mvveelen
Post by mvveelen »
@ FutureCow : how did you get the Skycons (?) in there? If they are Skycons :) ?
Can you share your code? Maybe others like to use (some of) it.
FutureCow
Post by FutureCow »
mvveelen wrote:@ FutureCow : how did you get the Skycons (?) in there? Can you share your code?
After more than one hour of trying, i gave up...
I've made a gif for every icon, took me only 10 minutes for all the icons... I can share the gifs, but with the background!(i can create white with black background if people are interested)
mvveelen
Post by mvveelen »
If you can make both? Or, can't you make them with a transparent background?
I don't understand why it isn't possible to add the Skycons..... jan_nl ? bbqkees ? :D
floris74
Post by floris74 »
I guess it's possible to save them as *.png file, which supports transparent as far as I know.
Jan_nl, about the icons directory and his files! where do I get them? In what version of front page.html or whatever where they in?
SwordFish
Domoticz version: V4.11375
Post by SwordFish »
How do i get the the sunrise and sunset in a cell?
mvveelen
Post by mvveelen »
jan_nl wrote:Added some sort of traffic info, max 4 traffic-jams, the text is clickable and brings you to http://www.anwb.nl/verkeer (which is not configurable (not yet anyway)).
Changes in frontpage.css (cell2_3), frontpages_settings.js and frontpage.js
I also added a script (wget_verkeer.sh) to get an rss feed from verkeerplaza, so this propably only works in the Netherlands. This scripts must run via crontab (changes about every minute)
Would it be possible to post the pieces of code, stating where you have to put them, and in which file? That way people can use the pieces they want.
This method is used by bulletin boards, when they make 'mods' (modifications). I think this will make it a lot easier for everybody to help improve the frontpage.
Sure, this will take a some more energy and time, but what about he users who have other ideas from which everyone can profit?
Example (it shows which file to edit and where to add or replace a piece of code -> see how important the comments are :) ?) :
<edit file>
Themes/default/Display.template.php
</edit file>
<search>
// Show the anchor for the top and for the first message. If the first message is new, say so.
</search>
<replace>
global $bar_exps, $bar_posts;
</replace>
(source: http://wiki.simplemachines.org/smf/Manu ... on_of_mods)
thorbj
Post by thorbj »
jan_nl wrote:And yet another update.
Changes are the possibility to add sunrise/sunset to a cell.
Changes are in frontpage_settings.js (enabling option and 3 new var's) and frontpage.js bottom and top of main refresh function
If you use the included css, remember it is made smaller to fit my 7" tablet.
Great work with the sunrise/sunset option jan_nl!
I noticed the weather icons were somewhat dragged in the latest release. I changed the width to the same value as the height to get the right dimentions. Worked for the current weatherstatye here, haven't controlled the others yet.
Anyway, here's the code-part form frontpage.js:
// replace forecast (text) with an image
                                                if (vdata == 'Sunny' ) {
                                                        vdata=new String(vdata).replace( "Sunny","<img src=icons/day_sun.png width=155 height=155>");
                                                if (vdata == 'Partly Cloudy' ) {
                                                        vdata=new String(vdata).replace( "Partly Cloudy","<img src=icons/day-partlycloudy.png width=155 height=155>");
                                                if (vdata == 'Cloudy' ) {
                                                        vdata=new String(vdata).replace( "Cloudy","<img src=icons/day-cloudy.png width=155 height=155>");
                                                if (vdata == 'Clear' ) {
                                                        vdata=new String(vdata).replace( "Clear","<img src=icons/day_sun.png width=155 height=155>");
                                                if (vdata == 'Rain' ) {
                                                        vdata=new String(vdata).replace( "Rain","<img src=icons/day-rain.png width=155 height=155>");
                                                if (vdata == 'Snow' ) {
                                                        vdata=new String(vdata).replace( "Snow","<img src=icons/day-snow.png width=155 height=155>");
                                                if (vdata == 'Fog' ) {
                                                        vdata=new String(vdata).replace( "Fog","<img src=icons/day-fog.png width=155 height=155>");
                                                if (vdata == 'Hail' ) {
                                                        vdata=new String(vdata).replace( "Hail","<img src=icons/day-hail.png width=155 height=155>");
                                                if (vdata == 'Thunderstom' ) {
                                                        vdata=new String(vdata).replace( "Thunderstorm","<img src=icons/day-thunder.png width=155 height=155>");
                                                if (vdata == 'Sleet' )  {
                                                        vdata=new String(vdata).replace( "Sleet","<img src=icons/day-sleet.png width=155 height=155>");
2xRaspberry Pi Model 2 w/RaZberry z-wave chip (master/slave)|Fibaro Wall Plug|Fibaro Universal Dimmer 500W|Aeon Labs Multisensor|RFXtrx433E|Nexa WMR-1000|Nexa Pe-3|Nexa Remote|Nexa LGDR3500|Lightify Gateway|Lightify RGBW bulb
thorbj
Post by thorbj »
I took the liberty to rewrite the time/date function in frontpage.js so it would display the date in the following format: 3. feb 2015 hh:mm
//Return current time: dd. month yyyy hh:mm
function currentTime() {
    var today=new Date();
    var h=today.getHours().toString();
    h = h.trim();
    if (h.length == 1) {
	h = '0'+ h;
    var m=today.getMinutes().toString();
    m = m.trim();
    if (m.length == 1) {
	m = '0'+ m;
    var day=today.getDate().toString();
    day = day.trim();
	//Change the months to reflect your preferred translation
	var month = new Array();
		month[0] = "jan.";
		month[1] = "feb.";
		month[2] = "mar.";
		month[3] = "apr.";
		month[4] = "may";
		month[5] = "jun.";
		month[6] = "jul.";
		month[7] = "aug.";
		month[8] = "sept.";
		month[9] = "oct.";
		month[10] = "nov.";
		month[11] = "dec.";
	var month = month[today.getMonth()];
    var year=today.getFullYear();
    //To display month first, change the following string to
    //var ret_str=month+" "+day+". "+year+" "+h+":"+m;
    var ret_str=day+". "+month+" "+year+" "+h+":"+m;
    return ret_str;
If someone wants it to display "the american way" like Month Day. Year, you can switch the second-last string with:
thorbj
Post by thorbj »
Is it possible to add &deg;C after the value in temp cells?
SwordFish
Post by SwordFish »
Can someone please tell me howto use the sunrise/sunset option :?:
thorbj
Post by thorbj »
SwordFish wrote:Can someone please tell me howto use the sunrise/sunset option :?:
 ['29','Sun',         'cell21',                       '','0','0','color:#17E213;font-size:50$'],
in frontpage_settings.js worked for me.
SwordFish
Post by SwordFish »
Thanks, but do i have to make a dummy switch for the sunrise and sunset?
jannl
Domoticz version: 2026.1.x
Post by jannl »
No you don't. Take care, better use 0 instead of 29. And you now can use SunBoth, SunRise and SunSet as well.I had some stand issues when using an existing idx by accident.
I downloaded the icons from a link on this forum. I will post them here in several files today of tomorrow
@mvveelen: I understand the need for mods, however I don't really understand how. Comments in the code are present, more or less. But I will make it more clear with future changes
vanputten80
Post by vanputten80 »
Is it possible to add NS train information?
And can I make the second page as start page?
SwordFish
Post by SwordFish »
jan_nl wrote:No you don't. Take care, better use 0 instead of 29. And you now can use SunBoth, SunRise and SunSet as well.I had some stand issues when using an existing idx by accident.
Thanks that works. But now i want to get sunsrise in one cell en sunset in another cell. I have now set idx '0' and value 'Sun'. when i put 'SunRise' in the value i get nothing? Is there something i have to change?
bbqkees
Domoticz version: 4.1x
Post by bbqkees »
I missed a few days over here and in the mean time this topic kind of exploded.
Is everything working right now in respect to dimming, thermostat and the correct amount of swipe-able pages?
Seems so.
I looked into the skycons issue, but I have not resolved that yet. The alternative solution with the GIF files could be an easy sidestep of the problem.
jkimmel
Domoticz version: 2021.1
Post by jkimmel »
@bbqkees
I created a virtual setpoint device, I now see I need to send another command for those devices.
/json.htm?type=command&param=udevice&idx=93&nvalue=0&svalue=21.5
But I can fix that this weekend.
Is this fixed already?
Rfxcom
Raspi 4
floris74
Post by floris74 »
For now i created 2 virtual push buttons;
on, with 'aan actie' and 'uit actie'
http://192.168.1.56:1720/json.htm?type= ... value=17.5
off, with 'aan actie' and ´uit actie'
http://192.168.1.56:1720/json.htm?type= ... value=15.5
I haven't tried it since your last update with the thermostat, which didnt work.
bbqkees, did it all worked wel with building the house?
Floris
jesper
Post by jesper »
Is it possible to get battery level and if the device is online/offline?
BobbyNL
Post by BobbyNL »
I have entered my IDX doorbell and my frontdoorcamera is working in frontpage. But when I press the doorbell there will be no popup. How can I make it work .
I tried Chime, On and Group On but no luck.
Rpi-Domoticz +RFXtrx433E | Rpi-Openelec | Rpi-Runeaudio | unRaid 6 server | Intel NUC-Linux Tvheadend + Oscam
