Python plugin: UPS Monitor
manuloup
Re: Python plugin: UPS monitoring
Post by manuloup »
I tried the new version of file plugin.py but I don't see anything in the log file if I check for UPS.
Not sure it is working though.
Rapberry PI B+ (RaspBian), RFXtrx433E USB 433.92MHz Transceiver, AEON LABS Controler Z-Wave, Aeon Labs Z-Stick S2, Everspring ST814 Temperature Sensor, Everspring SF812 Smoke Detector, 2x Fibaro Wallplug, Aeon Zwave Miniremote , Xbee Teleinfo USB
manuloup
Post by manuloup »
Devices look up to date, so I guess this is good.
Thanks for your help, madpatrick.
UPS devices.jpg (146.26 KiB) Viewed 3968 times
eddieb
Post by eddieb »
I noticed this error on my rpi running under docker...
2026-06-02 10:31:43.121  Error: UPS Meterkast: (NUT_UPS) failed to load 'plugin.py'.
2026-06-02 10:31:43.258  Error: UPS Meterkast: Traceback (most recent call last):
2026-06-02 10:31:43.258  Error: UPS Meterkast:   File "/opt/domoticz/userdata/plugins/NUT_UPS/plugin.py", line 37, in <module>
2026-06-02 10:31:43.258  Error: UPS Meterkast:     import telnetlib
2026-06-02 10:31:43.258  Error: UPS Meterkast: ModuleNotFoundError: No module named 'telnetlib'
this did work for a couple of months, is there some recent change that removed telnetlib ?
suggestions how to fix ?
RPI4 Beta / Tasmota / ZigBee2MQTT / P1meter / Haier AC MQTTmapper / SolarEdge SE3500H modbus_tcp / IndeVolt SF3000 / Opentherm gateway / Plugwise Anna/Smile / ObserverIP weatherstation thru WuDirect
Feeding ADSB https://adsb.im/home
Domoticz version: 2026.3
eddieb wrote: Tuesday 02 June 2026 11:19 I noticed this error on my rpi running under docker...
For docker and installations of Python modules see https://wiki.domoticz.com/Docker#Python_Plugins
Also docker image has moved to Python 13 so perhaps the module is not compliant.
madpatrick
Domoticz version: 2026.1
Post by madpatrick »
See a few post earlier
Replace: import telnetlib
viewtopic.php?p=332146#p332146
eddieb
Post by eddieb »
I used your adjusted plugin.py and now it works.
Are you pushing that changes to the plugin developer ?
Re: Python plugin: UPS Monitor
I merged the UPS Monitor sub discussion with the original discussion. Probably something went wrong while creating the question.
rini52
Domoticz version: 2025.2
Post by rini52 »
Guys many thanks.
I got nut running on trixi with domoticz in docker. I can confirm that updating the plugin.py with the pluging.py.txt and in stalling telnetlib3 works. Just changing the original plugin.py with "import telnetlib3 as telnetlib" didn't work. Also make sure that you have the config files set with root:nut credetials.
Gr.
Domoticz running on Pi-4, Ubuntu(amd64), Synology Nas and VM
Hardware: RFXCOM, RFLINK, P1-smartmeter-HomeWizard, Z2M Sonoff dongle(20+ devices), Esp8266 (counters), Eaton_3S ups
