The Energy dashboard has a small bug. As you can see that before the sun is up my converter uses some energy from midnight till 06:38:42 -0.022 kWh
The power is not negative in the dashboard despite the fact that in the data from the device it is negative -3 Watt
The moving lines are also wrong because that power used by the inverter is comming from the net and is not feed into the house.
Small Energy Dashboard bug.
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
Kedi
- Domoticz version: latest
- gizmocuz
Re: Small Energy Dashboard bug.
The reason for this is that we make the value positive in the Energy Dashboard as there are devices that returns -3000 Watt of the PV is generating 3000 Watt.
So in your case, (and i find it strange your PV is reporting it this way... but ok) .. you have to deal with this.
