button update) it will restart and show what it discovered and uses.
Tuinfluiter
Post by Tuinfluiter »
It looks as if it is working again. I didn't change any software, but since this morning 9:45 the error messages stopped and I have a temparature graph again.
Can someone confirm?
Domoticz running on Pi4
RFXcom, Zwave2MQTT, Zigbee (Z4D), P1, Tado X
Looks like buienradar changed the json output of https://data.buienradar.nl/2.0/feed/json back to original lowercase.
Domoticz Beta can handle both now so no new changes to be expected.
Gravityz
Post by Gravityz »
i just discovered this. i was about to upgrade and all the sensors came back.
what a bunch of idiots. lucky for us domoticz can handle both.
does the auto feature( station to 0) also work.
i had mine switched to the nearest station because i thought that was the only problem but it was not.
UPDATE: tested and 0 still works
mariaa
Target OS: OS X
Post by mariaa »
I see that several of you have run into problems with Buienradar data since June 9. I've had trouble getting valid data too. Looking at the thread, it seems Buienradar recently changed their JSON format, which messed up Domoticz.
There's an update proposed on Git by Vespino, and I hope it fixes our issues soon. In the meantime, have you tried other solutions like using another weather provider?
I saw users mentioning Open Weather Map. That could be a good alternative until the problem gets sorted.
Automate ur home, simplify ur life with esim.
WouterO
Post by WouterO »
mariaa wrote: Wednesday 17 June 2026 0:34 I see that several of you have run into problems with Buienradar data since June 9. I've had trouble getting valid data too. Looking at the thread, it seems Buienradar recently changed their JSON format, which messed up Domoticz.
Did you notice in this thread the solution of Gizmocuz? It’s all fixed in the latest beta.
“Gizmocuz has fixed the issue, there were also some other impacts in the change, see the discussion in https://github.com/domoticz/domoticz/pull/6850
New beta is available.”
Gravityz
Post by Gravityz »
latest downloadable image is 18021. this should be 18024 (commit 15917+2107)
WouterO
Post by WouterO »
Gravityz wrote: Wednesday 17 June 2026 11:57 latest downloadable image is 18021. this should be 18024 (commit 15917+2107)
Gizmocuz repaired this issue in v2026.2 (build 18016)
