Small Energy Dashboard bug.
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Kedi
Domoticz version: latest
Post by Kedi »
The Energy dashboard has a small bug. As you can see that before the sun is up my converter uses some energy from midnight till 06:38:42 -0.022 kWh
The power is not negative in the dashboard despite the fact that in the data from the device it is negative -3 Watt
The moving lines are also wrong because that power used by the inverter is comming from the net and is not feed into the house.
gizmocuz
Re: Small Energy Dashboard bug.
Post by gizmocuz »
The reason for this is that we make the value positive in the Energy Dashboard as there are devices that returns -3000 Watt of the PV is generating 3000 Watt.
So in your case, (and i find it strange your PV is reporting it this way... but ok) .. you have to deal with this.
